Question about Amana SXD524VW Side by Side Refrigerator
Light is on inside, no cold air - Amana SXD524VW Side by Side Refrigerator
Which way do the orange and white wires go in relay on freezer side wiring around the back
Posted on Nov 12, 2009
I have a moretti elite portable air con and it's not blowing cold air it's second hand and a red light is on saying water full
Air conditioners remove humidity or water first, look for the bucket inside and drain it. or it is plugged and not draining.
Nov 16, 2014 | Heating & Cooling
I have a whirlpool unit model number ED22MMXRNRO the lights are on inside but the unit is nor cooling.
Is the fan inside the freezer is blowing air. But not cold air and it is regular air. If so then your compressor is not running or there is a cooling gas leak or line block.
Oct 14, 2014 | Whirlpool Refrigerators
03 grand am ac wont blow cold air
Two things are very likely to be your problem. Freon or compressor. Turn on the ac on cold and see if the compressor is engaging, if it is and stops and goes or if it doesn't. try to check the compression on the low side of your ac, the smallest plug where you service the ac. Or take it to an ac professional to get it refilled or checked. Remember, just because its blowing air, it doesn't mean its working. There are fans inside the car that push the cold air inside your vehicle and most of the time these will work, but that's not the only part required to blow cold air inside your car, the compressor is what makes the air cold.
Oct 09, 2014 | Cars & Trucks
I have a Electrolux Intuition plus freezer/refrigerator, and freezer is working properly but refrigerator isn't working anymore (but light inside still works) but it is not cold inside anymore, what...
A clog on the refrigerator side will cause that. Check if there's a lot of things loaded into it. Usually cold air from freezer will going down up to the bottom of the refrigerator if there's no hindrances or blockage like food stuff, fruits, vegetables, etc. load, it should therefore be cold.
Arrange correctly the things you loaded so it will not blocked the cold air dropping and it will reach the bottom side of the fridge.
Good luck.
Jun 24, 2011 | Refrigerators
2003 pontiac grandprix gt 3.8 , cold morning start loud noise
The Antilock Brake Hydraulic Control Unit is directly under the air cleaner box. Is your Antilock Brake light coming on?
Jun 22, 2009 | 2003 Pontiac Grand Prix
Wont get cold
check to see if there is excessive frost build up inside of the freezer on the back panel. If so you may have a defrost problem or your fan motor in the freezer may be bad. Open the drawer to the freezer and see if the fan comes on when you push the light switch. What brand is this unit?
Apr 01, 2009 | Refrigerators
2004 camry a/c
You have a faulty a/c snowflake switch or wiring broken that's why no cold air is coming in. This will not let the a/c compressor engage to give you that cold air you wanted. Your problem to be specific is from the fuse in which you said is good and through that a/c snowflake switch.
Aug 23, 2008 | 2004 Toyota Camry
GE side by side Refrigerator approx. 8 years old. Fridge side barely cold.
With your fridge, does the light go out when you shut the refrigerator door?
That could be your issue, that light running inside will create Alot of heat.
Also check to see if there is air circulating from the freezer to the fridge side through the damper. The damper is on the Fridge side left wall up towards the top. That is where the cold air gets to the fridge side. If that damper doesn't open that will also cause your problem, Let me know how you make out.
Bill
May 14, 2008 | Refrigerators
Both Fridge and Freezer not blowing cold air.
with the thermostat turned to its coldest setting can you hear or feel the compressor running?  Can you find the defrost timer inside the refrigerator and turn it until the compressor stops, and then please let me know, JT
Oct 24, 2007 | Amana AFD2535DES French Door Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
46 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
