Question about Abit BD7II-RAID Motherboard
I lost my abit bd711 manual. - Abit BD7II-RAID Motherboard
  • Jagutpal Rajcoomarsing May 11, 2010
    you need manual for what things to verify?..
  • 535 Answers
Can specify your mother bord full model no
Posted on Nov 12, 2009
3 Suggested Answers
Semi-Driver
  • 434 Answers
SOURCE: AJ LOV INSTALING DRIVER...ABIT BD711 PENTIUM
Please be careful to download the correct driver(s) for your operating system:
Abit BD7II Downloads
Posted on Jan 25, 2010
map9966
  • 2351 Answers
SOURCE: have an abit bd711. when I start up the computer i
You're Abit BD7II-RAID MB has many bios settings that could bring about the sound you are hearing.
See page 3-23 in you're manual. (Resume by Alarm)
Most of the settings on page 3-23 are used for power savings. Also see page 2-10 section (13). U27: POST Code Display. When you hear the alarm tone check the MB's display U27 for it's code.
I'll post a site where you can download a small program called Speccy that can monitor the temps in you're system; http://www.piriform.com/speccy/download
This can help if there is a heat problem with a device within you're system. At this time I don't feel you have a CPU problem.
Mike
Posted on Jun 04, 2010
How to connect 2 cd-roms to motheroard
If they use the wide ribbon cable, you need the cables with two connectors. Then set on drive to master and one to slave, or set both to CS - for cable select. When you restart the computer, the OS will do the rest.
Feb 23, 2015 | Abit Computers & Internet
ABIT-BD711
Okay,.......that was DU-MB!
Lemme see,.......oh yeah!
Letters and words! !O_O!
(Wondered where my glasses were!)
http://images.search.yahoo.com/images/view;_ylt=A2KJkCAV3j9QW2cAUAOJzbkF;_ylu=X3oDMTBlMTQ4cGxyBHNlYwNzcgRzbGsDaW1n?back=http%3A%2F%2Fimages.search.yahoo.com%2Fsearch%2Fimages%3Fp%3Dabit%2Bbd711%26fr%3Dmoz35%26fr2%3Dpiv-web%26tab%3Dorganic%26ri%3D2&w=600&h=444&imgurl=www.ixbt.com%2Fmainboard%2Fimages%2Froundup-i845e%2Fbd7ii-raid-board.jpg&rurl=http%3A%2F%2Fixbtlabs.com%2Farticles2%2Froundupmobo%2Fabit-bd7ii-raid-i845e.html&size=111.5+KB&name=Abit+BD7II-RAID+%28i845E%29+Mainboard&p=abit+bd711&oid=14ba8ece461cfe2b401fe4f974d4c0b7&fr2=piv-web&fr=moz35&tt=Abit%2BBD7II-RAID%2B%2528i845E%2529%2BMainboard&b=0&ni=56&no=2&ts=&tab=organic&sigr=124cn6s7j&sigb=12vbgaaru&sigi=120054ob4&.crumb=J6iwC7bwOtM
Motherboard photo, and detailed info below it. Scroll down.
Looking at the motherboard installed in the computer case:
1) To the right of the Ram Memory slots, and in the upper right corner, is the 20-pin ATX main power cable connector, on the motherboard.
Whitish connector with two columns of 10 socket holes.
A 20-pin ATX main power cable plugs in here,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note the Lock on the side of the power cable's connector, (Middle photo, and right photo), and the Tab on the motherboard connector, (Left photo)
When the power cable is plugged in correctly, the hooked end of the Lock on the power cable's connector, will be hooked over the Tab on the motherboard connector.
2) Look at the bottom Left corner of the Processor socket. Note the three cylindrical objects. (Radial Aluminum Electrolytic Capacitors)
Note the whitish square 4-socket hole connector below them.
This is where the 4-pin ATX +12 Volt power cable goes. It also has a Lock, just like the 20-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This is power for your Intel Pentium 4 processor.
3) To the Right of the Ram Memory slots, and located below the whitish 20-pin ATX main power cable connector, are the two IDE connectors. (Turquoise Blue)
One is for an IDE (PATA) harddrive, and one is for an IDE(PATA) optical drive. (CD/DVD drive)
The one on the outside near the edge of the motherboard, has IDE1 next to it.
It is for the Harddrive.
The one closer to the middle of the motherboard is IDE2.
It is for the optical drive. (Or drives { 2 } )
NOTE*
One side of those rectangular connectors has a cutout in the middle.
(Square U-shape cutout)
This is where the Locating Lug, on the flat ribbon IDE cable's connector, goes to.
It aligns Number 1 pin in the connector, with Number 1 wire, in the flat ribbon IDE cable.
