Question about HP PSC 1210 All-In-One InkJet Printer
My printer no connection cable and also power cable what is price for two materials??
  • HP Master
  • 3,247 Answers
You will need to search on the internet or go to your local computer parts shop.
You will need a USB printer cable (approx $10) and a AC power adapter for the HP PSC1210. This will cost about $20-35 depending on which style you chose.
check http://www.sparepartswarehouse.com/HP,PSC,1210,Printer,Power-Supply.aspx
Posted on Nov 12, 2009
My hp printer overheats and takes too long to cool
Please follow the steps below to hard reset the printer and let me know the result.
1.Remove all the cables from the printer.
2.Wait for 10 mins.
3.Connect only the power cord and try to power on the printer.
4.If the problem is solved, then connect all other cables, otherwise let me know.
If this do not solve the problem, then it will best to replace the printer, as the repairing cost of your existing printer will be higher than the price of a new printer.
Aug 28, 2012 | HP Office Equipment & Supplies
Tip
How to determine the formula of ribbon you need
Not all thermal transfer ribbon formulas print on all materials, the key is to match the label material with the proper ribbon. There are three main types of ribbon formulations used in most thermal printers.
Wax -
  • the least expensive
  • works best on thermal transfer paper labels (it may print on the other materials to some degree but will easily scratch off)
  • looks the darkest (more opaque) when unrolled and held in front of a light
Wax / Resin
  • this is a very wide ranging category, some formulas are the same price as wax, others can be almost the same price as resin
  • works best on thermal transfer labels paper, preprinted thermal transfer labels, and many polypropylene materials
Resin
  • the most expensive
  • the most durable
  • is UL approved when matched with a compatible material
  • works best on polyester and polyolefin
  • looks the lightest (more translucent) when unrolled and held in front of a light
on Aug 20, 2010 | Office Equipment & Supplies
Error 5100
1) Smearing or scratches on the timing
**** film;
clean the timing **** film.
2) Foreign material or paper debris that
obstructs the carriage movement;
remove foreign material.
3) Ink cartridge conditions;
re-set the ink cartridges.
4) Cable connection
5) Part replacement:
- Timing **** film
- Carriage unit
- Logic board
- Carriage motor
Aug 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Myy Brother MFC5460 will not print at all. Printer status says it is ready, but the printer never receives the print material. The information remains in the print queue. Work Offline is not checked, so I...
How is it connected?
If its connected via usb cable just follow the steps below:
1. Make sure that Mfc5460cn lcd shows date & time. 2. Disconnect the usb cable from the computer and printer. 3. Turn off the printer and unplug it from the power outlet. 4. On the computer, cancel the document on queu. Go to printers folder and right click on the Mfc5460cn icon and left click on cancel all documents. 5. Reconnect the usb cable from the printer then to your computer. Make sure that it is connected securely. 6. Plugged the printer back to the power outlet and then wait for the lcd to show date & time. 7. Open the printers folder again. Make sure that the status is ready document 0 8. Right click on MFC5460cn then left click on properties. ON the lower left side of the window click on print test page.
The printer should print a test page. And it should work,
Hope this helps. Rate if it works. Thanks
Apr 09, 2011 | Brother MFC-5460CN InkJet Printer
I have just bought a hp printer but how to instal?
Installatin is usually quite simple depending on the make and model. First make sure all the shipping material and tape is off the machine. Install the printer cartridge and put paper in the trays and power it up. If you are connecting to the PC via a parellell cable, plus it into the computer and the printer of course. If a USB connection, do the same. Power up your pc and printer and go to the control panel and click on teh add printer icon and follow the directions.
Mar 19, 2011 | HP Office Equipment & Supplies
After 20-30 prints i got this error.. error 6A80 can you help me about this my printer is PIXMA iP4760... i laways plug in an d out the power cable.. can i have a long time solution with this problem...
In the service manual write this
1) Foreign material or paper debris
around the purge drive system unit;
remove foreign material, and
confirm that the ink absorber right
beneath the purge drive system unit
stays in place and does not contact
the unit.
around the ASF unit;
3) Cable connection
4) Part replacement:
- Purge drive system unit
- Logic board
As technician i say to replace the purge unit.Pls give me a vote I have been helpful.
Mar 06, 2011 | Canon PIXMA iP4700 InkJet Photo Printer
Hello, I've been trying to pirnt for the past hour from my cell phone, and it doesnt print. Frutrated!!! with new polaroid zink printer.. please help thank you
First perform systems connectivity inspection on the printer to the computer. Ascertain that the power cables are in source of current. Second, ascertain that the cable connection from the printer to the computer is intact. Third if any cables were loose, reconnection attempts would require restarting the computer altogether to acquire the new settings before printer actions can take place. Second perform a test print job. Usually the type of material requirign printing should have been highlighted or selected with the mouse as an indication of what requires hard copying. Clicking on the printer job buttons should achieve responses fo action. Important notes.
1. A change of printer accessories like ink or paper may have caused printer malfunction. Inspect the compartments that holds ink/ paper for inappropiately closed entrapments, dislodged supplies or depleted.
2. An attempt to expose the ink compartment while printer is still powered to the computer would require powerign of for restarting once more to acquire the new settings.
3.Refer to the printer user guide for details
Jan 27, 2011 | Polaroid Office Equipment & Supplies
I have lost the cable connecting the pc to the printer wher could I buy one please
Just buy a USB printer cable from Walmart or Ebay.com (for a better price) or Amazon.com (for a good price). Match the male or female ends together so it will fit correctly.
Jan 13, 2011 | Lexmark X2350 All-In-One InkJet Printer
Printer says clear paper jam then press reset
Could there possibly be:
A) Paper jammed internally: Power Off. Open the cover and remove the paper or scrap carefully. Do not touch the internal printer parts. Close the cover. Power on.
B) Foreign objects in printer: Power Off. Open the paper support and confirm that there is no foreign material in the auto sheet feeder. (If so, remove it by hand or with tweezers). Open the front cover and confirm that there is no foreign material in the unit. Avoid touching the inner workings of the machine.
C) Reset the printer:
1. Turn the printer off with the Power button
2. Disconnect the data cable from the printer
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Attach data cable.
4. Turn the printer back on.
If all of these suggestions fail, your iP1600 may require repair service. Please note: With the suggested retail price of $29.99 USD, repair does not seem cost effective - you could just go out and purchase a new printer.
Dec 28, 2009 | Canon PIXMA iP1600 Printer
Pixma iP 1500 shows paper jam and makes squealing noise when activated to print. There was no paper jam when this occured.
Remove foreign objects from the paper path iP1500
Remove foreign objects Foreign material inside the printer can cause printer malfunction Caution: The power cable should be disconnected from the unit when inspecting the paper path for obstructions.
  1. If there is any foreign material (such as a piece of metal or pen) inside the printer, after turning the printer off and removing the power cord from the outlet, remove it by hand, or with tweezers.
  2. Check to be sure that there is no foreign material by opening the printer's top cover and paper output tray.
Sep 05, 2008 | Office Equipment & Supplies
HP PSC 1210 All-In-One InkJet Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
