Question about Krups Small Appliances Espresso Machine
Fuse trips when the on button is pressed - Krups Small Appliances Espresso Machine
  • 10,865 Answers
Hello. I can assist you. First I want you to take your appliance to another part of the house and plug it in. Turn it on there and see if it trips the fuse. It is possible that the location where you usually have the appliance plugged in is a circuit that is over utilized already. Here is what I am referring to: Most circuits are either 15 AMP or 20 AMP circuits. This means that they have a maximum of 15 or 20 Amps of power available. That translates to 1500 or 2000 watts. Now let's say that same circuit already has a microwave plugged into it, or a refrigerator, or a lot of lighting. It could be that your appliance merely drives the demand beyond the available power.
That said, the other issue is the the appliance itself. It is possible that the unit does have a bad component which would result in a short circuit which would pop your fuse or your circuit breaker.
And finally, it is always possible that the problem is within the circuit itself. If you have a circuit breaker, they do wear out and have to be replaced.
The final word is that you will have to use this information to check out each of these possibilities until you isolate the issue. Thanks for choosing Fixya! Regards, Joe.
Posted on Nov 12, 2009
  • 460 Answers
The heater element is shorted.
How to reset a service interval indicator on a 2003 mini one
Resetting Oil Service Light on your 2002 - 2006 Cooper and Cooper S Hatchbacks, and 2005 - 2008 Cooper and Cooper S Convertibles:
1) Press and hold the trip button
2) Insert key and turn to position 1
3) Watch for RESET to appear
4) Release the button, then press & hold it again
5) Wait for the RESET to flash
6) Release the button, and then press & release (once only)
7) Service interval should then be reset to next interval
If that didn't work, try this:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
Or this:
1. Press and hold the trip odometer button.
2. Insert car key and turn it to the fi rst position (not the second position).
3. You will see 51A come up in the trip odometer area.
4. Release, then press and hold again.
5. Watch for the word "RST" to appear on the Odometer indicator.
6. Release, then press and hold again.
7. Wait for the "RST" message to fl ash.
8. Release, and then press & release (once only).
Jul 01, 2014 | 2004 Mini One
Tip
Pontiac service light 1983-01
Firebird
1998-01
To reset the "CHANGE OIL" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and goes out, the system is reset.
Grand Am
1999 -01
To reset the Change Oil light, open the driver's side instrument fuse panel and turn the ignition on. Press the "RESET" button and release. The light will flash. Press the button again and the system will be reset.
Grand Prix
1999-01
Driver Information Center If Equipped). Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the ignition key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure. To reset the OIL LIFE indictor if equipped with a Trip Computer: Press the trip MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to be 99 percent.
Grand Prix
1997-98
To reset the oil life indicator, press the "MODE" button until the light next to "OIL LIFE" is lit. Press and hold "RESET" for 3 seconds until oil life percentage is 100%.
Grand Prix SE
1997
Turn the ignition on, but do not start the vehicle. Within 5 seconds, push the accelerator to the floor 3 times. Turn the ignition off. Start the car and the Change Oil Soon indicator light will be reset.
Grand Prix
w/ Trip Computer
1988-93
To reset "CHANGE OIL", "CHANGE OIL FILTER", or the mileage of either on the Trip Compute, continually press the "SERVICE" or "SYSTEMS CHECK" button until the item appears with the mileage below it. Then press the "RESET" button and the mileage will be reset to the maximum value. If you want to reduce this value, hold the "RESET" button down and the mileage will count down. Release the button at the mileage you would like to observe.
