Question about Necchi Sewing Machines
Necchi 514 - winding the bobbin
I have a Necchi Lelia 514 and a problem with winding the bobbin. The small arm on which to sit it will simply not give in and I cannot imagine there would be so much more force needed to do it. What am I doing wrong?
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Posted on Mar 14, 2009
  • 6 Answers
SOURCE: need parts for old Necchi Lydia 3 Sewing Machine
GO 2 STAPLES
Posted on Jun 16, 2008
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
SewTechWayne
  • 186 Answers
SOURCE: problems winding bobbins on my singer 4622 sewing machine
I have two possible solutions:
1. you have the wrong bobbin and it doesn't grip the winder.
2. the small spring on the winder spindle is missing or bent, it is what applies pressure to the bobbin for winding.
good luck!
Posted on Jan 31, 2009
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
Dec 05, 2016 | Necchi Sewing Machines
How do I wind a bobbin?
Actually, $10 for a manual is probably a valuable investment. It will not only help you with threading & winding the bobbin but also with maintenance and care of your machine and as well as how to use your machine. Similar brand machines thread and wind the bobbin in the same manner. So, even finding a similar Necchi and the bobbin winding method should be helpful.
Necchi bobbin wind Google Search
Oct 17, 2016 | Necchi 3101 Mechanical Sewing Machine
Necchi Lydia 3 544 Bobbin mechanism will not fully disengage to allow a return to sewing.
Under the lid you will find the bobbin winding stem and the mechanism that is meant to "flick" home when the bobbin is full. This mechanism may be sticking. It may need a small amount of lubrication.
It may need tweaking with small pliers to make it work as the bobbin stem often gets knocked off line when moving the machine and this stops the mechanism from working smoothly.
Jul 14, 2016 | Necchi Sewing Machines
Necchi 4825 bobbin winding problems
tell me exactly what you do when you want to rewind a bobbin. I got an old singer that will not sew but it makes a great bobbin winder for all the other machines .
May 12, 2015 | Necchi Sewing Machines
How to wind the bobbin on a 3577 necchi
here is a link for a manual, it should have the information about winding a bobbin
http://www.sewingpartsonline.com/instruction-manual-necchi-3577.aspx
Oct 05, 2013 | Sewing Machines
I have no instructions book I would like to thread and what kind of bobbins do I need
you might try a google image search for that make and model... generally speaking, machines thread right to left, top to bottom.
May 26, 2009 | Necchi Sewing Machines
I want to find a manual for a Necchi Lelia 513
Greetings lindalime,
This might help you,
http://www.thetreadlersvillage.com/NecchiLelia513manual.html
Thank you,
Dorothy
Go Ahead. Use Us.
Jun 18, 2008 | Sewing Machines
Sewing Machines Logo
108 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
