Question about JVC TH-C60 System
When system is turned on, the subwoofer light comes on and then goes out.
This just started to happen. There is no sound from the speakers. Turn system off and back on and the same thing occurs.
Thanks for your support.
  • 3 more comments
  • Steve B Jan 08, 2008
    I took the amp out and nothing looks burnt or broken that I can see.
    I checked the power plug and put it in another outlet. I also looked at the S cable at both ends that runs from the reciever to the powered subwoofer and no pins are bent. The cables were not touched between the unit working and not working.
    Hello!!!
    I have checked the DIN cable and all pins have continuity including the power cord.
    When I power up my JVC TH-C60, the powered subwoofer lights up for about a second and then the light goes out slowly.
    I have checked the DIN cable and the power cord and both have continuity between their pins.
    Thanks for your help.
    Thanks Paul. Overheating is not the problem so I believe you are correct that a resistor is bad.
    I will let you know what I find.
    Appreciate
  • 4,102 Answers
Hi it sounds like the power is being interupted and the unit is shutting down.
You will need to check all resistors near amp check for swelling or signs of over heating. it is difficult to get schematics for these as i had friend with one and we looked everywhere for the schematics and couldnt source them.
The chances are its going to be a resistor or if lucky a solder problem witch will require resoldering this is less likely as it shuts down almost imediately so i would look at all resistors and replace as necesarry but without sourcing schematics its difficult to trace the resistors in order as to eliminate them in the right order.
Ill have another look maybe somebody has sourced one by now but just check all resistors for signs of swelling or discolour you might find it could be a couple gone let me know how you get on ok
Posted on Jan 08, 2008
  • paul proctor Jan 08, 2008
    Hi forgot to ask is it just the sub that shuts down as usually this is sign of overheating.
    so check all air vents are free from dust and also remember that if the unit is ontop of another piece of equipment then this will cause it to overheat as they should not be placed on top of any other units.
    If over heatings the problem then this could be expensive to fix as you could end costing as much as replacing let me know how you get on ok.
    If the leads havnt been moved unplugged or knocked about before you got the problem then you no its not the leads so dont go that route unless someone has messed with them.
  • 790 Answers
Hello!!!
Just check out the cables connected to the woofer first... Guess its an electronic issue ..
  • Kanth raj
    Kanth raj Jan 08, 2008
    Guess its a faulty cable .. it may work fine if the connecting cables replaced ...
Sound comes out of the right speaker with the z4 volume set at minimum. however the sound can be controlled by the windows volume control. When you turn up the volume on the z4 the left speaker works....
open your subwoofer because main system is inside in your subwoofer than clean it with a air blower ..
this happens when dust is inside the system....
Dec 26, 2010 | Logitech Z4 Speakers
Dear Sir, I hav dell vostro 1015 laptop with windows Xp Operating system. I have purchased 4.1 subwoofer system. When i am connecting subwoofer to pc audio output & all 4 speakers to back of...
Recheck your wiring and instructions. If your woofer is self powered perhaps the amp is no good. Actually it better have amps since the laptop output will not power those speakers.
Mar 31, 2017 | Computers & Internet
Creative Inspire 5200 system won't work
Hi. Check your speaker system with a different audio device like iPod or any MP3 Player using the same jacks. If the speaker system gives out sounds then nothing is wrong with it... if no sounds come out, then you know what I mean...
Try to replace the speaker of your sub-woofer... maybe that can fix it!
^_^
Jun 06, 2010 | Creative Labs Inspire 5200 Computer...
Faulty sound on Panasonic home cinema system
If you can leave off the subwoofer (disconect it) and the sound distorts you know it's the amp.
In either case you are looking at a transistor or IC that has a heat problem. You can find out which by spraying with Servisol Freezer spray on to a suspect device, when the distortion is there. If it goes away when the suspect is cooled, then it's gone. To confirm it heat it back up with a soldering iron, it should then start acting up again.
You should be able to get the spray from Maplin (UK) or Radioshack (USA), or that type of shop.
Nov 29, 2009 | Panasonic SB-WA100 Subwoofer
No sound from Sony SA2500 subwoofer
Please intimate exact model number written on sticker pasted at back of Sony subwoofer to provide you help.
Aug 01, 2009 | Sony SA-WX700 Subwoofer
Power is on ,but no light on the radio or sound
It would help to know specifics like models and if they ever worked correctly.
How long and how loudly are you playing it before all this happens?
Does the receiver feel unusually warm when it dies? If so, is there proper ventilation around the unit so it can cool itself?
What light on the radio goes off?
What light on the subwoofer are we talking about? Do you know what it means? It could be telling us that it has lost signal, not surprising if the receiver quits.
Better clues will lead to better answers.
Apr 24, 2009 | Audio Players & Recorders
Red light comes on and then slowly goes out. No output
For some reason you are not getting constant power to the system. What gauge power/ground are you running? Describe your system to me and we'll see what I can do to help.
Jul 16, 2008 | Infinity BASSLINK Car Subwoofer
Subwoofer goes to sleep
The receiver automatic speaker set-up set the sub volume at -12 and since it was not getting any signals from the receiver it was doing what it is supposed to be doing (going to the standby mode). This was troubleshooted by Onkyo tech support on a Sunday. All the best about Onkyo customer support.
Apr 12, 2008 | Audio Players & Recorders
Power issues: will not turn off or function
Unplug all of the speakers and power on.Its possible that one of the speakers is causing the protection circuit to activate.If powered on and subwoofer works start reconnecting one speaker at a time( after powered off) and retest each time.One Speaker may be bad.Its also possible the output ic is failing under a speaker load.There are no fuses related to this issue.If its not a speaker problem then the subwoofer will need to be serviced.
Feb 24, 2008 | Panasonic SC-HT730 System
Can't get sound from the wireless subwoofer
There are 2 things you can try, first ensure that the digital transmitter is fully inserted into the slot of the main unit. Secondly do you have any other wireless devices near such as cordless phone or wireless network equipment? See page 5 of the installation manual as per this picture.......
Jul 25, 2007 | Panasonic SC-PT1050 System
JVC TH-C60 System Logo
172 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
