Question about HP Pavillion s7420n PC Desktop
Once i start uploading the orperting system,after a few minutes,it says the file vga. sys is corrupt.
    President:
  • 414 Answers
This is a case of os corruption somehow..!!..may b a virus/trojan or hardware or software is responsible..
all u need is the os boot cd anyway..
probably now u got two way out:
goto some cyber n download win xp pro sp2, using any bit-torrent client(like utorrent) from torrent site (eg. mininova.org so on)..make a boot disk n try..
1) copy the file in windows repair mode or from any identical os n put it in place as stated above..
OR 2) reinstall os..
(to take data backups u gotta connect the hdd to another pc/laptop, for such cases a hdd-case is available in the local spare market, it'll make behave ur hdd to act as an external removable drive)..
this can also b a symptom of faulty/defective of RAM..pen clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..[it'll b more prominent, that if itz cause by ram or not,..if during normal operation, a Blue Screen appears/Memory Dump]
though, sometimes itz also caused by the m/b..
there are also exceptions, where it is found that any hardware component on the system is loose or incompatible (see addon cards, the ram(s),the hdd (if itz making any 'ticking' noise like 'kirr kirr' or 'tuc tuc'), all data cables n power cords, may b dusty, cpu overheating,see filter/power/south bridge/crystal clock generator section of m/b esp mosfets and capacitors..etc)..
if once u can login, do the following:
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, , without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessarystartup items from here..(if u can't find what to remove,post me/us inur comment with all the items listed in each n every tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disable the following: a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart; b)'Error Reporting 'right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
always better to seek professional advice of ur system admin/vendor...
Posted on Nov 12, 2009
    Master:
    Sergeant:
  • 381 Answers
Try re-installing the drivers for the vga?
or take out the VGA card (thats if its not built on to the motherboard)
or repair the the o/s using the system cd
Corrupt rar/winrar Archive
Maybe is uploading to the FTP site using ascii transfer type, once on the FTP connections, you should use binary type.
that is done with the command bin:
The following FTP Command will set the file transfer mode to BINARY (the binary mode transfers all eight bits per byte and must be used to transfer non-ASCII files). ) and display the information.
ftp> binary 200 Type set to I. ftp
May 06, 2015 | RARLAB WinRAR
My daughters Asus eee pc MK90H notebook says windows could not start because system 32 is missing or corrupt. It says to use the original CD Rom, which obviously we dont have. Help what do we do?
To restore a missing or corrupt ntfs.sys file you must have the Windows XP CD and follow the below steps.
Insert the Windows XP CD into the computer and restart the computer.
As the computer is starting make sure to press a key to boot from the CD.
In the Windows XP setup screen press the 'R' key to run the Windows Recovery Console.
If prompted enter the number of Windows installation you're repairing.
At the command prompt type the below command.
copy x:\i386\ntfs.sys c:\windows\system32\drivers
* In the above example you would replace x: with the letter of your CD-ROM drive. Many computers have the CD-ROM drive configured as the D: drive.
If ntfs.sys is still on the computer you'll be prompted if you wish to overwrite the file. If prompted, press the Y key for Yes to overwrite the file.
Once the file has been successfully copied remove the CD and reboot your computer.
Do NOT use an OEM "Recovery Disc". Only a valid Windows XP media will work or a disc from the OEM that says "Operating System" may sometimes work depending on how the manufacturer labeled the CD.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | ASUS Eee PC 1000HE Netbook
What can I do other then the reboot CDs for a corrupt system file
Its means " setupdd.sys" is not present on your system. May be corrupted by virus or by mistake its deleted. Batter you repair your OS.
Thanks.
Feb 02, 2010 | Acer Aspire 5670 Notebook
I am having trouble running setup on my desktop
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
System32/DRIVERS/pci.sys
ITS EASY JUST COPY THE FILE pci.sys from any other computer from System32/DRIVERS/pci.sys .SOUNDS FUN?BUT I KNOW IT WORKS
Mar 27, 2009 | Computers & Internet
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Video Drivers
The file “Windows/System/Drivers/mup.sys” is not actually causing the problem. It’s the next step after mup.sys that’s causing the computer to hang. That next step consists of the OS checking the registry files for plug and play devices.
Some causes are: new or defective hardware installed, corrupted registry, (caused by virus), defective or corrupted hard drive, just to name a few.
Try removing all devices attached to the computer like printer, web cam, flash drives, etc.
If your computer has a PCI or AGP graphics card AND your motherbrd has a VGA connector, remove the video card and use the one on the motherbrd.
If the above doesn’t work, try running “CHKDSK /P” from the Windows recovery console.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 18, 2008 | Dell OptiPlex GX260 PC Desktop
File System Error?!
I have the 4GB version (non-FM) and it's having the same issues. I reformatted mine to the NTFS filing system in hopes of uploading my songs faster since these players run on FAT32, but reformatting it to any file system other than FAT32 will cause it to give a File System Err notice on your player. I would suggest reformatting it to FAT32 using your computer. There are resources available everywhere online that shows you how to do this.
Mar 02, 2008 | Coby MPC895 MP3 Player
System32.ntfs is missing and corrupt
Boot into recovery console, and at the c:\windows prompt type: cd system32 cd drivers ren ntfs.sys ntfs.old If the ntfs.sys file is there and corrupt this will rename it. If it is not there, then it was missing. At the prompt type: copy e:\i386\ntfs.sys c:\windows\system32\drivers\ntfs.sys good luck
Mar 19, 2006 | Apple Power Supply 344 Watt PowerMac G4...
HP Pavillion s7420n  PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
