Whirlpool LG5531xkwo need to replace drive belt and re-install idler pulley. I have found a parts listing schematic, but it's not clear how the idler pulley should be re-installed in relation to the belt and drum and best way to install the new belt around the drum.
  • rtp451 Nov 12, 2009
    Thank you.
    Great directions.
    Most appreciated
    Bob
  • 5,911 Answers
Replacing the dryer belt and installing the tensioner on this model dryer involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the lower toe panel by inserting a putty knife along the top seam about 2 inches in on each side. This will depress the retaining clip that holds the panel in place and the panel will open.
3. Remove the two screws that were under the lint screen and lift the top panel.
4. Unplug the door switch conector plug and any ground wire that may be installed on the front panel.
5. Locate the screws that hold the front panel in place. There should be one screw on each side in the cabinet interior and two on the lower panel in the front.
6. With the door shut, lean against the front panel and remove the screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the bottom edge of the front panel with the holes on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you still have questions, please let me know. I hope this helps you
Posted on Nov 12, 2009
Testimonial: "Excellent directions. Clear and concise. Made the repair quick and easy."
Belt drive diagram for ford rt5
Exploded view of rototiller available at New Holland website.. Area with decals has belt path diagram.
http://partstore.agriculture.newholland.com/us/parts-search.html#epc::mr55011ar111419
Belt goes around motor pulley and tiller pulley and above idler pulley, which is in the middle. When putting belt on, it is easiest to put around motor pulley first and tiller pulley (the large one) last. Belt is 3/8" x 27" v-belt. Idler pulley is available too, only under Lawn Boy part number, which is found on parts list at New Holland site. Just had to perform repair. All parts found on ebay.
Hope this helps!
Rob (Sterling Heights, MI)
Mar 21, 2013 | Garden
Replace belt diagram
If the model number you listed this question under is correct, changing the drive belt involves the following steps:
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and remove the old belt from around the drum.
If the belt has broken, this may sometimes cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model is manufactured by Whirlpool).
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also include helpful exploded view diagrams that can help you locate and properly identify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section.
NOTE: If you still have the Teflon glide type tensioner (does not have a wheel), Whirlpool recommends you replace it with a conventional roller type idler pulley. The Teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assistant may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Apr 18, 2011 | Kenmore 64742 Electric Dryer
My nephew took my dryer apart to replace the belt and cannot figure out how to re-attach the idler on the Whirlpool LER5620KQ1 model. Is there a manual available that shows exactly how to do this?
If the model number you listed this question under is correct, changing the drive belt and reinstalling the tensioner involves the following steps:
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H.
repairclinic.com
For future reference, the part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also include helpful exploded view diagrams that can help you locate and properly identify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section.
Oct 18, 2010 | Whirlpool LER5636P Electric Dryer
Replacing the belt
repairclinic.com
NOTE: If you still have the Teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The Teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Oct 06, 2010 | Whirlpool WED5300S Electric Dryer
What size is the engine on a 2002 dodge durango R/T? Need to change the surpentine belt.
4.7L or 5.9L and it should be listed on a sticker somewhere in the engine compartment.
Drive Belt Removal & Installation 3.7L, & 4.7L Engines To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Disconnect negative battery cable.
  3. Rotate tensioner until it stops.
  4. Remove belt and slowly rotate the tensioner back to its free position.
To Install:
  1. Install new belt and route around all pulleys except idler pulley.
  2. Rotate the tensioner arm until it stops.
  3. Route the belt around the idler pulley and slowly let the tensioner rotate back to its free position.
3.9L, 5.2L, & 5.9L Engines To Remove:
NOTE: Check the belt routing label, located in the engine compartment, for the most current belt routing schematic.
CAUTION
Do not attempt to check tension with a belt tension gauge on vehicles equipped with an automatic belt tensioner.
  2. Attach a socket wrench to the pulley mounting bolt of the automatic belt tensioner and rotate the tensioner assembly clockwise until tension is relieved.
  3. Remove or disconnect the following:
    • Belt from idler pulley
    • Belt from vehicle
To Install:
  1. Position drive belt over all pulleys except idler pulley.
  2. Attach a socket wrench to automatic belt tensioner and rotate the tensioner assembly clockwise.
  3. Install belt over idler pulley, allow tensioner to rotate back into place, and remove the wrench.
Sep 03, 2010 | 2002 Dodge Durango
How do you install the belt to the belt tension wheel?
If the model number you listed this question under is correct, changing the drive belt involves the following steps (skip down to step 6 for instructions on how to route the belt on the belt tensioner and motor pulley):
6. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
7. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
8. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
repairclinic.com
Aug 27, 2010 | Kenmore 74602 Gas Dryer
The tumbler does not work
Most commonly this is caused by a broken or worn dryer belt. If the model number is correct, the following steps explain how to replace the belt:
If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model Amana is manufactured by Whirlpool).
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section. The belt is listed as item 33 and the tensioner is listed as item 32.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
Aug 12, 2010 | Whirlpool LER4634J Electric Dryer
Model LE5705XPW1 replacing broken belt and have no idea of proper pulley position--any clues?
Replacing a dryer belt on the model dryer you have listed involves the following steps:
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section. The belt is listed as item 56 and the tensioner is listed as item 53.
Aug 12, 2010 | Whirlpool Dryers
Change a serpentine belt on a 97 lincoln
3.8L Engine
  1. Insert a 1/2 inch flex handle in the square hole in the tensioner. The tensioner has a square hole cast into the rear of the tensioner body directly behind the pulley. Rotate the tensioner clockwise and remove the belt from the pulleys.
NOTE As an alternate method, a 16mm socket can be placed on the tensioner pulley bolt and rotated clockwise to remove the belt.
To install:
  1. Following the schematic on the decal under the hood, loop the drive belt over all the pulleys except the alternator pulley.
  2. With the belt installed properly on all except the alternator pulley, rotate the tensioner as described above and install the belt on the alternator pulley. Ensure that all the V-grooves make proper contact with the pulleys.
4.6L Engine
WARNING Do not allow the drive belt tensioner to snap back as damage to the drive belt tensioner or personal injury could result.
  1. Rotate the drive belt tensioner clockwise with a breaker bar installed in the 3/8 inch square hole in the drive belt tensioner.
  2. Lift the drive belt over the idler pulley flange and remove the drive belt.
To install:
  1. Following the schematic on the decal under the hood, position the belt over the pulleys, except the idler pulley.
  2. Rotate the tensioner as described above and install the belt on the idler. Ensure that all the V-grooves make proper contact with the pulleys.
Apr 23, 2010 | 1997 Lincoln Continental
My Whirlpool dryer belt broke.
You should be able to reuse the idler pulley unless it is physically broken.
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
Let me know if you need more assistance.
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
