Question about HP Computers & Internet
My pc doesn't work - HP Computers & Internet
  • Jagutpal Rajcoomarsing May 11, 2010
    check the power cable what exact error r u getting??
    President:
  • 414 Answers
I gotta know 1st what is ur system configuration..is all ur system is getting power on..is there any sound coming out of the system..
assuming that the bios has not been flashed in a wrong way & u r a professional..
before u proceed to complex checkups..check the mains power supply- the fuse/switch/wirings/power cords/other associate circuits..
probably itz either minor case of loose ram/improper ground/cmos battery..
or major case of faulty or defective smps/cpu/main board short/display adapter or card/monitor
..plz do check the following as in order:..
1) in power on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..
2) if u hv a graphics card, replace with a standby or onboard and see..
3) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
4) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
5) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistace n many more..resulting an increase in heat..
6) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
7) the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
8) if itz not the smps, then it must b ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
always better to seek advise from ur system admin/vendor....
Posted on Nov 12, 2009
Acer 5349 restore doesn`t work.
Do you have a question? If you do, try giving us a clue.
Aug 21, 2013 | Acer Aspire Z5600 PC Desktop
Dell dimesion wont turn on at all
So it doesn't power up at all? I'm only asking because you said it's not the connection.
If it doesn't power up, open the box and reseat everything, something may have come loose during the move.
Sep 21, 2012 | Dell Dimension 2400 PC Desktop
My windows xp pro product key doesn't work n
doesn't work how? when installing or there's an error message?
and did you buy an original windows xp? if so,you can contact microsoft for an alternative solution
Aug 22, 2012 | Computers & Internet
Vgn-cs26g touch sensor not working
my vaio VGN-CS26G' touch sensor panel doesn't work after install Windows 7
please help the basic is Windows Vista after i change it in to Windows 7 touch sensor panel doesn't work
Aug 10, 2012 | Computers & Internet
My f10 lite is on and keyboard won't work
Unplug it and replug it, if it still doesn't work restart your computer. If it still doesn't work, it could be the keyboard, or it could be the port it's connected to.
Aug 23, 2011 | Computers & Internet
My keyboard in my laptop is not working.. please help ! it doesn't work at all even the synapse pointing device
Reference the manual on how to remove the keyboard from your computer and than reconnect the cable. If this doesn't work, than the keyboard needs to be replaced.
Jul 03, 2011 | Acer Computers & Internet
My usb port wont reginize my usb stick
try putting your USB stick in the port provided at the back side your PC !!! if it doesn't work try in your friends PC if it doesn't work there then your USB stick must have failed!!
Jun 15, 2011 | Computers & Internet
Computers & Internet Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