Bonneville,
6000
w/ Driver Information Center
1983-91
To reset "CHANGE OIL SOON" or "OIL FILTER" or to adjust the mileage on the Driver Information Center, continually press the "DIC" button until either message appears with the mileage below it. At this point, hold down the button. In 5 to 10 seconds, the mileage will count down. When it passes 0, it will cycle back to a maximum figure. Release the button when the mileage gets to the service interval you'd like to observe. If "CHANGE OIL" or "OIL FILTER" already appears, just hold the button down to reset the mileage. "CHANGE OIL" and "OIL FILTER" are reset separately.
on Dec 07, 2009 | Pontiac Grand Prix Cars & Trucks
How do I turn the Maintenance warning light on my 2020 Nissan Murano? I tried the manual indications to no avail. Thanks in advance. Leo
1. Turn your ignition switch on.
2. Press the Trip Computer switch until "Maintenance" is displayed. The trip computer button is located above the "Trip Reset" button and has a square graphic printed on it.
3. Press the "Select" button to enter the "Maintenance" menu. The "Select" button is above the "Trip Reset" button and has a circle graphic on it.
4. Press and hold the "Trip Reset" button for about 10 seconds until the maintenance reminder resets.
  • Apr 03, 2011 | 2009 Nissan Murano
    How do you turn off the "Car needs Oil Change"
    1. Make sure the trip odometer is NOT on 'Trip A' or 'Trip B' (ie: just the normal ODO). With the ignition off, press and hold the reset button. Press the 'Start' button twice without pressing the brake, but while holding the reset button. The dash will let you know its resetting, just keep holding the button until it is done.
    2. Make sure the Trip/Odometer is set to "trip A". With ignition off press and hold the reset button. While pressing the reset button, press the start/ignition button twice to turn ignition on. Keep watching the trip/odometer display to flash the lines (-----) until you see it flash the zeros (00000) then it
    Feb 22, 2011 | 2009 Lexus LS 460
    No power to viking microwave unit.tripped fuse in house and than reset fuse but doesnt work.
    Check to see if you have a "reset" button on your microwave, or even just by pressing the "clear" button first. Check to see if you have a "master" or "red" reset or "test" button nearest to your microwave on a light switch and reset that if applicable. You could also check to see if your unit has a fuse and replace that. It's possible when you tripped the fuse in the house you might have blown the fuse in the microwave.
    Oct 09, 2010 | Viking DMOR205SS Microwave Oven
    How do you reset the oil change required light on a 2004 Ion
    Press and release the trip/reset button until the oil life message is displayed.Then press and hold the trip/reset button until and chime is herd 5 times and reset is displayed in the message center.When the system is reset the odometer will be displayed in the message center.Turn the key to the off position.When you turn the key on if the change oil message is still there it did not reset.Retry again.Hope this helps.Good luck.
    Feb 17, 2010 | 2004 Saturn ION
    How do i reset my kilometer gauge after changing oil or does it reset to 0 automaticly
    Resetting Oil Service Light on your 2002 - 2006 MINI Cooper and Cooper S, and 2007 - 2008 MINI Convertibles:
    4. Wait 3 seconds
    5. Push trip button
    8. Push trip button
    Or this:
    5. Watch for the word “RST” to appear on the Odometer indicator.
    7. Wait for the “RST” message to fl ash.
    Apr 12, 2009 | 2003 Mini Cooper
    Mini dash
    4. Wait 3 seconds
    5. Push trip button
    8. Push trip button
    Or this:
    backbutton0001.gif Article Date: Jan 02, 2007
    Car Accociations: NEW_MINI
    Hits: 16731
    Jan 13, 2009 | 2002 Mini Cooper
    2004 Nissan Murano How do you clear maintenance light after oil change?
    press maintanence button until you see engine oil, then hold trip/reset button... :)
    Oct 03, 2008 | 2004 Nissan Murano
    Power tripping
    First off, lets make sure its not the wiring in your house. disconnect the dishwasher and plug in something else and see if it trips the fuse. also what amps is the breaker rated at?
    Nov 02, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
    Krups Small Appliances Espresso Machine Logo
    198 people viewed this question
    Top Krups Coffee Makers & Espresso Machines Experts
    Billy Mac
    Ross Keen
    Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
