Question about Epson TM-U220 Matrix Printer
Hi, I have a problem with my EPSON TM U220PB.. i perfom the self-test and it works properly. but the print test with xp interface gives me incomprehensibles caracters. Please help me...
  • 79 Answers
Reinstall the driver and check. If it does not work, replace the cables and check.
Posted on Nov 12, 2009
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Printer Epson TM-U220PB is not recognized by PC using windows 7. Shown driver EPSONTMPB1.02 invalid
I have made so many attempt but my printer still can not print any recipt, pls help to solve this problem it is urgent.
Aug 26, 2011 | Epson TM-U220PB Matrix Printer
I need driver for Epson TM-U220PB (Windows xp..) user port USB
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
May 28, 2011 | Epson TM-U220PB Matrix Printer
Epson TM 88II not working with Win XP SP2
Are you confident this is using a parallel interface?
The ones I used to work with used a 25pin to 9pin serial connection. The 25 pin connection on the printer is the same as a parrallel port on a PC, but if you think of a normal parallel lead the printer should use a 'centronics' connector to conform to this. I think you may need a 25pin to 9pin serial lead which aren't very common but plenty of people should still make them.
Stephen
Feb 18, 2010 | Epson TM T88II Label Printer
Is it viata ready or what os do i need for epson tm-u220pb printer
The requirements for epson tm u series printers are.....
Windows XP, Windows 32bit: Microsoft Windows XP Professional 32bit SP3 English, Microsoft Windows XP Embedded 32bit SP2 and Microsoft Windows Vista Ultimate 32bit SP1 English
Windows 64bit: Microsoft Windows Vista Ultimate (x64) SP1, Windows Server 2008 Standard (x64)
Aug 10, 2009 | Epson TM-U220PB Matrix Printer
Tm-u295 firmware problem?
I can solve that problem but i need some help in the firmware of TM U220B. I just need the .bin files to downgrade to version 1.02
Feb 18, 2009 | Epson TM-U295 Matrix Printer
Can't install epson tm-t88iii serial
unistall the epson driver.
reboot your system.
connect and turn on the printer.
reinstall the driver, v3.02, selecting for create a serial port.
choose the right setting os serial interface.
after install, reboot your system.
it works to me.
Aug 19, 2008 | Epson TM-T88III Thermal Printer
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
407 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
