Question about Kenwood Protalk XLS TK-3130 (2 Channels) 2-Way Radio
Vox wont activate on new tk-3301Headset functions as it should, but following manual, the vox function will not activate
Tk3301 has 8 preset channels but has 16 channels, what are the other channels for?
Posted on Mar 22, 2010
I have a Kenwood tk-2212L. I am unable to transmit via my lapel PTT microphone. I can however hear dispatch & other units. How do I activate VOX? Any suggestions?
Not all devices are VOX compatible. Some audio accessories with inline PTT buttons fall in this category. One thing you can do is be certain to have the radio turned off when plugging in the device. Check your user guide for VOX instructions and double check the compatibility of lapel mic.
Feb 07, 2015 | Kenwood Radio Communications
Vox blc 007b
Hi gurukataria, you can use the china made DVD/CD player remote's which have same key functionalities as the Vox BLC007B had. They are easily available in electronic shops.
Feb 09, 2014 | Office Equipment & Supplies
Can get headset to work right
check your radios settings, this should be available in a menu on the radio... the user manual does not show a setting for non vox operation of the head set, (as this maybe a version difference it may be available in the menu) so if it is not available in the menu with the rest of the settings it is not an option.
Oct 22, 2013 | Motorola Walkie Talkie 2-Way Radio
We recently purchased the MS350 radios and are trying to use them handfree with the headsets. We plugged in the headsets, turned on the radios, but are unable to communicated back and forth using the VOX...
The three things which come to mind are:
1) Is the headset the VOX headset intended for the radio model? Sometimes the rings on the plug do not match the internal points of contact if it is not the intended headset. Not all headsets are VOX capable.
2) Is the headset plugged in all the way. (You mentioned plugging in and then turning on. This is good. You must always have the radio turned off when plugging or unplugging an audio device.)
3) Try pressing the PTT on the headset cord one time before switching the dip switch to VOX. (Assuming you have a headset with the small box in the line.)
Check your VOX/ iVOX settings. You will need VOX for using an audio device.
Lastly, if you continue to have difficulties, contact Motorola at the 800# provided in the user guide. They should be able to assist you.
Best regards.
Sep 23, 2013 | Motorola Hands-free Headset,for 2-Way...
Hi. the mobicam keeps turning on and off and the light is flashing?
What does the VOX switch do?
When the VOX function is active, both the LCD screen & Audio turn off and will automatically reactivate when there is
noise in the room being monitored (e.g. baby crying). This feature is useful at night so the light coming from the screen
doesn't bother you and also when running the MobiCam Ultra receiver on batteries since it will extend the life of the
batteries. Note: The VOX function will not work when batteries are low and you cannot change channels on the receiver in
the VOX mode
Jun 14, 2011 | Mobi-Cam Mobi AV Monitor
My Mobi-cam keeps turning off by itself. What is
This is from the Mobi Camera Manual
Q. What does the VOX switch do?
the VOX mode
Sep 17, 2009 | Mobi-Cam Mobi AV Monitor
TK-3202LU16P Radio
Hello ppaseka,
The Kenwood TK3202 onky supports VOX use with three specific models of Kenwood headsets: the KHS-1, KHS-21, and KHS-22. You will want to ensure that you are using one of these three headsets and that the Push-to-Talk is set to the VOX position.
Additionally the VOX function must be enabled in the radio. This can only be done by the dealer programming the radios. If the Voice Operated Transmit function was enabled by dealer who sold the radios to you then you may still need to set the VOX sensitivity level to ensure that function is sentitive enough to register the user's voice. The steps to setting the VOX sensitivity level are located on pages 20-21 of the radio's users manual which is available for download here.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 26, 2008 | Kenwood Radio TK2200 TK3200 Compatible...
Headset problem with Uniden 1558
Determine if this is a VOX problem or a headset problem.
Turn off the VOX. Does the headset work for normal transmit and receive?
Remove the headsets. Do the radios work normally on speaker?
Plug one headset in And test with the (other) radio in speaker mode. Does it work? Now turn on VOX in this mode (yes it will work this way). Does vox work (put you mouth right on the mic)
If so swap headsets and try the other.
If one Hset works but not the other its the headset. If neither works its likely the radio ..but before you decide try the same headset experiment on the other radio. Find out which of the 4 devices the problem follows.
Happy New year
Dec 24, 2007 | Uniden GMR-1558 / 2CK 2-Way Radio
Operating Manual
To turn off sound activation press the menu button 3 times to enter VOX mode. The VOX icon should be flashing, then press the down button till the number of bars dissappear. Press the menu button to confirm the VOX off mode. You also can adjust the sensitivity of the VOX mode by how many bars are displayed, less bars equal less sensitivity. No bars and voice command is deactivated. Hope this helps. Ed
Dec 11, 2007 | BellSouth 2250BK (22 Channels) 2-Way Radio
Earbuds
If you are using vox (voice activated transmit) go into the menu and make sure you don't have the VOX setting too high. You should be able to put the headset on... hit the "push to talk" button on the radio and transmit you audio. Turn the other radio on and make sure the radio is "keying" (tx with no auio) then make sure there is audio. If you don't have audio but the radio is transmitting.. you might have the wrong type of plug on your headset for the audio..... there are 2 plugs... 1 for transmit audio....1 for recieve audio. It could be the wrong type of plug for the jack in the radio. Regardless.. the way the headset works is either you push the "push to talk button" onj the radio OR you use the VOX function... with the vox function you just have to talk into the mic to transmit. This is what your headset is designed for. You will have to go into the menu and set up the radio for VOX. If you still have problems follow my directions at the top of this page ( check mic jack and stuff) I think you just have to set the radio up for VOX operation and set the VOX setting. You should be able to push the push to talk button and talk through the mic on the headset. If you don't get any audio that way there is a problem and you should check the jack and plug on the headset.
Aug 25, 2007 | Motorola Talkabout T5720 (7 Channels)...
Kenwood Protalk XLS TK-3130 (2 Channels) 2-Way Radio Logo
353 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
