Question about Dell Inspiron 9300 Notebook
Laptop is not a dell it is a Packard bell easy note. it did work last night and picture was fine. have checked connection and greeen light is on on extension lead. I know batttery is knackered but my friend said it worked when plugged inti extension wgich it did but not today.
  • 10,865 Answers
Hello. I can help you. As you indicate the problem could be the computer itself, the battery, the charging system, or the outlet you are using to plug into.
That said, begin by shutting the computer down and removing the battery for two minutes. That will reset some parameters and may solve your problem.
While you are waiting the two minutes, plug something else into that outlet, say a lamp just to be sure there is power there. If there is no power then go to your electrical panel and check the fuse or circuit breaker, which ever you have.
Now plug the computer in, still leaving the battery out and turn it on. if it operates that way unplug it again and reinstall the battery.
If the computer works on direct electricity but not on battery you could consider buying a new battery.
Regards, Joe.
Posted on Nov 12, 2009
Our packard bell easy note te69kb laptop is stuck on shutting down screen as if it didn't close properly when last used
I suspect there has just been a windows update and it is confused. If it won't close down, hold the power button down until it does and than re boot. The issue should clear.
Mar 25, 2016 | Packard Bell Computers & Internet
Which key do i press to switch on wireless on my packard bell laptop. Thought it was alt and F4 but does not work.
Packard Bell Easy Note E2 ---- Fn / F1
Packard Bell: easy-note MV46/008 ---- Fn / F1
Packard Bell MZ36-U024 ---- Fn / F2
Easy note W7730---- Antenna like wireless button on the side of the laptop.
(Press & Hold Fn Key and Press F2 or F1 key) ... :)
Mar 14, 2011 | Computers & Internet
The mouse of my laptop Packard bell is locked. how
On the top of the keyboard you can see a picture of a Hand on a rectangle which should light up press is once , touchpad will be working fine !
Jul 03, 2010 | Computers & Internet
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
You may need to get a new power supply!
May 05, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Packard Bell Easy One Silver monitor problem
Hi there.
You need to be looking at the inverter, this is a very thin circuit board located underneath the screen so you will have to remove the plastic bezel (screen surround) check the connections on that. If the screen is still white look at the inverter itself because there could be a dry joint or the coil has gone, if you are confident with a soldering iron then re-solder all the points on the inverter circuit board and try it again.
Good luck and thanks for using FixYa!!
Mar 11, 2009 | Packard Bell Easy One Silver 2120 Notebook
Key pad mouse and touch pad not functioning
I have a laptop packard bell easy note a8730 and
laptop touch pad doesn't work properly @ get m
Dec 29, 2008 | Dell F3534 Touchpad
Fn key is constantly on
i just solved this problem today on my packard bell easy note all you have to do is hold the FN key and press NUMLK and then it should work
Dec 20, 2008 | Compaq Keyboard
Packard bell easynote keyboard not working
my keyobard won't work on my packard bell laptop
Nov 23, 2008 | Packard Bell Easy One Silver 2101 Notebook
Dell Inspiron 9300 Notebook Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