IF, there is NO Locating Lug on the flat ribbon IDE cable;
On one side of the flat ribbon IDE cable is a thin RED stripe.
This stripe denotes the side that Number 1 wire is on,
http://en.wikipedia.org/wiki/File:Nappe.svg
Looking at the rectangular IDE1 and IDE2 connectors, Number 1 pin is at the BOTTOM of those connectors.
(Motherboard installed in computer case)
On an IDE harddrive, Number 1 pin is ALWAYS towards the 4-pin power connector.
Same with an optical drive.
4) Since this is a motherboard, that has a RAID option for using multiple harddrives, I'm guessing the two Yellow rectangular connectors, below the two rectangular Turquoise Blue IDE connectors, is for more IDE harddrives.
http://en.wikipedia.org/wiki/RAID
5) Below the two Yellow IDE harddrive connectors is a Black rectangular connector.
This has 34 pins, and is for a Floppy Drive, IF a Floppy drive is used.
6) Below the Black Floppy Drive connector on the motherboard, is the Front Panel header.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
What is needed here is a Front Panel header pinout.
Dunno. Photo isn't clear enough.
Looks like a Black rectangular strip of plastic, with 8 pins in a row.
4 pins, 3 spaces, 1 pin, 1 space, 3 pins.
Looking closely, (And you may need a bright light, and a magnifying glass), what are the abbreviations next to the pins, on the outside edge of the motherboard?
HDD = HarDDrive activity LED (Light)
PW = Power On switch
RST = Reset switch
PWLED, or close to that effect = Power On LED.
Post back in a Comment.
IF, it is just a row of single pins going across, I would use an LED light that has two wires on it.
Computer, (Power Supply actually), plugged into power, touch the two wires to the first two pins.
Nothing?
Go on.
When the Power Supply comes on you know you have the Power On switch pins (2)
Now go back through, but do not touch those pins again.
LED light blinks? = HarDDrive activity LED (Light)
LED light stays on? = Power On LED (Light)
Computer restarts? = Restart switch pins
7) To the left of the white long PCI slots, (There are 5 towards the bottom of the motherboard), are two small Black rectangular connectors. Each has 4 pins in it.
The one that has Audio, or CD, or CD-IN, is for the audio cable from the CD/DVD drive.
8) At the Top of the motherboard in-between the Processor socket, and black Ram Memory slots, is an Orangish connector with 3 pins. Should have CPU, or CPU_FAN next to it. This is where the Processor fan plugs in.
9) At the bottom/left, and below the two small black connectors with 4 pins in them, is an Orangish connector with 3 pins.
This should be for the computer case fan.
(SYS_FAN)
Additionally you may want to join this website, and ask them for the Front Panel header pinout, for your Abit BD711 motherboard,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
Finding information for an ABIT BD711 motherboard, is about as rare as finding hen's teeth.
I, and I'm sure 100's of people, would be in your debt, if you would post the Front panel header pinout for this motherboard.
Hope I have redeemed myself for the S.N.A.F.U. of the question asked in the Comment, lol!
Regards,
joecoolvette
Aug 30, 2012 | Computers & Internet
Have an abit bd711. when I start up the computer i sometimes get an alarm tone, and other times I do not. Not sure what it means.
Mike
Jun 04, 2010 | Abit BD7II-RAID Motherboard
AJ LOV INSTALING DRIVER...ABIT BD711 PENTIUM 4(478)/845E FREE
Jan 25, 2010 | ASUS Computers & Internet
Abit VA20 Motherboard
You can download your drivers and manual from Abit using the link below.
Click Here
Feb 23, 2009 | Abit VA-10 Motherboard
I lost my Motherbord driver CD...
http://www.abit.com.tw/page/en/download/download_driver.php?pFUN_KEY=9000&pTITLE_IMG=/download/images/download.gif
Sep 27, 2008 | Abit BL7-RAID Motherboard
Multimedia audio controller
Brain its sure that you have missing driver for your audio system and you must have to re-install it.
But before installation you need the right driver for your device.
And to search the right driver for your device you must know your device manufacturer and device model no.
So, just get your manufacturer site, make a search for your device model on that site, and download your driver.
For your help here is the link for ABIT
Goto this page, select your region/country and download your driver.
Thanks
Iqbal
Mar 23, 2008 | Edirol UA-4FX External Sound System
Lost my user's manual
i get a new link from shuttle direct.
hier das manual:
http://download.shuttle.eu/Archive/Manuals/en/mk40v_n/
und die Treiber:
http://download.shuttle.eu/Downloads/Mainboard/MK40V-N/
Nov 14, 2007 | Abit ST6 Motherboard
Abit BD7II-RAID Motherboard Logo
942 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
