Question about Panasonic CT-36HX41 36" TV
My panasonic tv wont turn on or do anything - Panasonic CT-36HX41 36" TV
  • 10,865 Answers
Hello. I can assist you. First of all, unplug the TV and plug something else into that outlet, say a lamp, or a blow dryer. This way, we will know for sure if the problem is the TV or just the outlet. If the outlet has no power, check your house electrical panel and either replace the fuse with a new one of the same amperage, or turn the circuit breaker full on then full off and then full on again.
Let's assume that the power is ok. Now to the TV itself.
ONE: If you are using a power strip, check to make sure it has not tripped out. Mostly they have a reset button somewhere on the bar.
TWO: Also, check the line cord. Wiggle it near the molded ends - which is where the greatest of open circuits happen.
THREE: Unplug the tv for 30 minutes and try again. This will reset the power protection circuit.
FOUR: If all above does not get you anywhere, then the problem is likely an internal failure of one of the key sections of the tv. The power protection circuit is constantly monitoring the current drain and shuts the set down when too much current drain is detected. Culprits are the deflection circuits (including the high voltage generator call the flyback in the horizontal deflection amplifier), audio amplifier and main power supplies.
FIVE: If the problems turns out to be an internal failure of one of the sections above, then replacement of the set may be the better choice. Conventional 27" sets are available in the discount stores for $149 and up. Flat screen 27" are $277 and up. If you must replace the power transformer, for example, in your set the cost will be upwards of $200 to $250. The flyback would run about $100.
Regards, Joe.
Posted on Nov 12, 2009
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Plasma tv wont turn on after static shock
The TV might have overheated. Contact the authorized service centre. Gopakumar Gopalan Google
Protection mode is now ON. If you know how to set it OFF, can do.
Mar 27, 2014 | Panasonic TCP46C2 46 in Plasma TV
My panasonic up/down channel buttons on the side of the tv wont work
Try getting a Harmony remote control. It will operate your tv and anything else you can connect to it. When the TV gets too old to fix, the remote can be reprogrammed for the new TV, so it never gets obsolete. The remote is programmed from their website.
Mar 20, 2014 | Panasonic Televison & Video
New circuit board in plasma tv panasonic but still blinks 10 times wont come on
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Mar 02, 2013 | Panasonic TCP42C1 Plasma TV
We have a Panasonic Plasma TV and are experiencing TV signal issues when our Bose sound system is turned on. Is ther anything we can do to improve the signal when the Bose is on (signal fine when we t
Move the insulated cables for the bose away from the cables to the tv. Or go buy monster cables for the TV so there wont be interference. Sounds like power cables are interupting the picture.
Sep 20, 2012 | Panasonic Televison & Video
Panasonic tv model tc-p42c2 remote is inop
It is a common thing that all the buttons of a universal remote control might not work, as it meant to be. Try an other code. If this too won't help you, there is no other way than buy a new original remote control for your Panasonic TV. You can buy in from the authorized service center for Panasonic at your town. Just give them the exact model number to your TV. They will provide you the original one.
Jul 20, 2012 | Panasonic TCP42C2 42 in TV
My Panasonic Model: THL32U20A will not respond. You can turn it on manually (not by remote) and once turned on, nothing works, IE: remote doesnt do anything and you cant even change channels or volume etc...
I too have exactly the same fault. The Tv even turns itself on in the middle of the night, i have to unpug it from the wall. It has been in for repair 3 times now, one guy said there is nothing wrong with it. I am keen to hear if anyone has had this fault resolved.
Thanks
Darren
Mar 13, 2011 | Panasonic TH32LRU20 32 in LCD TV
Can't get my Panasonic LCD out of Standby.
I only have two solutions. Either, turn the tv on from the tv. or try checking the tv connection. If that doesnt work maybe the remote is out of battery.
Sep 14, 2009 | Televison & Video
Tv wont turn on> is there a reset switch?
reset button can apply when the tv turns on. first the tv has a short circuit and has to be repaired in order to be able to reset the tv to the original settings created in the program as brightness, color etc.
your tv now needs a visit to the workshop first, to turn on.
Apr 14, 2009 | Panasonic PT-51HX40 51" Rear Projection...
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Panasonic CT-36HX41 36" TV Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
