Question about Samsung Jet S8000 Cell Phone
Whenever i go to open a picture it says not enough resources please close other applications to continue but i dont have anything else open so what do i do to fix it ?
I have a Samsung Duos B7722 and I have a problem with a message that appears whenever I open pictures. The message is as follows: "Not Enough Resources. Close some applications and try again."...
it may solve through widget setting just remove some widgets from the widget tab on the screen 1 of ur duos phn and it can be done in the just go in display and light setting in the phone stteing menu thn widget n thn jus unmark the not reqired widget its like Setting>display and light>widget>unmark unnessary widget.....thts it hopefully it will work jus try......
Jul 29, 2011 | Cell Phones
Hiii first of all i waant to thank you for the tips/solutions. I am using samsung jet. when ever i open any application , i get a error message "not enough resources close some...
May be there are some open applications in the background.Close it all if unnecessary, and try opening the desired application. Free up phone memory by moving data to a memory card.
Mar 04, 2011 | Samsung Jet S8000 Cell Phone
Whenever I open any application (message, my file etc) it keeps on saying not enough resources close some application
Are you using..a.. the original memory on the phone or..b.. have you installed extra memory?
If ...a.....you have too many apps and stored music ,vids, pictures for the machine to use any other resources.You need to upgrade by buying more memory that will normally just plug in to the phone in a slot similar to when you plug in when charging.
If..b... You need to check in SETTINGS on your phone that all your saved apps vids etc are saved onto this memory card because you may still have it stored on the phone original memory still and the extra storage is still not being used. Easy to move= click on options in your saved items and move to memory card,then go check it has now moved from old place and now in new memory card where you can use it when needed and now you should have freed up the phone memory which the phone uses to open your programs etc. ... OK a bit long..sorry.
Steve B hope this helps
Feb 01, 2011 | Samsung Jet S8000 Cell Phone
Whenever i open an application...it says" not enough resources.close some applications and try again"..even when there is no application running.
Delete all the messags or format the cell udsing code
*2767*2878#, then it automatically restarts , wait for some time
May 21, 2010 | Samsung Jet S8000 Cell Phone
Not enough resources - Samsung Jet
I just restarted the phone and it worked again. Simple as that
Jul 08, 2009 | Samsung Cell Phones
Whenever I play games, my game and system hangs..
Why dont you try to uninstall some application or gamesyou are not playing this will help increase the memory resources of your system, or upgrade your memory
Sep 19, 2008 | XFX GeForce FX 5200, Graphic Card
Mapking R12
reinstall the mapking application.
kill other process using the task manager
Mapking is a huge software and willconsume a lots of resources including the dreadful battery
Aug 22, 2008 | HTC P3300 Smartphone
Samsung Jet S8000  Cell Phone Logo
255 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
