Washing machine stopped mid cycle there is no lights on main control panel.fuse in the plug is ok been told it could be the main printed control board.
  • Anonymous Mar 27, 2014
    the main panel is blank how do you reset
    Genius:
  • Washing Mach... Master
  • 1,467 Answers
Could be mains switch/ Door interlock dead?..If you have multimeter you can easy check..
Posted on Nov 12, 2009
Why did my washer stop mid cycle and now won't work at all?
Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
Aug 21, 2014 | Zanussi Washing Machines
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
W6444
make this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 25, 2013 | Washing Machines
Hi Indesit IDL700 Dishwasher. Stopped mid cycle by
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
Sep 05, 2011 | Dishwashers
Washing machine died mid cycle with no LED function. Have checked mains fuse and power input and are ok.
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 01, 2011 | Washing Machines
Maching stopped mid cycle & now has no power, it will not turn on, all fuses are ok
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 02, 2010 | Hoover Washing Machines
Kenmore Elite Oasis - stopped mid-wash!
run it through a diagnostic test cycle; with unit plugged in, but not in operation, press and hold the rinse button for 4 sec, then release for 4 sec, press for 4 sec, release for 4 sec, press for 4 sec,then all the lights on the main control panel will come on indicating enterance into diag mode, let this test cycle through until you get an error code, then correspond that error code with the one in your owners manual and correct as needed, or if there is no error code, check the drain pump by removing the back panel of the unit while there is no power to the unit and disconnecting the hoses from the drain pump and checking for any blockage... if that checks out ok, you may have a software problem and should test these as needed per the service manual that you can order at sears for your unit.
Aug 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool dishwasher stopped mid cycle
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Aug 10, 2008 | Dishwashers
Hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
Feb 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
