Question about Keurig B60 Coffee Maker
Hot water does not go through the individual cup of dry coffee. Pours out and around top into cup placed for finished coffee. Had spongey black rubber gasket which deteriorated and was sent a different type which seems to be too small (Soft nylon type) Machine is a Keurig coffee individual cup maker. Thanx, Sandy
  • Anonymous Mar 16, 2014
    the motor seems to stop before releasing coffee into cup
  • 460 Answers
Check to see if the outlet hole is plugged up and use a tooth pik to clean it out then try bo brew again..
Posted on Nov 12, 2009
Why did the coffee maker leak bad and now just quit wont gety hot
You seem to be saying the unit "leaked: really badly getting water all over; and now the hot plate will not heat up. Such "leaks" are usually caused when the basket is not pushed in correctly so that the water cutoff switch remains closed when it should be open. (The water cutoff valve is what allows you to remove the pot/carafe in order to pour a quick cup even while the coffee is still drip brewing.) If that cutoff vvalve remains closed for more than a minute or so, or less, water will overlow the basket because with its path out the bottom and into the pot is blocked' and it has not place else to go but over the top of the filter basket holder. Now, when such an overlfow (not leak) happens, there is the hot plate right below into which the overflow flows down. As long at it remains wet it will be short circuited and not heat up. So let stand and/or blow or hairdryer heat to remove all water (be sure to unplug coffee maker to to that). Now, once everything including the hot plate are dry, the coffee maker will either work fine, or will need to be replaced.
Nov 02, 2014 | Bunn 10 Cup Home Coffee Brewer
Coffee pours very slowly
An espresso should take 25 seconds to dispense, long coffee takes longer unless you pour an espresso into 1/2 cup of hot water (or the other way round). It could be the grind is too fine hence extraction is proving difficult. Try making the grinder setting to more coarse. More info in link
Coffee Knowledge
Oct 29, 2012 | Saeco Magic Comfort Plus Espresso Machine
Does not pour the proper cup size. Have the default set to the largest size. Sometimes it pours the proper size, other times it pours a smaller size. Also, the sequence of action seems to be off. Sometimes...
the Keurig is supposed to keep at least 12 OZ of hot watet at the ready...
when you press brew, the pump pushes water into the bottom of the heater... the hot water comes out the top into a clear plastic holder with probes sensing the height of the water... when the proper height is reached, the motors change state... other valves open up and that pur-measured water goes from the plastic holder tank to the arm touching the K-Cup...
Try running vinegar thru the unit and maybe the sensor probes are scaled... otherwise... you may have a intermittent connection and would beed to reseat the low voltage wires from that water height container...
involved taking the unit apart... :(
try the vinegar first.
Seems like internal cables need reseating.....
I posted how to open it... do not do unless its out of warranty... and you have a few hours of time to disassemble it...
May 06, 2010 | Keurig B50 Coffee Maker
Coffee grounds in bottom of commercail size coffee maker
If you will call 800-286-6070 we can help you with this.
Nov 01, 2009 | Bunn 10 Cup Home Coffee Brewer
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Keurig B60 Coffee Maker Logo
445 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
