SOURCE: Sharp AR 5316
It worked thanks alot.
All I did was to press the #,interrupt,c,interrupt in sequence. The display then went off.
I then press the numeric keypad 1,4 and start botton in sequence.
It's fine now.
A big thanks
Ometan Goodluck
Nigeria
SOURCE: Sharp -COPIERS - AR-5316
If you go to this web page:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
You should be able to find the driver for that machine.
Hope that helps.
Lbcoaster
SOURCE: Sharp Photo Copier AR 5316
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
E7-11 Shading troble(whife
correction)
IMPRPER
CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE
copy lamp lighting abnormality
ccd
unit abnormality
MCU
PWB abnormality
(when occurred in the scan position)improper installation of the mirror
unit
Testimonial: "than u sir every time i had problem u are helping me sir thank you so much sir"
