Question about HP PhotoSmart C4280 Laser Printer
Printer has been working fine. Now it says
Printer has been working fine. Now it says incompitable print cartridges?
    President:
  • 414 Answers
Did u changed / replaced the cartridge with original spare or refilled it??
do not panic..this kind of problem often follows with (esp. an unbranded) cartridge change and or refilling..!!
it also can be the defective cartridge itself causing such problem..!!
well if u r a professional then just dip a cotton into isopropyl alcohol n gently rub the connector sensor/ contact surface, n reinsert it properly, gently rub on the head too n make sure ink is coming/flowing, make sure the toner is not jammed or dried up, also have a glance on the 'carriage' n see that no sensor pins are broken and or bend..!!
..if u r not an professional, make sure it is properly inserted and the ink-spill protective/head covering is removed..
if all the above fails, then it may b a defective or demo cartridge..!!
and call ur system admin....
Posted on Nov 12, 2009
  • 460 Answers
You can try to reload the printer drivers or manually clean the print heads with a paper towel and alcohol...
  • 79 Answers
Have you installed refilled ink cartridges ? If not then take out the cartridges and try to clean the contacts of the cartridge with cotton swab.
My HP stops printing after accessing any type of webmail or online study courses,e tc. I can send a doc to print and the printer works but it prints blank pages. The ink cartridges are fine.
Step 1:-
First of all go to the printer--> Press setup button on it --> use the Arrow keys --> choose the tools option --> now choose the option Print a test page--> If the test page prints fine--> The printer is fine. No problem in the printer.
Else take out the cartridges and clean it with a lint free cloth. ( Remember when cleaning the cartridges DO not touch the nozzel of the cartridge. Just clean the out side of the cartridge nozzel.)
Step 2:-
Try to change the color of the font on the document you are printing and then try printing. You will get to know if it is actually printing or not. If it is not printing in color also then try this ...!
Click on start--> go to control panel--> go to printers and faxes or printers option and then right click on the printer and choose properties option. Click on the print a test page button.--> Check if it works.
Let me know if it works..!
May 07, 2010 | HP Officejet 7210 All-In-One InkJet...
Cant figure out how to put in the ink cartridges
Procedure for replacing Cartridge
When FIne Cartridges run out of ink, replace them. using the following steps.
*Important
Handling Fine Cartridges
-Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
-To maintain optimal printing quality, we recommendthe use of specified Canon brand FINE Cartridges.
Refilling is not recommended.
-Once you remove a FINE Cartridge, replace it immediately. Do not leave the printer with the FINE Cartridge removed.
-Replace empty cartridges with new ones. If you insert FINE Cartidges that has been removed once, the printer may not print properly due to some reasons such as clogging of the nozzles. Furthermore, with such cartridges, tlhe Low ink warning may not be displayed properly.
-Once a FINE cartridge is installed, do not remove it from the printer and leave it out in the open. This will cause the FINE Cartridge to dry out., and the printer may not operate properly when it is reinstalled. To maintain optimal print quality, use a FINE Cartridge within 6 months of first use.
-Color ink may be consumed even when printing a black and white document or when black and white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the printer's performance.
1) Make sure that the printer is on, and then open the Front Cover.
The FINE cartridge Holder move to the left.
Cautuion : * Do not hold the FINE cartridge Holder to stop or move it.
* Do not touch the metallic parts inside the printer.
Important : If the Front Cover is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. Close and reopen the Front Cover to return the holder to the left.
2) Remove the empty FINE Cartridge.
a) Push down the FINE Cartridge.
b) Remove the FINE Cartridge.
Important: - Handle FINE Cartridge carefully to avoid staining your clothes or surrounding area.
-Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
3) Prepare the replacement cartridge.
a) Unpack a new FINE Cartridge and remove the orange protective tape. gently.
Important : - Handle FINE cartridge carefully to avoid staining your clothes or surrounding area.
- do not re-attach the protective tape once you have removed. Discard it according to the locals laws and regulations regarding disposal of consumables.
