Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon mp600 printer repeated error code 6B00
None of the usual suggested fixes works. The printer buzzes then shows error code 6B00 print head appears to be jammed
After reading through earlier problem fixes, I inserted a piece of Card right through the feed system then taped all the covers and loose paper feed trays closed with masking tape. Picked the whole unit up, turned it upside down and shook it up and down and side to side quite hard. Put it back in place on the desk, undid all the tape and plugged both cable back in and switched it on. It went through a long startup process, spat out the card sheet and has worked OK since then (about 15 sheets printed).
Thanks for all the ideas in earlier fixes.
Posted on Nov 13, 2009
I'm getting a message all of a sudden that "the type of print head is incorrect. Install the correct print head." I have not doen anything to the printer to change the print head that has been working...
It means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
May 19, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I have problem with my mp600, in the lcd displayed error code u52. how to fix it?
This means The type of print head is incorrect. Install the correct print head." U052
The solution is follow the directions given in the Easy Setup Instructions to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it.
If the error is not resolved, the Print Head may be damaged and may need replacing.
Oct 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
IP4000 service error 6B00
6B00 is a paper feed error, look in the back with a mirror and flashlight, and see if something has fallen in where you put the paper for printing.
Jul 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon printer not printing and gives error code U052
you have a purge unit problem, cost more than the printer is worth unless it is under warranty,
Canon small printer technician
Mar 31, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 all in one inkjet printer
error code u052 is a print head error that means the print head is faulty If unit is still under warranty should cover the printhead. Go ahead and call canon support number for your region or go online to canon website for closest Authorized Service Facility and they will take care of it for you.
Good luck
Sep 19, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Pixma mp600 error code u052 ,type of printer head is incorrect. Need to know how to remove & reinstall as pre instructions on page 69 of manual
Got the error U052.....with incorrect print head. Has been printing just before. How do I remove the printhead and place it back in. My printer is Canon MP610
Jul 26, 2008 | Office Equipment & Supplies
Error code 6b00
THESE ARE THE STEPS
1. Turn off printer
2. Hold down Resume button n pres Power button.
3. Keep holding down Power button nd let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Jul 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Error Code 6B00
Thank you so much.  I was getting so frustrated and finally decided to shake the printer even harder.  Absolutely AMAZING!!  Thanks again.
Sep 04, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
420 people viewed this question
old marine
old marine
