Question about Corel WordPerfect Office 12 Standard Edition for PC
Bookmark cannot be found while trying to generate a table of authorities
The bookmark search bar for my iPad Air 2's in Safari to date, has never found or even suggested a single bookmark!
No, bookmark is not that icon. To retrieve your bookmark It is the plus sign ( + ) on the top of the right corner.
Apr 22, 2017 | The Computers & Internet
Wordperfect 11
Createing table, or you want the whole process?
Mar 26, 2008 | Corel WordPerfect Office 11 Upgrade...
Can you get ordered pairs for the 3D equations?
I am not sure I understand but I will try. Do you want to generate a table of values for a surface you have graphed? If I guessed right then I am sorry to inform you that the TABLE is not available in 3D. I have just tried to generate a table for the surface z1=(x^3*y-y^3*x)/390 )an example from the manual). When I pressed [Diamond][Table] I got the message reported earlier.
Oct 12, 2013 | Texas Instruments TI-89 Calculator
Zynga poker error code RS1
i have 11 m when i click 100k/200k/200k/400k table show up this message cold not join room:you are not authorized to enter the room.error code:RS1. i can play only 80 k down tables HELP ???
Jan 12, 2012 | Zynga Texas HoldEm Poker
How can I transfer my bookmarks to a new computer?
The simplest method to transfer bookmarks between computers is by "signing in" to Chrome on the first computer. All of your Chrome browser data and preferences (including bookmarks) will be saved into your Google account, and that will be available whenever you sign in again on any other computer.
Here's how to sign in: In the Chrome web browser, click on the wrench icon (upper right corner), then select "Sign in to Chrome".
Then enter your Google account user name and password.
All of your Chrome bookmarks, extensions and other preferences will then be saved into your Google account online.
Then on your new computer, install the Chrome browser, and again "sign on" with the same Google account. Your Chrome bookmarks, extensions and other preferences will be retrieved from your Google account.
See also these Chrome help pages:
http://support.google.com/chrome/bin/answer.py?hl=en&answer=165139
http://support.google.com/chrome/bin/answer.py?hl=en&answer=185277&topic=1693469
Alternatively, you can export your bookmarks from the Chrome browser on the old computer. Click on the wrench icon, select "Bookmark manager"; then select Organize > Export bookmarks. That will generate an HTML file. Copy that file to the new computer (e.g., by using a flash drive). Then on the new computer, install the Chrome browser, select "Bookmark manager"; then select Organize > Import bookmarks.
For more on bookmark export & import, see this helpfile:
https://support.google.com/chrome/bin/answer.py?hl=en&answer=96816
Hope that's helpful.
Dec 26, 2011 | Google Chrome
Iwant to delete bookmarks
  1. 1Open your Mozilla Firefox browser.
  2. 2Select the "Bookmarks" button from the file bar.
  3. Scroll down to the bookmark you wish to delete. Scroll down to the bookmark you wish to delete.
  4. 4Hold your mouse over the bookmark you wish to remove and right click.
  5. From the drop-down menu that appears, select the Delete button. From the drop-down menu that appears, select the Delete button.
  6. 6Alternately, delete all bookmarks in Firefox by deleting the bookmark file from Mozilla Firefox's user profile folder. (Note - This method will not work on Firefox 3. The bookmarking system has been changed from that of previous versions) This varies on each PC since the profile folder name is a randomly generated name, but here's an example:
    C:\Documents and Settings\(your account name)\Application Data\Mozilla\Firefox\Profiles\f1f2f3f4f5.default\bookmarks.html
Any doubts you can get in touch with a technician through
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Sep 28, 2011 | Microsoft Windows Vista Home Basic Edition...
The X-Values in the Table for a graph wont reset, i have deleted the equation and there is no graph plotted, however they wont disappear. Also, i tried accessing the X on the top of the table, and it did...
What are you trying to do? You drew a graph, then you cleared the function graphed and went to the table to see if the X values have disappeared and they did not.Right?
By pressing the [SHIFT][(TABLE) key you were in fact commanding the calculator to generate a table for a function but you did not supply (nothing in Y= editor), and the calculator faithfully obeyed you. It looked at the Xmin of the window, looked at the Xscl factor and generated a blank table that contains all the X-Coordinates (where your function or table would have been calculated had you entered a valid expression in the Y= editor). That is how it works.
Aug 28, 2010 | Texas Instruments TI-84 Plus Calculator
Transferring bookmarks to a new computer and now I cant get it to open a .json file. What do I do?
what procedure did you follow when transferring your bookmarks?
In Firefox Select Bookmarks > Organize Bookmarks...
In the Bookmarks Manager select File > Import... and locate the saved bookmarks.html file and attempt to load them up again).
I found this article that may help you with your problem, see here
good luck!
Mar 29, 2010 | Mozilla Firefox
Corel WordPerfect Office 12 Standard Edition for PC Logo
130 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
