Question about Leica Digilux 1 Digital Camera
I have a Leica Digilux 1. I have just replaced a Sundisc ultra 2 1.0GB with a Sundisc ultra 2 4Gb. The camera is not accepting the memory card even though it is the exact size. Is 4GB too much for it ? JC
erickg
  • 116 Answers
SOURCE: Nikon coolpix 2100- out of memory- After installing 4gb CF card
format card
Posted on May 24, 2009
  • 241 Answers
SOURCE: formatting an CF 4GB sandisk ultra II....How to do
The camera uses FAT16 so it won't be able to use cards bigger than 2GB. IF you can format it, you will only have 2GB space available.
Formatting the card: Press Menu/OK, select Setup, Select Format, press OK untill it's done.
Posted on Oct 12, 2009
  • 241 Answers
SOURCE: My Leica Digilux 2, recently purchased and never
Does the menu in the camera work?
You may need to activate some Postview function in the menu. If the camera takes pictures, you should be able to view them in playback mode. There could also be a Preview mode, which requires pressing OK before storing pictures. Preview/Postview should cancel each other though...
Posted on Apr 13, 2010
ssemul
  • 202 Answers
SOURCE: I own a Leica DIGILUX
there is problem with key switches may be there is some due or some water drop goes in side. check by opening your camera if you find then clean it.see what hapen if still problem need to replace key switches.
Posted on Oct 18, 2010
Testimonial: "Amazingly Prompt helpful particularly regarding Leica cameras as there are not many authorised service centres in India. Thanks. SK Pillai"
  • 102366 Answers
SOURCE: Will a Leica D-lux 3 camera use any class six
The D-lux 3 will handle any size SD or SDHC card. It will not handle the newer and larger SDXC cards, though. The class refers to the read/write speed of the card and will make little difference to the camera, though a faster card may download faster if you use a card reader.
Posted on Nov 05, 2010
Hello, I have recently bought a Leica Digilux 1 but I can't use it since it always marks "Memory Card Error". I have tried with three different memory cards and that sign keeps on appearing....
First make sure that any pics on the cards are safely downloaded to your computer. To get the cards to work in the Leica, you must format them in the camera. This will erase them and set them for the operating system of the camera.
Aug 17, 2011 | Leica Digilux 1 Digital Camera
I have a Leica Digilux, but could not fine it anywhere on tghe dealer spots. I need a memory card for it and its difficult to get locally. The size is larger than the regular cameras.
Amazon could be a help:
http://www.amazon.com/MEMORY-Leica-DIGILUX-Digital-Camera/dp/B000Y06WXA
It may depend on what your exact camera model is. You have only stated Leica Digilux.
There is the Leica Digilux 1, Leica Digilux 2, Leica Digilux 3, Leica Digilux 4, and the Leica Digilux 5. Most seem to take the SD HC (the SD card may work as well) card:
http://www.google.com/search?q=Leica+Digilux+memory+card&hl=en&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=FjQaTtGBMoKusAKnxLzCBw&ved=0CDsQrQQ
If your camera is a Leica Digilux 1, then the cards it can take are: Secure Digital Card and Multi Media Card
http://en.wikipedia.org/wiki/Leica_Digilux_1
If you have an earlier camera, then it could take some other kind such as the Compact Flash Card, although I did not find such a note anywhere.
Jul 10, 2011 | Leica Cameras
My digilux2 is completely dead and lost my certificate card. would it be possible to send it to leica? from thailand.
here is the repair website for Leica. They are worldwide and main repair is in Germany.
http://en.leica-camera.com/service/service_and_repair/
Not sure how they will handle warrenty.
May 04, 2011 | Leica Digilux 2 Digital Camera
I need the manual for digital camera leica v-lux 1 in Spanish, as I can find
Hola, de seguro en el manual en alemán encuentra la direccion de Leica para solicitarles un ejemplar en español.
Saludos
Feb 25, 2011 | Leica Digilux 1 Digital Camera
When I turn on my Leica digilux-2, the monitor shows a photo from the SD card, but does not pick up anything else. The viewfinder is black.
Odd this has been here five months w/o a response. Apparently you describe a "burned out CCD", the famous "sensor problem", which is frequently mentioned whenever the Digilux 2 is being discussed. It's too bad because I think otherwise it is a wonderful camera. Contact Leica in whatever country you live and see what the current policy is re: repair, and whether the company will stand behind their product. There appears to have been positive response. Good luck.
Nov 10, 2010 | Leica Digilux 2 Digital Camera
Best make and largest size of sd card for the leica digilux 2
The Digilux 2 will work with any SD card, but bear in mind that SD cards max out at 2GB. Larger cards are actually SDHC cards and will not work in the Digilux 2.
Apr 18, 2010 | Leica Digilux 2 Digital Camera
My Leica Digilux 2, recently purchased and never used before, doesn't appear to be taking pictures. It reads all memory cards (residule photos previously taken) however when taking a snapshot, the display...
Apr 13, 2010 | Leica Digilux 2 Digital Camera
Leica Digilux 2
The same problem, no idea how to fix it.
Oct 06, 2007 | Leica Digilux 2 Digital Camera
Digilux 2 problem
No solution- Humidity and moisture is death to Digital Cameras
Sep 28, 2007 | Leica Digilux 2 Digital Camera
Leica Digilux 1 Digital Camera Logo
42 people viewed this question
Top Leica Cameras Experts
Steven Wander
Steven Wander
Steve
xalint1
xalint1
Are you a Leica Camera Expert? Answer questions, earn points and help others
