Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Fridge motor on too much it seems
I have an ~10 yr old Kenmore refrigerator R134A Model # 25369842890. Lately the compressor motor seems to be on much too frequently. I've tried lowering the internal thermostat knobs to their lowest level ''cold'' in each case. However it seems to be the same.
  • stuart_gaffi Nov 12, 2009
    I didn't describe the problem correctly. The thermostat knobs in freezer and fridge have two extemes "Coldest" to the left and "cold" to the right. So "cold" should be the "warmest" setting.
    Sorry for the confusion
  • 909 Answers
Remember, the colder you make the thermostat, the longer the compressor will run to try and reach the required temperature. Question is," is the temperature in the fridge cold enough or not cold enough." If it is, then you will need to have the thermostat replaced.(there is no control). If not cold enough at any time, then there is an issue with the cooling circuit.(Will then need to have it checked by a technician.
Posted on Nov 12, 2009
Is there any difference between the plain auto R134a and R134a used in the 2000 year Kenmore refrigerator model 596.58642890? If it is different where can I buy a small can of appliance grade R134a ?
r134a gas is r134a gas and it is used in a variety of applications
because it is a extreme high pressure gas , it is unlikely that you will get a small can of it
It will be cheaper to have a fridge technician come and use the right amount as it normally comes in a 9 kg bottle and cost plenty
a fridge may use 100 grms if lucky
Oct 03, 2015 | Kenmore Side by Side Refrigerator
My compressor for my kenmore elite fridge SF43C72RAU6 R134a is making a knocking/pinging sound from within unit
If its the compressor, the compressor is bad and needs to be replaced, typically when they do that, they will short out, and trip the breaker.
It could be the condenser fan motor going bad too, knocking/pinging noise seems more suspect to a fan motor going out or a bent fan blade.
Recommend a appliance repairman to look at this
Jul 08, 2013 | Refrigerators
2 yeaor old kenmore fridge not working, motor runs
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | Kenmore Refrigerators
There is a line with with wrappin on back of ref that is frezzing over wht is wrong
That is typically a sign of a problem with the heat exchange, specifically the suction line and capillary line have separated OR...the system has been worked on recently and been over-charged with refrigerant.
Answer me these questions...
Is it frosting up close to the compressor ? Where it comes out the back wall at the top back corner only ? Or the entire line all the way down to the compressor ?
Has this fridge had any system work performed on it recently or has anyone "topped it up" with refrigerant ?
What are the temperatures in the fridge ? Are you capable of gauging/measuring system pressures ?
Finally, how old is this fridge and do you know if it contains R12 or R134A ? ...if it`s old enough for R502, forget it ha ha !
I`ll watch for your reply.
macmarkus :)
Jun 22, 2010 | Kenmore 64802 Top Freezer Refrigerator
My Kenmore fridge, Model 596-58692890 is not cooling and I've lost use of the water/ice dispenser. The motor and compressor seem to be working but the cool air is not blowing. What part might need to be...
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 24, 2009 | Kenmore Refrigerators
Motor stopped running days after move
Unfortunatly in most cases it is more expensive to fix than replace. A compressor change is at least 3 hours. The other cost include the compressor, drier, recovery machine, recovery cylinder, silver sodder, torch fees, and so on. The compressor will likely cost around $300. A used fridge in the paper can cost less then $200. Please let me know if you need anymore information.
Feb 19, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore 106.63854302 Coldspot is not holding temperatures
Hi i had the same problem and someone came in it was well worth it it was the relay button and it only cost $50.00 for the part .
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator knocking noise
the motor could be on the way out. Put your hand (carefully) on the motor (back of the refridgerator), if it is too hot to touch then the motor is burning out and will need to be replaced.
Nov 15, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore Refrigerator making loud sounds at shutdown
the compressor has a loose or broken spring inside the compressor, unfortunatly it can not be repaired without replacing the compressor, it could last many more years and it could quit as we speak.
best thing is to let the neighbor know of the problem and what is the repair that way they won't think you are ponning off the machine to them, it may outlast your new one, time will tell
Apr 15, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
146 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
