Question about Samsung SGH-U700 Cellular Phone
Since my phone has been one of Vodacare as it is still under guarantee it came back with a message ''Upload data to pc''. So i sent it back again and only only worked after I have contacted their head office. It was fine for few weeks but now with its original battery inside when I charge it, it tells me the very same message. I changed the battery and have no problem. But when I put the battrey back it tells me that message again.
Where in the settings is text and subtitle font/color options?
I believe you are talking about imessage, no you can't change the color or font, you can change the text size though which is under settings, generals and text size. The color blue means it's a imessage sent using your mobile data/wifi, a green message means a traditional text message sent using your non-data mobile network
Sep 14, 2014 | Apple iPhone 4S
I CAN'T DELETE MY 6000+ MESSAGES IN MY NOKIA 5130.HOW CAN I DELETE THAT MESSAGES?
It should not happen that you are not able to delete the msgs. You can try and load all your data on a pc and then try and format the memory card. This will delete all msgs on you mobile and then you an upload the data from your pc to cell again. Hope this woks.
Else try to go to inbox and rather selcting all msgs try and delete few selected. This will be a big excercise for you although,
Let me know if the above suggestion works.
Best of luck!
Jun 09, 2011 | Nokia 5130 Cellular Phone
My phone display this message " upload data to pc"
It may be stuck in a mode where it thinks its connected to the computer. Try plugging it into one with USB and then removing it and see if the message goes away.
Mar 18, 2011 | Samsung Star GT-S5233 Cell Phone
I can't send messages with my nokia e63,i still have load.it says unable to send,General: Memory full. Close some applications and try again. i've deleted all of my inbox and sent items.no other...
with my experience this problem caused by system error, you must return your phone to factory setting, press *#7370# and insert 12345 as phone code, but before you do this back up your phone with PC suite to computer, because your phone will formated and your all data will lost, after formated connect your phone to computer then restore your back up data at computer to phone, your data will back again
i hope this helpful
thank you for using fixya
Jan 31, 2011 | Nokia E63 Cell Phone
Where on the facebook homepage is the settings button so i can send pics from my cell phone??
1. sign up for mobile facebook and enter your confirmation code. The link is on the right hand side under GET CONNECTED, last thing in the list. Connect on the go.
2. send a picture in your phone to mobile@facebook.com
3. you will be sent a text msg with a confirmation code.
4. go to facebook on your computer and go to settings.
5. go to the mobile tab
6. were it says confirmation code type in the code that was sent to your phone.
now your photo will be on facebook! the code can take awhile to be sent, but if it doesnt come soon, try sending it again.
once you confirm the first picture you send you can send more pictures without having to put in a code!
OR....
The first step is to make sure your mobile number is listed in your facebook mobile preferences under 'account' if you haven't done that already, and that it's confirmed. Also make sure you have the MMS photo/video subscription option in your plan from your provider and a data plan if you're using Facebook
Once those are set up the two ways I upload pictures are:
Option #1: Using Facebook for BlackBerry you can use the "Upload a Photo" option which also allows you to tag the photo.
Option #2: Send an MMS to mobile@facebook.com, photos@facebook.com or 32665 (I have this number in the "mobile" field for Facebook in my address book) This does in fact depend where you live... It may NOT be 32665, in your area..
You need to contact FB, to check on that fact.
Aug 20, 2010 | Computers & Internet
I cant delete my sent messages
Restore the phone back to factory setting and then try deleting it OR do a hard reset on the phone which will erase all the data on the phone!
Dec 31, 2008 | LG VOYAGER VX10000 Cellular Phone
I have a received file on my Nokia 5310, that I would like to load onto my pc. The problem is that I am being sent a message that the file is too large, to send. The message says the maximum message size...
Your best bet is to use the USB cable to upload it to your PC. When you plug the cable to the phone, it should prompt for either Data Storage, PC suite or Music Sync.
If the file you want is on the phone memory, copy it to the memory card.
Then, on your phone, go to Menu, Settings, Connectivity, USB, select Data Storage.
Connect your phone to the PC. Then, go to "My Computer", click on the one that says "removable memory or removable device"....
Go to the folder in which the file is stored. click and drag to your desktop and its done!!
Dec 10, 2008 | Nokia 5310 Cellular Phone
K850i wont turn on/off
i sent it back for repair under the guarantee
Feb 27, 2008 | Sony Ericsson K800i Cellular Phone
Samsung SGH-U700 Cellular Phone Logo
49 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
