Question about Dell E176FP 17" LCD Monitor
Monitor displays a window stating it is doing a self test, 2. digital input. The rest of the window has the RGB bars.
    Problem Solver:
  • 7 Answers
Does this happen eveytime you turn the monitor on ? If so, check that you don't have a button on the monitor that has got stuck in.
Posted on Nov 12, 2009
My Hewlett-Packard w2207 monitor is showing no input signal when I power it on what does that mean and how can I fix it
1) Reset your computer.
2) Unplug the cable from the computer to the monitor and check to see if its damaged, if OK plug it back in.
3) On windows computer, click windows key / windows system / control panel / device manager / display adapters (click on icon) / Update driver
Feb 22, 2018 | HEWLETT-PACKARD Computers & Internet
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Oct 27, 2017 | Dell Computers & Internet
Monitor has solid green LED, but no display
you have to test the processor functions. therefore use post diagnostic card via PCI or PCIX or USB for the check hexa codes, if you show codes the processor ,ay be ok, also have to check the code function by card manual. and replace the unit that failure.
Mar 12, 2017 | AOC LM-800 18" LCD Panel Monitor
Connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Mar 14, 2009 | ASUS Computers & Internet
MONITOR NOT COMING ON . RGB NO INPUT SIGNAL .
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
Oct 28, 2008 | Computers & Internet
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
Monitor image is "posterized"...red,yello, blk and white only
you have defective RGB circuit, or re solder all CRT Board maybe you have lost contact at the RGB CRT Board. RGB means red, green, blue. CRT means Cathode Ray Tube.
Oct 08, 2007 | Apple Studio Display 17" CRT Monitor
Digital not working
The latter part of this post seems to confirm that the problem is inside the monitor, probably a failure on the signal / video board. You might also look for damage to one of the connectors. Otherwise, if your manual shows some settings or a rest, that might be the issue. But the fact that the self-test does not work leads me to believe that the unit needs a new a signal / video board.
Jan 06, 2007 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell E176FP 17" LCD Monitor Logo
126 people viewed this question
Alun Cox
