Question about Plumbing
Problems getting hot water to the shower
In my new bathroom, fitted a year ago, the hot water supply to the shower has never been satisfactory. The fitter has been back and tried numerous remedies, including fitting non return valves, but now thinks that the pump is the problem. The manufacturers tell him that the COLD water tank needs holes drilled in it, and being an old asbestos one it has to be replaced. I am expected to bear the cost of the replacement tank. Is this a problem anyone else has encountered - how likely is it that this is the solution? The pump draws water from the hot ater tank, but that in itslef then draws from the cold water. I have never had problems with water pressure in the house - if anything it is on the high side. Any ideas please before I authorise the extra work?
  • Anonymous Mar 22, 2014
    water pressure dropped here and since it came back we get only cold water from the shower how do I vent the pump?
  • 43,501 Answers
If you have good water pressure to every other hot water faucet inj the house then the problem lies in the shower valves. There are some very small passages in the valve and getting dirt removed can be very hard to do. You could try trurning the water off and blowing air back through the shower or taking apart the valve and flushing the valve out with it dissasembled.
But my opinion is that the problem is in the valve.
Posted on Nov 12, 2009
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
I have two vanities and a shower in the bathroom. We only get hot water to the sinks when we turn on the shower to hot. Even if we turn off the shower we will still get hot water for a while. It just seems...
Check the water supply lines to the shower at the faucet handles. If the fitting for the hot water line connected to the handle is loose, it can twist and kink off the water supply further down the line when you turn the faucet handle. I'm not exactly sure how this could be relevant otherwise, but under normal design circumstances this type of scenario with your shower wouldn't matter for other faucets.
May 01, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
Hot water dosen't come out.
hot water supply is probably turned off. Is it a rental or did you buy the place? Does it have a crawl space or a basement? Where is your water heater? Start at the water heater and trace the line to the shower. There may be a valve in between that has been shut off. Good luck.
Feb 21, 2010 | Pioneer 2 Handle Satin Nickel 6" Rain Head...
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
Shower problem
This must be a joke because there is no way the shower is connected to your faucet. the faucet on you vanity is connected directly to your hot and cold water supply. And only by opening the hot water side of the faucet can you get any hot water.out of the faucet.
Aug 01, 2009 | Home
No cold water comes out of one of our bathroom shower
Obviously your plumber when they were building the home hooked up hot water lines to both faucets and never hooked up a cold water line.
Jun 01, 2009 | Moen Showhouse Waterhill One Handle Tub...
I have a Moen Posi-temp single handle tear drop tub and shower that gives me no hot water
i am assuming you have hot water in same bathroom and that its fed by the same pipe? if so ask yourself did i have anything done recently that may have affected the shower ?if not i would think you have some kind of a blockage in fitting. one way to try to clear it is shut off water to house open shower fitting to what used to be the hot side when working,leave shower open,go o lowest level of house open hot side in sink you may get lucky and vacumn(think ****)debri from shower good luck .
Apr 23, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Shower not hot
There is a handle limit stop under the handle. Remove the handle with an allen wrench and you should see a plastic piece with a tab on it fit into the assembly. Remove it and rotate it slightly to allow more travel in the handle and reinsert. You will have to test it to see if it allows enough hot water to mix in. If it is still not warm enough repeat as needed. Once you have the water at a comfortable temperature reinstall the handle and enjoy.
Dec 31, 2008 | Plumbing
I have a 6 year old Halstead Ace High boiler which has many recurring problems due to a bad fitting. It was never flushed out causing the heat exchange needing to replaced TWICE through clogging and then...
Firstly your system needs a power flush to get rid of the grot, then it needs a good inhibitor to slow up the reappearance of the sludge.
Changing the boiler won't help. Any boiler will get clogged up but the halstead DHW heat exchanger is particualrly prone to getting gummed up. You can clean this out and refit without having to buy a new one. - but without a power flush it will happen again.
Jul 31, 2008 | Heating & Cooling
Plumbing Logo
158 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
