Question about Asrock GE PRO-M2 Motherboard
When traying to instal windows eror MSDOS Extender
  • 81 Answers
Check the cd and the hard disk.
Posted on Nov 13, 2009
E000580-0000 solution of this eror when machine show this on display then what i can do to start the machine properly
Appears to be a problem with the finishing tray attached to your copier - disconnect the tray from the copier (pull it away and unplug it), restart and see if you still get the message. You will need to have a tech fix the problem with your finisher tray, but you might be able to make use of the machine without it until then.
Sep 09, 2014 | Office Equipment & Supplies
Why is my verizon router extender flashing red really fast
The red flashing light shows there is an error. Which lights are flashing would tell you more about the eror
Aug 29, 2014 | Computers & Internet
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
Hpf4400 trat extension
I figured it out today. There is a plastic "catch" between the two halves of the paper tray (where the extender was stored). Grip the sides of the extender and wiggle it around firmly but carefully in different directions. You should eventually get the correct angle so the catch releases and you will hear a "click". Then the extender folds easily back inside the paper tray.
Feb 23, 2013 | HP F4480 All-In-One Printer
What is ms dos command prompt
MS-DOS stands for Microsoft Disk Operating system. Its has CUI(Character User Interface) unlike Widows which has GUI(Graphical User Interface)
Which means you need to type commands in MSDOS. In windows we see icons, folder etc to work using mouse but MSDos is different.
To open MSDOS
Click Start goto Run - Type CMD and press Enter (for Windows XP) Click Start - Type CMD in search - Click on CMD (For Windows Vista and 7)
Jun 22, 2011 | Computers & Internet
Hello, I have a question about the HP 1312 all in one printer. Does it print on legal size paper and where do I load the legal size?
Yes, it can print on legal size paper. Do the following:
Lower the paper tray, and if necessary, slide the paper-width guide to the outermost position.
Fold out the paper-tray extender to catch paper as it exits the device.
Tip: For best results when loading legal-size paper, fold in the paper-tray extender before loading the paper to avoid a paper jam.
May 13, 2011 | HP Office Equipment & Supplies
Printer will not scan pictures.
Introduction To use the scan features, the HP All-in-One and computer must be connected to each other and turned on. The HP All-in-One software must also be installed and running on the computer prior to scanning. To verify that the HP All-in-One software is running on a Windows computer, look for the HP Digital Imaging Monitor in the system tray at the lower right side of the screen, near the time. NOTE: Closing the HP Windows system tray icon can cause the HP All-in-One to lose some of its scan functionality and result in a No Connection error message. If this happens, correct it by restarting the computer or by starting the HP Image Zone software. Follow the instructions below to scan documents from the all-in-one to an application. Make a Scan Step one: Load paper
  1. Open the paper tray door. Figure 1: Opening the paper tray door c00315283.gif
  2. Pull the paper tray extender toward you, as far as it will go. Flip the paper catch at the end of the paper tray extender to open the extender the rest of the way. WARNING: Legal paper might get caught on the paper tray extender if it is fully extended when you print onto legal paper. To avoid a paper jam when using legal-size paper, do not open the paper tray extender.
  3. Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide to its outermost position. Figure 2: Sliding the paper-width guide to the outermost position c00315284.gif
  4. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
    • Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
    • Make sure all the paper in the stack is the same size and type.
  5. Insert the stack of paper into the paper tray with the short edge forward and the print side down. Slide the stack of paper forward until it stops. NOTE: If using letterhead, insert the top of the page first with the print side down. For more help on loading full-size paper and letterhead, refer to the diagram engraved in the base of the paper tray. Figure 3: Inserting paper into the all-in-one c00315285.gif Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Sliding the paper-width guide to the edge of the paper c00315286.gif Do not overload the paper tray; make sure the stack of paper fits within the paper tray and is no higher than the top of the paper-width guide.
Step two: Load the original NOTE: Many of the special copying features will not work correctly if the glass and lid backing are not clean.
  1. Lift the lid and place the original face down on the left front corner of the glass, with the sides of the original touching the left and bottom edges. NOTE: For more help on loading an original, refer to the guide engraved under the glass.
  2. Close the lid.
Step three: Scan to an application NOTE: To use this feature, you must have installed the full software package and the HP Digital Imaging Monitor must be running.
  1. Press Scan on the control panel. A preview image of the scan displays in the HP Document Viewer window on the computer, where you can edit it.
  2. Click Done or Finish in the software. The HP All-in-One sends the scan to the HP Image Zone software, which automatically opens and displays the image.
NOTE: To stop scanning, press the Cancel button on the control panel, or in the HP Image Zone software, click Cancel . Have a good day,
Jun 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Gone into safe mode cant change mode?
1. Click Start, point to Find, and then click Files or Folders. 2. In the Named box, type msdos.sys. 3. In the Look In box, click the drive on which Windows is installed (usually drive C), and then click Find Now. 4. Right-click the Msdos.sys file, and then click Properties. 5. Click to clear the Read-Only and Hidden check boxes to remove these attributes from the Msdos.sys file, and then click OK. 6. Right-click the Msdos.sys file, and then click Open With. 7. In the Choose the program you want to use box, click WordPad, and then click OK. 8. Do one of the following: • Delete the BootSafe=1 line.
-or- • Change the value in the BootSafe=1 line to BootSafe=0. 9. On the File menu, click Save. 10. Right-click the Msdos.sys file, and then click Properties. 11. Click to select the Read-Only and Hidden check boxes to set the attributes for the file, and then click OK. 12. Restart your computer.
Apr 16, 2008 | Video Cameras
Rebuild
A PCMCIA CD drive will work, but only some models. Toshiba makes one, and it would be your best bet.
Dec 05, 2007 | Toshiba Portege 3490CT Notebook
Asrock GE PRO-M2 Motherboard Logo
37 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
