Always says the door is locked and wont fill with water Front loader
  • 460 Answers
Washer needs a new control module. call a serviceman.
Posted on Nov 12, 2009
My wcvh6260fww front loader washer wont fill up with water
check the water valves then the screens in the hoses. if those are on and clean then the electric valves probably have burnt out and need replaced OR it is the DOOR LOCK has failed
Feb 18, 2017 | Washing Machines
How do I increase water level in my wfxd8400uc?
I get this complaint a lot from home owners , I take it you have just got your first front loader washer , and you don't think it adds enough water to wash anything , this is the water saving feature of front loaders
but a simple test I tell most folks to do if they think there water level sensor is not working right
set washer to auto load sense on water level , normal wash cold water, permapress add nothing to drum completely empty! no soap unless you have a auto soap dispenser then it wont start to you add some and close door
start cycle wait till fill is complete just as it goes to agitate stop cycle (plug can be pulled for this if buttons have locked out )and open door see if water level is two fingers wigth under door seal , if its close your ok if it's a long way off then contact a repair department to look at auto sense water level
May 07, 2015 | Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
Why wont my washing machine fill with water?
If its a front loader it may be the door lock sensor not telling the unit it is locked. if you get the model number you may be able to put the unit through a self test. check on googlrewith the model for a procedure
Dec 22, 2011 | Washing Machines
Machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Jan 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer does not fill at all
Have you checked the filter just inside the water hoses. You just turn off the water and unfastenent he hoses from the machine and you will find a little filter. It may be clogged with lint, sand, etc.
Jul 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Door lock
Check for loose wires in the door lock; or replace door lock.
Dec 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
