My washing machine is leaving a lot of soap in the clothes. Why? It started with the machine not stopping a couple of times. It`s now stopping but there`s a lot of soap in the clothes.
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Sounds like not discharging water properly..You could try cleaning the filter/ also could be cold water not entering machine during rinse..Hope this is of some help .
Posted on Nov 12, 2009
I have a fisher&paykel washing machine every time l wash my clothes it leaves Dirty marks on my clothes I have pulled out the barrel and cleaned it and put it back together and it still leaves marks
With no clothes in the machine, Do a long hot wash, add some bleach, stop using fabric softener. Cut down on soap usage. This should clean out the machine. If it happens again, there may be a mechanical problem which is allowing grease or oil into the machine.
Mar 20, 2017 | Fisher and Paykel Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
My Tromm washer is leaving residue on my clothes
Make sure you are using the correct soap. (Front load soap powder) Also use a bit less than suggested on the packet. If you are often using cold or low temp wash cycles, dirt and build-up in the machine will be common and come off on your clothes. Use a very hot wash at least once a month to clean it out and stop using fabric softener. It sticks to everything and any dirt in the water gets stuck on and then comes off in later wash cycles.
Sep 25, 2014 | LG WM2688HWM TROMM SteamWasher
My washing smells after a wash, but the washing machine drum does not smell.
A solution from the internet: Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Another: I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
Jul 02, 2014 | Hotpoint Aquarius WD63 Front Load...
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Jan 25, 2010 | Maytag PAV2300 Top Load Washer
Sud message on whirlpool duet front load washer also after washing clothes i notice a mildew smell on the clothes.
You areusing too much soap. Run a rinse cycle and use less soap next time. As for the mildew leave your door cracked open after you are done using the machine.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have an affinity washer that has an odor and my clothes come out smelling bad. I don't leave clothes in for any period of time. If they stay in for even a couple of hours, I have to rewash because the...
You have a build up of undesolved soaps in the system. Do 2 hot washes twice a day for maybe 3 days without washing in and no soap. Old soap needs to be desolved and drained away. See if there is a difference. Note, Put only 1/2 of the soap in and work from there.
Nov 13, 2009 | Frigidaire Affinity ATF7000E Front Load...
LG stinks too
It is not a poor design its the way we have gone re washing clothes
Old machines washed hotter and with more additives in the powders.
Try using a good strong mix of soda crystals in hot water , pour that into the wash before you switch it on and do a hot wash without any soap powder
Use old fasioned powders for a couple of weeks and do a hot wash once a month with the soda
The constant cool washes leave body fats from the clothing inside the machine as there is no real heat to melt them and no soda in the washing powder anymore to unstick them from the surfaces .
Jun 26, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
