Question about Canon Office Equipment & Supplies
An error occurred. Some ink cartridges cannot be recognized.
    President:
  • 414 Answers
Did u changed / replaced the cartridge with original spare or refilled it??
do not panic..this kind of problem often follows with (esp. an unbranded) cartridge change and or refilling..!!
it also can be the defective cartridge itself causing such problem..!!
well if u r a professional then just dip a cotton into isopropyl alcohol n gently rub the connector sensor/ contact surface, n reinsert it properly, gently rub on the head too n make sure ink is coming/flowing, make sure the toner is not jammed or dried up, also have a glance on the 'carriage' n see that no sensor pins are broken and or bend..!!
..if u r not an professional, make sure it is properly inserted and the ink-spill protective/head covering is removed..
if all the above fails, then it may b a defective or demo cartridge..!!
and call ur system admin....
Posted on Nov 12, 2009
Testimonial: "thank you let me see "
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
Tip
I am having canon pixma ip1300 inkjet printer. it worked properly till 13th...
Things you will need.
Needle nose pliers.
Paper towels
97% rubbing alcohol
Plastic gloves.
Flashlight
Disposable waste container, lined with plastic.
Disposable plastic tray about 6x9 or thereabouts.
Plenty of ventilation, outside if need be.
a. With the printer on, open this lid as if to change cartridges.
b. Turn Printer off. Unplug the printer. Unattach the communication cable. You will be moving it to a work area with excellent ventilation, such as outside.
c. At the far right where the the cartridges normally park themselves when not printing you will see a platform with rectangular compartments. When the cartridges park, this platform rises, seals off the nozzle area and captures any leaking ink, which till happens today.
d. Examine the platform with your flashlight and you will see what looks like sponges in the compartments. This material with holes in it, like a sponge, is plastic.Put on your gloves.
e. Place a paper towel folded over on itself underneath this platform as best you can to catch any spilling ink.
f. Use paper towels soaked in alcohol slightly and your needle nose pliers to push
the paper towel into each compartment, gently at first, until the majority of ink is
removed.
g. This will take quite a long time and plenty of paper towels and patience. So be
patient and ready for the long haul. Avoid smoking and the fumes.
h. At some point the sponge material, itself, may become dislodged and loose.
When you witness this, go ahead and remove it carefully using your needle nose
pliers and place it on some paper towels placed inside your disposable plastic tray.
i When you have one or both, if needed or more sponges removed and in the tray,
pour alcohol over these until the ink runs pretty thin. Leave to everything to dry.
i. Use a paper towel damp with alcohol and your pliers to clean out the compartment and its sides as best you can.
j. When you have completed these tasks allow the compartments and sponges to dry.
k. You are ready to reassemble the sponges into the compartments. Do so now.
l. Nearly done; take a towel wet with alcohol and hold it very gently against the bottom of the ink cartridge until ink flows freely onto the paper towel. If its stubborn, knock
the cartridge gently but sharply against a hard surface with the alcohol soaked towel held against the nozzle area.
k. Re insert the cartridges now.
l. Return the printer to its working location, attach power, attache the comm cable and with the lid closed apply power.
m. Run your printer through its normal setup routine, deep clean the print heads, run a nozzle check and finally do a print head alignment.
m. Your Printer is now ready to be used again.
Thank you,
Worldvet
on Apr 15, 2009 | HP Officejet 5610 All-In-One InkJet...
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Whats the meaning of error in canon e5 error?
"E5: The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur."
Jul 22, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Problem with my canon printer ip1300
You can try this it works for my 1500 printer.
Go to the printer settings and turn off the ink low messages.
Switch your printer on and hold the paper feed switch down for the count of five the orange light should flash. Then switch off the power and switch back on again the green light should stay steady. If you do not come right on this one you can email me at grayjem@mweb.co.za
Aug 10, 2009 | Canon PIXMA iP1300 Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Printer error requests that a full ink tank is empty.
You can try cleaning the electrical contacts in the printer and on the cartridge with isopropyl alcohol followed by water to see if that fixes it. Then you can try removing all your cartridges, turning the printer off, unplugging it, waiting a few minutes, plugging it back in, turning it on, and waiting for the printer to recognize there are no cartridges installed before you reinstall the cartridges. Otherwise you may have damaged the chip on the cartridge with static electricity when installing it. If this is a new cartridge I would return it to the store you purchased it from and ask for a replacement.
Jan 26, 2009 | Canon iP3500 Photo Printer
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
131 people viewed this question
old marine
old marine