-once the protective tape is removed , to not touch the electrical contacts or Print Head Nozzles on a fine cartridge. The printer may not print out properly if you touch it.
-Be careful not to stain your clothes and hands with the ink on the removed protective tape/
4) Install the FINE Cartridges.
a) Insert a new FINE Cartridge all the way into the appropriate slot. The Black FINE Cartridge should be installed into the left slot and the Color FINE Cartrige should be into the right slot.
b) Push up the FINE Cartridges until it clicks into the place.
Important : The printer cannot be used unless both the FINE Cartridges are installed.
5) Close the Front Cover.
Hope this helps. Please rate my response.
Thanks,
Have a good day.
Nov 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer is stating incompatible ink cartridge. I am not able to print. Had this printer for about 1 yr.
printer will show this error message when the cartridges are not getting properly detected by your printer or there is another problem like if you are using refilled ink cartridges or if your printer is not working fine as because its hardware functionality is not working fine
so in order to check that which will be the reason try to clean the copper contacts of the cartridges first and then if that will not work then use a new set of ink cartridges and if those new cartridges will work fine then the previous cartridges are faulty and if that new cartridges will not work then the printer is not working fine so you must service ur printer
try these steps in order to resolve the issue..........
Sep 20, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Ibm info print 40 fuser 90h3567 same as xerox n40 fuser 109r486
Xerox put identity chips into their consumables and I presume IBM do the same which means even if the fuser is exactly the same your printer is going to reject it as a incompitable part
Sep 08, 2009 | IBM Infoprint 40 Laser Printer
Troubleshooting Dell 924 all in one printer(Printer reads unsupported cartridge)
Try replacing the cartridge with a new Dell ink cartridge, the refill may have gone bad.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
Can't put cartridge into printer
If your replacing the fine cartridge follow these steps. Sorry for jumping in but it looks like your in a hurry. If you already solved it, great.
1 Make sure that the printer is on, and then open the Front Cover.
The FINE Cartridge Holder moves to the left.
i_expl.gif Caution
bullet_s.gif Do not hold the FINE Cartridge Holder to stop or move it.
bullet_s.gif Do not touch the metallic parts inside the printer.
i_important.gif Important
2 Remove the empty FINE Cartridge.
(1) Push down the FINE Cartridge.
(2) Remove the FINE Cartridge.
bullet_s.gif Handle FINE Cartridges carefully to avoid staining your clothes or surrounding work area.
bullet_s.gif Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
3 Prepare the replacement cartridge.
(1) Unpack a new FINE Cartridge and remove the orange protective tape (A) gently.
*1 To the FINE Cartridge Holder
bullet_s.gif Do not re-attach the protective tape once you have removed it. Discard it according to the local laws and regulations regarding disposal of consumables.
bullet_s.gif Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
bullet_s.gif Be careful not to stain your clothes and hands with ink on the removed protective tape.
4 Install the FINE Cartridge.
(1) Insert a new FINE Cartridge all the way into the appropriate slot.
The Black FINE Cartridge should be installed into the left slot (ug_maintenance37.jpg) and the Color FINE Cartridge should be into the right slot (ug_maintenance38.jpg).
(2) Push up the FINE Cartridge until it clicks into place.
5 Close the Front Cover.
Hope this does it. I'll check on you later. If this fixes you up just rate it a 4 fix ya and I'll know you're ok.
Mar 26, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Will not print
Try using the 'clean cartridge' setting with your printer, this usually forces the ink through the installed cartridges.
Dec 11, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
HP 1350V all-in-one
Hi, You need to get a new ink cartridge. It is really not recommended to refill ink cartridges but if you do then it is advisable not to exceed 3 times because it could damage the printer head. If the new inks still gives error, then your printer head may need to be checked to see if it needs replacing. Good luck!
May 25, 2007 | HP PSC 1350v All-In-One InkJet Printer
HP PhotoSmart C4280 Laser Printer Logo
346 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
