Question about Compaq /HP 9010C 2.4GHZ 256MB 30GB DVD NIC 56K 14.1 WXP (DS983CABA) PC Notebook
My laptop wont exit safe mode even when pressing f8 key. Also windows is failing to boot from safe mode so I need to exit this. I cannot reset to original factory conditions to solve the problem either. What other options are there?
  • Amruth Louis May 11, 2010
    You dont want to resort to Factory Restore or that you cant do that because of some issues?
    President:
  • 414 Answers
This is a case of os corruption somehow..!!..may b a virus/trojan or hardware or software is responsible..
all u need is the os boot cd anyway..
probably now u got two way out:
goto somecyber n download win xp pro sp2, using any bit-torrentclient(like utorrent) from torrent site (eg. mininova.org so on)..make aboot disk n try..
1) copy the file in windows repair mode or from any identical os n put it in place as stated above..
OR 2) reinstall os..
(to takedata backups u gotta connect the hdd to another pc/laptop, forsuch cases a hdd-case is available in the local spare market, it'llmake behave ur hdd to act as an external removable drive)..
thiscan also b a symptom of faulty/defective of RAM..pen clean/removecarbon& or oxide formed on the teeth with an eraser n resitit..[it'll b more prominent, that if itz cause by ram or not,..if duringnormal operation, a Blue Screen appears/Memory Dump]
though, sometimes itz also caused by the m/b..
there are also exceptions, where it is found that any hardware componenton the system is loose or incompatible (see addon cards, the ram(s),the hdd (if itz making any 'ticking' noise like 'kirr kirr' or 'tuc tuc'), all data cables n power cords, may b dusty, cpu overheating,see filter/power/south bridge/crystal clock generator section of m/besp mosfets and capacitors..etc)..
if once u can login, do the following:
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, , without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessarystartup items from here..(if u can't find what to remove,post me/us inur comment with all the items listed in each n every tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disablethe following: a) 'Automatically Restart' right click on mycomputer->properties->advanced->startup n recovery->(uncheckon the) Automatically Restart; b)'Error Reporting 'right click on mycomputer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when critical erroroccur'..
Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
always better to seek professional advice of ur system admin/vendor....
Posted on Nov 12, 2009
    President:
  • 1,865 Answers
If you do not need to save the data on the computer, you can write zeros to the harddrive disk (HDD) using software from the HDD manufacturer. THen partition and format the HDD with your XP cd, and reinstall XP.
What do I need to do safe mode?
for windows 98 /xp/ 200 or win7 you can press F8 and select safe mode by pressing arrow keys.and select enter key or direct press F5 key.
if not work try pressing FN + F8
but for win 8 /8.1 or windows 10 please follow steps
http://www.digitalcitizen.life/5-ways-boot-safe-mode-windows-8-windows-81
Nov 16, 2016 | Computers & Internet
Hiw do reset my Sylvania tab N77C when it stops at boot and It cant open the recovery mode
Right after you press the power on button begin pressing the F8 key. This will open a screen where you can select "Safe Mode", then hit the Enter key on your keyboard. Wait for Safe Mode to boot up (may take a minute or so). Then try opening Recovery mode or System Restore. Failing this, insert your Windows installation disk or Windows emergency repair/boot disk and follow instructions to access Recovery Mode.
Nov 21, 2014 | Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Wont boot up after an improper shut down, how can i make it boot up?
Try tapping F8 while booting and go to boot with "last know good configuration" if that doesn't work hit f8 again while booting and go to "safe mode" and do a system restore :) hope this helps thanks
Dec 30, 2010 | Acer Aspire One 10.1" Netbook Computer -...
Starts up fine, gets to win xp loading screen and then goes black, i cannot get into windows, plz help
For that when you power up the computer press F8 key then if you are able to see safe mode and other menu then enter in enable vga mode.
Then go to start menu then control panel ->dispaly ->settings.
Also make sure that graphic driver installed and working fine.
change screen resolution to 1024*768 then apply and ok.
then check in normally.
But if you are not able to see even safe mode then you need recovery disk or windows disk.
Boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot menu then set first boot device as cd/dvd rom .then save and exit.
Thern it boot with disk.
Then follow the procedure and repair your previous windows.
Let me kno wif you need further assistance.
Nov 10, 2009 | MSI K9MM-V Motherboard
LAPTOP IS ON SAFE MODE AND I DO NOT KNOW HOW TO GET IT OFF SAFE M
when switching on your laptop please tap F8 key continuously and it should take you to the boot options
Sep 10, 2009 | HP Pavilion dv9000z Notebook
My Acer Aspire 6930 wont boot past the microsoft corporation screen. The computer wont even boot in safe mode. Are there any solutions for this?
Try system restore. During the boot sequence press F11 and follow the instructions. If it fails, try with your installation disk.
Aug 25, 2009 | Acer Aspire 6930-6455 Notebook PC
Dell optiplex 760 won't go into safe mode
It sounds as though your PF keys are disabled by the BIOS settings. Try this:
Upon cold start or reboot get to the BIOS setup. You may have to press F2 or delete, or whatever key the first POST messages instruct you to use. Different BIOS manufacturers use different keys, and you have to be quick to interrupt the boot process using the correct key. If you fail to determine what key it is, reboot once again, until you see/read what key does the job.
Next, once you're into the setup screens, look for a section where you can set/deny access to the F8, F9, F10 etc keys during the boot process.
Make sure you ENABLE them, following the instructions on what keys to use to set/reset these choices. Make sure you SAVE AND EXIT.
On the next reboot, upon the disappearance of all POST messages, make sure you press the F8 key repeatedly until you see your OS boot options menu, among which you'll find Safe Mode.
Aug 24, 2009 | Computers & Internet
My laptop won't boot up
Go into the BIOS and reset defaults and save the changes and exit.
If it still doesn't boot up then try pressing F8 to get to the boot menu and choose safe mode. If you can get into safe mode then restore your laptop back to the last date it was working properly.
If that doesn't work or you can't get into safe mode then the operating system is corrupt and you would have to restore your laptop back to factory defaults.
If you try that and the laptop is not allowing you to restore your laptop back to factory defaults then the hard drive is bad and would need to be replaced.
Aug 16, 2009 | Compaq Computers & Internet
Computers & Internet Logo
177 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
