Question about Carrier Heating & Cooling
Would u please help me the indoor unit compatible to Split type Air conditioner outdoor unit model 38KGC018703?
Therinnaiguy
  • 1420 Answers
SOURCE: Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Posted on Oct 10, 2007
  • 86 Answers
SOURCE: Error CA for LG air conditioner model Q-12 AWR
1.sensar of remote control.
2.indoor unit sirkit board may be there is problem.change sirkit board by new one
3.if any requirement abt airconditioner pls mail me i can send u spare parts of air conditioner,.
mintex007@yahoo.com
Posted on Mar 16, 2008
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
SOURCE: DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Posted on Apr 22, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
LG SPLIT SYSTEM AIR CONDITIONER INDOOR UNIT WILL NOT POWER UP
as described the voltage you are seeing is fake. if there is no led lighting in the indoor unit check the small transformer in the indoor unit you should get 12V DC or 24V DC out from it
Feb 10, 2014 | LG Heating & Cooling
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
When we turn on our split AC, outside unit is not turning ON
The blinking light is because the unit is waiting for the outdoor unit to come on. If in heating mode, the indoor fan will not run before enough pressure and therefore heat has built up. You should check that the indoor air return sensor is not faulty and therefore preventing the outdoor unit from coming on.
Nov 15, 2009 | Amcor NanoMax A12000E Portable Air...
Heating & Cooling Logo
37 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
