I have a 67 camaro the radiator got hot had to add 3 litres of coolent the next day the T 350 gearbox is slipping in drive
  • 460 Answers
The trans is causing the motor to overheat. you hahe a trans. problem...
Posted on Nov 12, 2009
    Genius:
  • 1,341 Answers
The gear box has nothing to do with the coolant that you have topped up.This is a different problen here.
The bonnet of the car is so hot after driving
check for any leek in radiator coolent if no leak drain and refill the both radiator and coolent sump with new coolent.
Apr 06, 2014 | 2003 Mitsubishi Lancer
I drive a 1990 celica 185 gt4, it had an issue with blown head gasket ( pushing the water/coolent out expansion tank) got gasket done. head plained etc. i got car back from garage with head gasket done and...
im guessing that maybe your thermostat is sticking. im not sure what else would make your coolant rush out like that. if im right, then that would definitely make your car overheat at speed, but not at idle. that isassuming that the thermostat is at least partially open. if that doesnt fix the overheating, then u may want to consider checking the ignition timing for being too far advanced, or even the camshaft timing.
Aug 04, 2009 | Toyota Celica Cars & Trucks
Overheating
Most common reason for overheating is 1. low coolent lvl 2. faulty thermostat (stuck closed). 3. Faulty water pump preventing coolent from circulating through engine.
Check coolent lvl in radiator when engine is cool by removing the cap and filling it up till you can see the coolent, replace cap and try. If you have the proper lvl of coolent. Replace your thermostat, which is located under the thermostat housing (right underneith where your top radiator hose connects). Fill with coolent and see if that helps. Next test is to start the car and let it run till it gets to normal operating temp or near (180 to 220 degrees F) Pinch your upper radiator hose and see if you can feel a gush, or flow of water rush through the hose when you release your pinch hold on the hose, (by pinch, I mean to try and totally squeeze the hose together) If you don't feel the rush of coolent through the hose, then your waterpump is faulty. If your car quits overheating, but your heater hoses don't get hot, then they are probably stopped up at the point where they connect to the engine. Its a common area for gunk, rust, and corrosion to build up.
Dec 09, 2013 | 2000 Pontiac Grand Prix
Cannot locate cold fill line on impala 2008 coolant overflow tank
Just fill it up 1/4 full with coolent. Coolent expands when hot, which will fill the tank up more, so don't over fill too much. If you think your low on coolent, let the engine cool down, and open the radiator cap and fill it full from there. Filling the tank, will not add ANY coolent to the radiator untill it warms up (expands) and cools down (contracts pulling in coolent from the tank only at this moment.)
Dec 04, 2013 | Chevrolet Impala Cars & Trucks
I have a 2001 dodge dakota 4.7 litre v8 truck is running hot replaced hoses , thermostat, radiator cap, coolent temp sensor, rdaiator fan relay, flushed system, bleed system, still running hot coolent...
my be the heat sensor indicating wrong reading or you might be having a gasket problem but only if water level is decreasing and/or change into milky or brown color in coolant color
Jun 06, 2011 | 2001 Dodge Dakota
My 1992 Honda Accord runs hot when I stop at a stop sign and the temperature gauge goes up like it wants to run hot but when I take off the guage goes back down. There is also smoke coming from under...
That's not smoke coming from under the radiator cap, it's steam. The radiator may be low on coolant or is clogged or the engine's thermostat is stuck closed or all of the aforementioned. Whichever the case, it needs immediate attention, before the engine blows up from overheating.
Mar 08, 2011 | Heating & Cooling
My temperature gage is going over in the red and my heat is not
Check the sensor which controls the cooling fans that cools the radiator it prevents the engine from over heating and allows the temp gauge to stay at normal range.recently had problems with my 2003 impala overheating it was the sensor had the thermostat replace as well.
Feb 10, 2010 | 2003 Chevrolet Impala
Isuzu bighorn automatic transmission slips after heating
Change your gearbox oil, and clean out the oil strainer.
Should help.
( On some models, you have to remove the gearbox oil pan to clean the strainer )
Nov 01, 2009 | 1994 Isuzu Trooper
Coolent lose
Check youre waterpump...also spending 5 dollars on "Radiator STOP Leak" is a good investment. its an additive you add to youre radiator. If the actual radiator has a small crack or leak, this will fix it. Check every inch of both the upper and lower radiator hoses and connections.
Aug 22, 2009 | 2000 Toyota Celica
37 people viewed this question
 Grubhead
Grubhead
