Question about Sony Televison & Video
My deaf father has been recommended to use headphones when watching TV. However, when his stereo headphones are plugged into the headphone jack socket, the internal speakers of his Sony KDLS32A12 are muted so no one else can listen at the same time! Is there a way the headphones can be connected to other sockets so that the internal sound isn't muted? Any suggestions will be gratefully received. Thanks.
  • 1 more comment
  • jillywebba Nov 13, 2009
    Thanks for this Dan
    The model number for the Sony TV is: KDLS32A12U (as stamped on the back of the set). However, we would like to use an existing stereo headset, rather than purchasing a new adaptive system as you describe.
    The TV set has audio output, both phono and SCART sockets. I already have a 3.5 mm jack to 2x phono cables (which is no good to me as I can't plug in the headphones) but cannot source a 3.5 mm SOCKET to 2x phono cables. However, on searching through catalogues last night, I found a 3.5 mm stereo jack coupler that I believe would connect the headphones to the cable I have.
    Do you think that if I buy the coupler and use it to connect the headphones to the TV via the phono cables I ought to be able to get sound without muting the TV's internal speakers? And, if so, which colour phono sockets should I plug in to?
    Thanks in advance
    J
    Thanks for this Dan
    Thanks in advance
    J
    Thanks for all of your help Dan.
    The current headphones don't have a volume control so it looks as though a new headphone listening system will be the better option.
    Regards
    J
  • 4,234 Answers
This is not a typical setup for most TVs. There are ways around it though. If your set has a set of audio output jacks, than those can be used to power a separate sound source for the headphones. There are adaptive listening systems available for this purpose what use either infra-red transmitters or RF transmitters to matching headphones. The key here is whether or not the TV has the audio output available.
Please check that and update this with what you find and I'll try to provide a solution within the context of your specific set. Post the TV model number too.
Thanks,
Dan
Posted on Nov 12, 2009
  • ABRsvcs Nov 13, 2009
    The red/white phono jacks labeled Audio Out should be useable without effecting the TV speakers. The only problem is that these may be a "fixed" output level. This means that they are intended to feed a receiver that has its own amplifier and volume control.
    Your best option here is to use the headphone jack of a receiver and feed the receiver from the TV as described above. This will give the headphones a volume control that is independent of the TV speaker volume control.
    Dan
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Have an Hitachi 42 PMA400e Plasma Tv.
Unfortunately, if there is no headphone connector on the TV there is no practical way of accomplishing the alternate arrangement.
Mar 21, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
Mar 22, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Why do I only hear static
Hi Cathy.. it sounds like you might be connected to the wrong jacks instead of the output that the headphones need.
Most high quality stereo headphones have a single 1/4" stereo plug that would readily plug into a 1/4" jack on the front of the stereo labeled "PHONES" or HEADPHONES".
Many lower quality "computer headphones" or headsets have two 1/8" plugs. One is often black or red and is for an included microphone that may be a boom type (shown below) connected to one of the speakers or an "in-line" type built into the cord itself. The headphone speakers in the headset get their signal from the other plug - which is usually green; but could be any color really. There should be 3 metal parts on the stereo headphone plug. The tip, the middle ring and the bottom ring. Many times the mic is mono (not stereo) and only has only a tip and a bottom ring on the plug. You can see stereo headphone and microphone plugs he picture below:
Computer Headphones or "Headset" with mic and phone plugs.
Your Yamaha stereo will probably NOT have 1/8" jacks to directly plug the headphone into. You can buy an adapter that you would plug your headphones into and then plug the adapter into the 1/4" jack on the stereo. One is pictured below:
Front and rear views of a "1/4" to 1/8" Stereo Adapter Plug" The front plugs into the stereo and the the smaller 1/8" headphones plug into the rear.
I hope this helps & good luck!
Jan 21, 2012 | Sennheiser Audio Players & Recorders
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
We are trying to hook our TV up to our computer to use it as a monitor. What cords do we need to do this besides the normal monitor cord?
if you want audio as well, it will depend on what kind of audio connection your tv has next to the VGA (computer monitor) connection. If it looks like the normal RCA audio, (red and white plugs) you will need to get a male headphone jack (to plug into your computer headphone or speaker out jack) to stereo RCA cable so you would have a headphone jack on one side of the cable and a red and white plug on the other side. Now if your TV just has what look like a headphone jack next to the VGA (computer monitor plug) you will need to buy a male to male stereo headphone jack cable. for both of these, just make sure the cable you get it long enough, or buy an extension.
Mar 21, 2011 | Sansui HDLCD1908 19 in. LCD TV
Can the audio be heard normally from the TV while these headphones are also being used? One person in the family is deaf and will use the headphones while the rest of the family will watch also with the...
Randy - I don't know what TV you have but in general media devices turn the internal speakers off when you plug anything into the headphone jacks. If your TV does you can probably do the following for probably around $20 (USD)
If you have a relatively new TV you could get a pair of inexpensive self powered computer speakers and a simple 3.5 mm to RCA stereo adapter. Then plug a standard red-white RCA stereo cable into the red-white stereo output jacks on the TV and the other end into the 3.5mm adapter and a 3.5" stereo cable from the adapter into the computer speakers.
Or, if the TV headphone jack is 3.5" instead of the larger 1/4" headphone type you could simply get a 3.5" stereo Y adapter and then plug the headphones into one end of the Y and the computer speakers into the other.
Either way sound for everyone.
Thanks for using Fix Ya
Mikeywaf .
Mar 17, 2011 | Audio Players & Recorders
I bought my father a Panasonic plasma TV but it does not have any audio out plugs on the back of the TV. Is there any way to hookup wireless headphones without audio plugs on the TV so that he doesn't...
Yes, they are out there. You can Google the net for Wireless Tv Headphones. I know what you mean. Panasonic is only a couple of mfgs that don't incorporate that in some of there models. I think that's crazy.
Dec 04, 2010 | Televison & Video
No sound from the TV when the headphones are plugged in.
if you have a stereo unit(am+fm reciever) that has output to speakers, connect the out jack of the tv to input on back of stereo unit(aux in or cd input) then you can have output to headphone and speakers also.
Apr 07, 2009 | Sennheiser RS 110 Consumer Headphones
Televison & Video Logo
369 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
