Question about Cell Phones
How to raise the speaker - Cell Phones
The system will shut off once the volume reaches a certain level. The system will not get really loud.
CHECK ALL YOUR SPEAKER CABLES YOU MAY HAVE A PINCHED OR PUNTCHURED SPEAKER CABLE. IF ALL YOUR WIRES ARE RAN ALREADY GO INTO SPEAKER SETTING GO TO SPEAKER CONF, WITH RADIO PLAYING, AND START RAISING Hz IF ITS A SPEAKER CABLE PROBLEM IT SHOULD CUT OFF WHEN UR RAISING THAT SPEAKER Hz. IF IT CUTS OFF WHILE RAISING THE Hz TAKE ONE SPEAKER CABLE STRAIT FROM RECIEVER TO THAT SPEAKER THEN TRY RAISING IT AGAIN. GOOD LUCK
Jan 09, 2011 | Onkyo TX-SR608 Receiver
Lanzar subwoffer speaker keeps flaping when volune is raised
x over frequency sounds wrong , level match head unit to amp , see amps gain , turn it all the way counterclock wise first then check , check surround on sub .
Dec 22, 2009 | Car Audio & Video
Volume automatically decreased to zero and won't go back up.
Plug the audio out to check it isn't the speaker itself failing. I suspect it is the audio circuit section of the board. But a few times I have experienced the speaker unit circuit where the magnet is caused the problem. So using an external speaker helps to determine speaker vs circuit
Thanks for using FIXYA
Oct 11, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Speaker problem
You can increase the volume of your speaker by tow ways,
1. By pressing the volume control which is on the side of your mobile.
2. Connect your headphones to your mobile, then press the volume raise button in your headphone, then remove your headphone.
I think this information will be usefull for you.
Mar 15, 2009 | Nokia 6630 Cellular Phone
Raised volume cuts sound and gives me "overload" message
A couple of possibilities: Bad solder on power regulators (attached to main heat sink) or cooling fan may not be turning on when volume is raised.
Jan 16, 2009 | Audio Players & Recorders
My hp speakers dont work
re-install drivers for your sound card
Aug 18, 2008 | HP Pavilion dv9000z Notebook
dear sushiudon
plz check your speakers with another pc is it working there.plz post your findings
Apr 02, 2008 | HP P5302M Computer Speakers
I want my music back!
Have you tried to raise the volume by double clicking on the speaker icon on your taskbar. This will open the play control panel where you can raise the volume.
If you do not see the speaker icon, go into your control panel and chose sounds and audio devices and raise the volume from that screen.
Mar 31, 2008 | Gateway 2520915 Keyboard
Subwoofer crakling sound when playing anything.
Hello Ronaldlora
Happy Holidays
Hi, this is a particular problem for this speakers, and subwofer, it is a resistor inside the sub, you have to fix it in a repair shop, or ...sadly, change for another model of Creative Speakers, for example one good one is the 7800 Spk. good ones.
but like I say is a problem that creative labs is aware too.
Dec 17, 2007 | Creative Labs Gigaworks S750 Computer...
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
