Question about Sharp AR-5316 Advanced Digital Imager Copier
It display I have sharp copier AR-M165. Each time put on, it displays error "Call for Service H5-01" Kindly help
  • 1 more comment
  • popson femi Aug 11, 2013
    it display call for service H4-00
  • Ngoya Mulomba Thierry
    Ngoya Mulomba Thierry Jan 11, 2014
    H5-01
  • Colin Barstow
    Colin Barstow May 28, 2014
    H5-01 error is displayed if the machines has experienced multiple jams. the way to clear the code is to perform a crop 14 on the machine, however this will not fix your jamming issue. Please check you have correct paper settings, guides are tight, no small pieces of paper anywhere in the machine
    New Friend:
Hello my machine gives me this message to call service error H5-01 Sharp what key i can use svp to lock the machine
Posted on Jan 11, 2014
  • Sharp Expert
  • 257 Answers
Check the white area of document glass and clean it or the copy lamp is not lighting.
Posted on Nov 20, 2009
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
Sharp m165 showing error H4-00
H4-00 relates to the fusing unit not reaching the desired temperature. This could be due to a heat lamp or thermistor failure. I would recommend calling your local service engineer. hope this helps.
Apr 22, 2013 | Sharp AR-BC260 Color Copier
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
U2-40 error on Sharp AR 5127 copier
try this pres the ff: # >interrupt> C >Interrupt
input 16 then follow instruction
this is related when you install not original toner or not compatible one
Jul 21, 2009 | Sharp AR-5316 Advanced Digital Imager...
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Apr 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Problem with copier SHARP AR-206 display
what is the problem with the display ? is it out ? or showing an error ?
Apr 05, 2008 | Sharp AR-207 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
623 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
