Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
I believe it is clogged with dog hair...not sucking
  • 10,865 Answers
Hello. Thanks for choosing Fixya! That dog hair will definitely have to be removed. Pull it out anyway you can, using a tweezer, a pair of needle nose pliers, etc. Also examine all of the hoses and remove any debris that could be adding to the problem. Regards, Joe
Posted on Nov 12, 2009
Vacuum is clogged with dog hair. How can clog be removed?
HI, it's Jim from Crucial Vacuum!
If your Shark vacuum is clogged with dog hair there are a number of general maintenance cleaning tips you could perform to help keep your vacuum working at its peak performance.
First let's check out your brush roll. Is there dog hair wrapped around the roll itself? If so remove it by pulling out the dog hair, or use a razor if its tightly wrapped around. Manually rotate the brush roll to help unearth any hidden clogs behind the roll.
If there's dog hair throughout your unit be sure to empty the dust cup after every use. When the dust cup isn't emptied often this leads to clogs and a loss of suction.
Also, be sure to check your vacuums hose for any clogs, or clumps of dog hair. Stretch the hose out as far as you can. If you notice a clog in a hard to reach place use a broom handle to unclog it.
Your Shark vacuums filters may need to be replaced, or washed and may be a source for a lot of the dog hair in your vacuum. Wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 11, 2015 | Shark Vacuums
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
Dyson upright sucks up great. Gets clogged within one of the beaters only and stops spinning having only vacuumed for a short while. We do have a dog and there is hair being sucked up also.
I'm sorry to hear you're having difficulties with your DC24. It's hard to determine from your description exactly what the cause of the issue is - I'd encourage you to get in touch with us directly so we can provide the assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Jul 18, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My vacuum is not working properly, it is not sucking any dirt. What should i do? where should i take it to fix it. i already checked the hose and it is not clogged
Remove hose an look down into tube that connects hose. There's a small elbow on the bottom that clogs easily. (Mine has multiple times - dog hair)
Mar 21, 2011 | Dirt Devil 12 Amp HEPA Filter Vacuum...
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Vacuum blows out dust/pet hair etc. when in use
try replacing the belt if you havent. it almost sounds like your getting weak aggitation. if thats not bad, check for a clog in the brushroll housing nozzle right on the inside by the tube. Replace the inside hepa filter if you havent within the last 3 months.
Jan 04, 2010 | Hoover U5753-900 WindTunnel Bagless...
My eureka 437 stopped sucking
I believe the filter on your vacuum is clogged. Bagless vacuums require the filter be brushed or washed and dried, If they are not, the filter will clog, resulting in the reduction of suction. Clean filter about every 3 months or sooner if the same problem happens again. Hope this helps.
Aug 20, 2009 | Eureka Vacuums
Dyson dc17 animal motor spindle keeps clogging
If you have animals get rid of the dyson and go to a vacuum that has a metal brushroll and better airflow. There is no fix on the dyson they just are not good on hair of any kind.
Jan 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell Pro Heat 8910 clogged?
Why the motor sounds muffled I am not sure. When the water is sucked up, it goes directly into the tank. The motor only creates the suction so it can do that. There should be a filter on the rim of the recovery tank lid, is it clean? Other then pulling the top cover off, and then the motor cover so you can inspect the motor, I really don't have a good answer for you. I t may be that that clump of hair when down the chute and into the fan, I have seen that happen with vacuum motors before.
Nov 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Lift-Off Pet Hair vacuum doesn't lift off pet hair!
very light "stuff" like dog hair will get stuck to the filter since that is where the suction goes. it's primary purpose was to keep dust out of the motor. This is a problem with many "bagless" cleaners. A bagged cleaner keeps all dirt and hair away from filters by utilizing the bag as primary filter. If you have alot of dog hair then this may have been the incorrect choice of a vac. all you can do is brush off the filter each time you use the vac. it will still pick up o.k. even when there is hair on the filter unless you leave it on day after day.
Jun 14, 2008 | Bissell 37604 Lift-Off Pet Bagless Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
144 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
