Question about KitchenAid KGSS907SSS Gas Kitchen Range
Oven not sparking to ignite burner - KitchenAid KGSS907SSS Gas Kitchen Range
  • KitchenAid Master
  • 43,501 Answers
Many of the ovens do not spark but instead have a hot surface ignitor that will get very hot to light the burner. If it is not getting hot then it probably needs to be replaced.
Posted on Nov 12, 2009
5 Suggested Answers
  • 530 Answers
SOURCE: Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Posted on Jan 04, 2009
garing
  • 998 Answers
SOURCE: Whirlpool GS465 stove top burners won't ignite
adjust air hoods
thumbs up
Posted on Aug 17, 2009
SOURCE: Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
Posted on Dec 24, 2009
  • 1531 Answers
SOURCE: Igniter in oven will try to ignite. Hear gas flow.
the ignitor may be faulty and not pulling enough power to keep the as valve open in order to light them oven, even though it is getting red or glowing the power is not enough.try and replace the ignitor
Posted on Jan 24, 2010
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Oven will not come on
Does your clock work? This sounds like either a lack of voltage to the oven igniter, or a failed spark igniter or both. Your oven igniter is the easiest to check. With broiler door open or the plate above your oven burner removed, turn your oven on and look for a red to white glow near your ovens burner. This is a ceramic glow plug, and it will not allow gas to leave your manifold until the igniter has reached the proper temperature. If there is no glow, then your igniter has failed and needs to be replaced. The spark module that clicks as you turn your burner has obviously either died, or there isn't enough voltage being supplied to allow it to start up. Unplug your 110v wire from the stove and try a hair dryer or other 110v appliance at the wall outlet to determine if you have proper voltage there.
The worst case scenario is that both your oven igniter and spark module have died, which is rare unless you have had a power surge or lightning strike near the power transformer to your house.
The cheapest way to test this is to buy the oven igniter first, since they are far cheaper than the spark module. If the new igniter lights up, then you can be pretty sure it isn't your power outlet, and can safely move on to the spark module.
Mar 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Whirlpool 465. The top range burners will not ignite. I can hear and smell the gas. The oven burner works fine. Do I need to replace an ignitor for the range?
    The bake is seperate from the burner ignition system. You may need a new spark module for the top burners. All burners should spark at the same time even if you are only trying to lite one burner.
    Aug 27, 2009 | Ovens
    One or more igniters are trying to light burners that aren't turned on .One burner is on. The other post on this never got answered properly.
    When you turn the burner dial, all igniters spark. Most brands work this way. The dial activates all igniters to spark but only opens the gas valve attached to that dial.
    Do you mean that they continue to spark even when you are not trying to light the stove?
    Jul 28, 2009 | Jenn-Air JJW8530C Expressions Collection...
    My tappan oven will not always light
    for the top burners you have to get to see the ignitors so that you can see the spark,the spark have to spark like a spark plug in the car, it most be on the tip of the ignitor.if not. the spark it's sparking on the wroung spot,wires may be wet or broken. thats one of the reason, the second one,there is small holes fasing the spark ignition on the burners when grease blocks them, they will not light, you can clean them with a paper clip or a safety pin. for the oven,some ovens do not have the spark sistem, they have the ignitor wich it looks like a small bar about 4 inches long by 1 inch some of them are round. thats the part that needs replacing
    Dec 06, 2008 | Kitchen Ranges
    Oven will not light
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
    Nov 20, 2008 | Frigidaire Ovens
    Electrical ignition is not working, no clicking and no spark for the burners. Also oven isn't working as well
    Try resetting the circuit breaker, if all burners are not sparking sounds like an eletrical problem or improper voltage to the range.
    Jul 28, 2008 | Viking Kitchen Ranges
    KitchenAid KGSS907SSS Gas Kitchen Range Logo
    237 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Colin Stickland
    Colin Stickland
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
