Question about Sony Ericsson Cyber-shot C902 Cellular Phone
I can't seem to open MMS messages, despite trying to download settings etc several times as for some reason no internet connection can be found. Can you help please?
Samsung eternity change apn
Eternity 2 settings for straight talk
i finally figured it out.
in fact the browser does use the same profile as mms on straight talk. but there are 3
settings for this phone in which need to be changed in order to use internet and mms..
I just found this been looking all day. i havn't got to try it yet but seen several people post they did it and everything is working. good luck.
1st is application/messaging/multimedia message/mms profiles/select the st profile added....
2nd is application settings/browser/browser profiles/select st profile added.....
3rd that i was not aware of....applications/more/connections/default/select st profile added....
everything seems to be working correctly now
Jun 30, 2012 | Samsung Eternity Cell Phone
Its a nokia phone made in china and i recieve a mms message then i cant view through my phone besides my gprs is activated,what would i do in order to open my mms message recieve?
Try retrieve the message for several times. check MMS settings. or may be the MMS has expired at the server and not available to download.
Mar 02, 2011 | Cell Phones
LG KS360
Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL http://live.vodafone.com
- GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address http://pxt.vodafone.net.nz/pxtsend
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
Dec 22, 2009 | LG KS20 Smartphone
To activate gprs in htc p3350
Thank you for choosing Fixya.com
Please follow the instruction below very carefully and make sure that you have load of your sim enjoy.
For Globe Subscribers:
For a complete listing of compatible MMS & GPRS phone handsets — send NOKIA, ERICSSON or SAMSUNG (your handset model) to 2365.
To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1)
Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
Enter 1234 when asked for PIN to save settings.
Send an MMS message for only Php 5.00 to activate the service.
Note: For prepaid subscribers, please make sure you have credits first before trying to access GPRS/MMS. You won’t be able to use the service if you have zero balance.
For Smart Subscribers:
OTA (over-the air) configuration
a) To activate GPRS *and* MMS
- SET MMS send to 211
- wait for the configuration to be downloaded to your phone (up to 24 hours)
- once downloaded, you will have SmartMMS data account, and SmartMMS WAP profile, and your MMS is configured already to use SmartMMS WAP profile
- you will also receive a confirmation message that your GPRS and MMS have been activated
b) To configure internet access (full access)
- SET INTERNET (handset model) send to 211
- wait for the configuration to be download to your phone, in minutes
- once downloaded, you will have SmartPC data account, and SmartPC WAP Profile
- edit this account to include DNS settings. DNS IP addresses are -202.057.096.003, 202. 057.096.004. you only need one.
c) To configure WAP via GPRS
- SET GPRS T68 send to 211
- once downloaded, you will have SmartGPRS data account, and SmartGPRS WAP Profile. SET THIS AS YOUR DEFAULT PROFILE
d) To configure WAP via CSD (Optional - kasi MAY BAYAD ITO, per minute)
- SET WAP T68 send to 211
- once downloaded, you will have SmartWAP data account, and SmartWAP WAP Profile. SET THIS AS YOUR DEFAULT PROFILE
I suggest you clear all your existing data accounts and wap profile beforeyou do this. If you follow the instructions in this order, SmartPC will have a CID=2. Your dial-up number willbe *99***2#
or to simplify it:
Setting up of MMS and GPRS handsets:
To download SMART MMS phone settings, key in SET MMS and send to 211.
To download SMART GPRS phone settings, key in SET GPRS and send to 211.
Activating SMART MMS and GPRS:
To activate SMART GPRS, key in GPRS ON and send to 333.
To activate SMART MMS, key in MMS ON and send to 333
Upon receiving the configuration settings, select "Save All" to save the settings in the phone.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
For SUN USERS:
Sun MMS
On the home screen, press the Programs soft key, press More to move to the next page.
Press Accessories then select MMS Setup by pressing the Action button.
Provide the following data on the required field, press Ok when done.
q First field: MMS connection
q IP: 202.138.159.78
q Port: 9201
q MMSC Address:
q Message Expiry: 1 day
q MMS Download: Auto
Press Settings, select Data Connection.
Press the Menu soft key then select Edit Connection by pressing the Action button
Select GPRS Connection. Press Menu then select Add by pressing the Action button
Provide the following data on the required field:
q Description: Sun MMS connection
q Connects to: MMS Connection
q Access point: mms
When finished, press Done four times.
Sun GPRS
Press the Menu soft key then select Edit Connection by pressing the Action button.
Select GPRS Connection. Press Menu then select Add by pressing the Action button.
q Description: Sun GPRS
q Connects to: The Internet
q Access point: minternet
Press Done three times. On the Data connection, select Sun GPRS under Internet connection.
When finished, press Done.
Sun WAP GPRS
q Description: Sun WAP GPRS
q Access point: mms
Press Done three times. On the Data connection, select Sun WAP GPRS under WAP connection.
Sun WAP Proxy
Crate a proxy connection
Description: Sun WAP Proxy
Connects from: The internet
Connects to: WAP network
Proxy (name/Port): 193.113.200.195
Type: WAP
To Activate GPRS:
Create a text message, type "ACTIVATE" then send to 2300
please don't forget to rate our answers properly.
Feb 23, 2009 | HTC P3300 Smartphone
HTC TyTn II data connection problem
It keeps connecting because an application keeps wanting to access the internet.
Make sure you set your email to manually download messages.
Turn the Weather Tab off in HTC Home Screen as it automatically downloads the weather.
Turn off "QuckGPS"
Disable Error Reporting to Microsoft in the System settings
Also remember MMS messages will require internet connection.
Everytime you send a MMS or receive a MMS your phone will connect to the internet.
Jun 20, 2008 | HTC TyTN II Smartphone
GPRS settings
i have Motorola w220 model mobile phone and mms, gprs activation setting how to save it
Apr 16, 2008 | Cell Phones
Unlocked Viewty - need help configuring internet and MMS settings for T-Mobile USA
Then Enter the following for mms
MMS Settings Step 1. Main Menu
· Click on the button with the four dots
· Settings (on right hand side) · Phone Settings
· Connectivity
· Access points
· Options and create a new profile with the following details... - Connection title: Telstra MMS - Bearer: GPRS
- Authentication: No Auth
- APN: telstra.mms.mnc001.mcc505.gprs ** Please note you do not need to enter any user name or passwords. Leave them blank. Step 2. Save the settings and return back to the main menu to select Messaging
· Messaging settings
· MMS
· Multimedia msg. centre
· Options and select Add new - Connection Title: Telstra MMS
- MMSC URL: http://mmsc.telstra.com:8002
- MMS Proxy: 010.001.001.180 - Connection: TCP with Proxy - Access point: Open list and select Telstra MMS. Return to the Multimedia msg. Centre menu and activate Telstra MMS on that screen.
Apr 06, 2008 | LG KU990 Viewty
Receiving MMS on Treo 650
That soulution dont seem possible with Palm treo 650 running Palm OS
Dec 13, 2007 | Palm Treo 650 Handheld
Sony Ericsson Cyber-shot C902 Cellular Phone Logo
153 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
