Monitor 2033SNPLUS. I cannot get the preferred
Monitor Samsung 2033SNPLUS. I cannot get the preferred configuration of 1600 X 900
  • 3,600 Answers
Right clcik on the desk top screen go to properties and click on properties and clcik om the resalution you want and 32 bit then click ok, once you do that if you like that setting click ok and close window and your good to go, if you still have trouble please post here.
Posted on Nov 12, 2009
Monitor is not detected in Win-8
Not all older monitors have the correct monitor.inf information for the newer operating systems. Look for a new monitor.inf file download that matches your monitor for Windows 8.
Jan 14, 2014 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor rotation from MacBook Pro
Go to system preferences > displays, then there's an option to rotate the display. You'll also need the corresponding cable to connect it. Enjoy the mac!
Dec 11, 2012 | Samsung SyncMaster 2493HM Monitor
Where can I buy a new base for the Samsung 24
The original Samsung stands will be very hard to find, only available from somebody that has wall mounted their monitor and no longer needs the stand. You can get a third party stand such as the one in the link below that will mount your monitor. All modern monitors have mounting holes in the back for VESA mounting, this is a standard configuration.
http://www.amazon.com/Adjustable-Tilting-Mount-Bracket-10~25inch/dp/B003L171KW/ref=sr_1_12?ie=UTF8&qid=1339684562&sr=8-12&keywords=monitor+stand
Jun 13, 2012 | Samsung 24" LCD Monitor 2494SW
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Dec 24, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
IMic doesn't work with Logic Pro 9
I had a similar problem, but I managed to solve it; however, I'm using different recording software. The iMic simply does not have built-in input monitoring. Chances are, you are getting an input-signal but it is not being monitored. Try to find some kind of input-monitoring in your recording software. I found a toolbar, in my recording software, called "playback state" that has an option for input-monitoring. Search the help file index, within your software, to find something similar. Here's a quote from iMic's quickstart guide that might be of further assistance:
"In order to hear your turntable or microphone, you will need to enable an important preference in your recording software, usually called “Playthrough.” It may also be called Monitor, Passthrough, Cue, Preview, etc. Enabling such a feature tells the software how to route your audio, and is necessary for monitoring even when not recording."
Moreover, once you've solved this, I recommend using the iMic for both input and output, as latency with onboard-sound-output will likely be intolerable for input monitoring.
Mar 29, 2010 | Apple Griffin iMic External Sound System
I have a similar problem but am using an Apple Mac
Top of the screen menu to the left of the mac bar. System Preferences is the option. Once in there click energy saver.
Jul 25, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Philips 107s5 LCD monitor connector configuration
make connection both side same to same
like 1 to 1
2 to 2
3 to 3 like that
Dec 28, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
