Question about Lexmark E321 Laser Printer
I cannot get my printer to work it says Printer
I cannot get my printer to work it says "Printer not responding"
Its not the leads, its something else ?
    Master:
  • 969 Answers
  • Lexmark Master
  • 3,247 Answers
The details you provide are a bit sketchy but will try my best to help.
If the "printer not responding" message is coming when you go to print from the application like Microsoft, then exit from there.
Go to control panel in Windows (depending on which version). Double click on the Printer icon and see if the printer shows in the list on the screen and is on-line. If it shows but is off-line then select the online button on the printer and see if it appears. Right click the mouse on the printer name on the screen and select preferences. At the bottom you have the Print Test page. Click and see if you get a page printed.
If the above is not good, then check if printer is getting the power and re-install the printer software from the CD.
Posted on Nov 12, 2009
Canon mx452 printer not responding to Windows 7 Dell Dimension E521.
if you haven't tried this , try downloading the driver again for the printer
May 07, 2015 | Canon Office Equipment & Supplies
Why does my canon mg5420 say "printer not responding"
Whenever I hear of a "not responding" problem in the same sentence as "Wi-Fi" I question the wireless connection. I'm sure you've done the tests, but just to go over them; Is the printer working - can you get a test print out of it locally (setup)? Is the computer actually "talking" to the printer (Check network settings and local connections)? And, can you connect directly to the printer using a USB lead - and get a print? I would be tempted to tell the computer to find a new printer, in order to double check.
Jun 29, 2014 | Canon PIXMA MG5420 Inkjet Photo All-in-One
Epson DFX 900 printer popping error 0F and asking to shutdown oftenly
It ispossible that the printer had encountered a software error and so responds otherwise. so to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels. Make sure the connections are tight and the power supply is good. Check the connecting leads.
Use head cleaning before a test is taken
Apr 06, 2011 | Office Equipment & Supplies
Dear sir or mam ,i m having argox GE200 barcode printer which is not responding. when m giving print no response from the printer and any error also not showing.wat to do?
Hi.. Just follow these steps, hope this may trouble shoot your barcode printer.
1) Restart Your Computer/ Barcode Printing S/w / Barcode Printer/ and try now.
2) Even if it does not work, check the cable connectivity with printer and system
3) Even it is not working, try printer calibration or labels feed options in printers.
4) Check the proper sensor adjustments in printers,
Hopefully this should help you to get back your barcode printer online.
If you have any other queries with barcode printers, please email/contact us.
Regards Kirubakaran.Rv Web Marketing Manager Trridev Labelss Mfg Co Leading Labels Manufactures In Chennai Mobile - 96000 07995 www.trridevlabelss.com email kirubakaran.rv@gmail.com
Sep 03, 2010 | Argox OS-314 Label Printer
Printer won't turn on...is plugged in and has been printing well.
hi, have you tried checking, changing the fuse in the plug.
check the lead is fitted correct.
as for the fuse is the printer running of mains lead or just of the usb lead let me know, if its mains the unplug the lead that goes to your comp and then try it with just the power lead plugged in to see if that makes the differance.
Check the mains lead works try it on something else if you can if its running off only the usb lead then the lead may be at fault.
Let me know then i can assist you further ok
Nov 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Dell 968 printer not responding message please help
try unplugging the printer and plugging it back in, also do you have the printer set as the default printer
Apr 26, 2009 | Microsoft Office Professional 2007 Full...
Canon ip 3000 saying printer not responding
when you disconnect the printer from your pc does it make a sound? also check File - Print - ( is the printer you are using highlighted? If no, right click and set as default. If yes, right click and see if it says "ready" when disconnected it should say "offline"
Which means the USB and the connection is OK
Look at the bottom right ot the screen is there a printer Icon there? if yes right click and see if there are any jobs pending, delete all jobs.
Otherwise it may be the driver which you may have to re-install.
Jul 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Open Questions:
Lexmark E321 Laser Printer Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
