Question about Sony Ericsson W910i Cellular Phone
My w910a keeps turning its self off and i have lost all display
My visionquest 47 inch Rembrandt tv keeps displaying "lost database" when turned on
Contact the authorized service center. It sounds like a corrupted firmware. Firmware update might be necessary. Gopakumar Gopalan Google
Feb 03, 2015 | Televison & Video
Directions on how to use the self-cleaning feature of my Kenmore Ultra Bake Self Cleaning Super Capacity oven
First take out the racks (unless they are coated with the same porcelan coating as the oven interior). Press the Clean or Self-Clean button. Press up or down arrow key - 3:30 will show in display which represent time in hours and minutes. You can press the up arrow key for more time, or the down arrow key for less time, but usually the default time is good. Then just press Start. The door will lock and the oven will turn on. In 3 1/2 hours the oven will turn off, but the door won't unlock for another hour.
Sep 09, 2014 | Kenmore Kitchen Ranges
Inverter manuals
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
Oct 12, 2013 | Sharp Heating & Cooling
How to reset passbook printer ibm 9068
When you turn on the power, the microcode version and then the release level of the microcode are presented on the LED display, and the device runs the basic assurance test and then resets the hardware.
If you need configuration changes done such as how the printer communicates and such, then you need to know all the functions and codes for configuration changes.
The self-test runs only in the self-test state. To place the printer in this state and start the self test:
1. Make sure the printer is turned off.
2. Press and hold either Start 1 or Start 2 on the operator panel; then turn on the printer. Keep holding the button at least until "00" is displayed on the LED.
Note: The left 0 blinks, and the right 0 stays on.
3. When 00 appears on the LED, the self-test "00" is ready to run. Insert an 8.5x11 Letter sized piece of paper into printer.
4. Press Start 2 to run the self-test "00". This will print the Configuration of your printer.
Feb 28, 2013 | IBM 9068 A01 Passbook Business Printer...
My hard drive fails and it wont boot. What is the best solution to it?
If its a HP notebook then perform the har drive self test.
Here are the steps below.
Steps for HDD self test.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If the hard drive fails then surely there is no option other than replacing it....
Please surely buy HP Hard drive.
Jun 14, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Oven self-clean won't turn off!!
You will need to press the stop/cancel button, this will clear the cleaning cycle, due to the interruption. If this does not clear the display you will need to unplug the stove for five minutes and then plug it back in and this should clear the display.
Nov 14, 2009 | GE Ovens
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven
Unplug the power cord for few minutes. then plug it back to see if the light still keep coming.
then do this:
Check if you have it in the lock mode.
Press bake and broil pads together for 2 to 3 seconds until SF shows in the display.
Press the self clean pad, display will show loc off or loc on.
Let me know if it clear the fault.
Good luck from : Prince P
Jul 25, 2008 | Kitchen Ranges
Stove manuals for Crosley Electric Stoves
how do I operate the self cleaning function on my stove model
cs37500-1
Nov 12, 2007 | Crosley CE35100AA Electric Kitchen Range
Sony Ericsson W910i Cellular Phone Logo
81 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
