Question about Fuji FinePix F650 Digital Camera
Pictures are in green and screen turned into green
--green screen no picture
A plain green screen display denotes a fault with its display panel
Dec 01, 2013 | Insignia Televison & Video
Hi, recently my flat screen tv screen turned a solid green.. i tried to turn the tv on and off and tried adjusting the wires but it hasnt seemed to work.. it does show a picture when i play a dvd tho. what...
The picture turns green if the component input cables are not connected in. Can you confirm that it is what you are using when you get the green picture? If yes can you please clarify the connection sequence of the RBG cables and the repective ports like Yb, Pb,Pr?
Apr 17, 2011 | Panasonic 50 in. Plasma TV
I gotta a green screen
It is possible that you have a shorted green CRT, you can remove the front speaker cover, and you will fine a focus block, and if you turn down the green screen voltage, very slowly, the green should turn down. if not then the gun (CRT) will have to be replace, If it does turn down, then go into the menu and turn the color are the way down and that should give you a black and white picture. If it is not black and white. adjust the red, blue, and green screen voltages until you receive a good black and white picture. Turn slowly they are touchy, and if turn to high, you will get retrace lines and the TV will shut down.
Nov 14, 2010 | Toshiba 61A60 TV
My LCD tv model LN46A650A1FXZA picture turns green after about being on for 5 minutes. Then is gets fuzzy and green
I have the same issue. TV is ~ 2 yrs old. Ruled-out cable-box & HDMI cables (green present in menu mode with no cables attached).
Screen turns mostly green, with a crappy picture. After a few days, a normal picture just appeared. Today I powered-on, the green screen stuff came up, then a minute later a good picture for about 20 minutes, back to green-stuff for 10 seconds, then good picture.
Did chavez_debi get her issue resolved?
Aug 05, 2010 | Samsung LN46A650 46 in. LCD HDTV
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Need to clean lenses and do manual focus/alignment of guns on a VS-5055. How do I get access to them and adjust? Thank you.
the lenses are accessable by removing lower back of unit,clean them with a damp paper towel-wipe them off with a dry one.put back back on unit.
screen/focas controls are in front of unit.remove speaker grill remove black cover using phillips screwdriver.you will see 2 sets of controls.one row is focas.one row is screen controls.red,green,blue.turn each focas control slowly to get the clearest picture for each color.screen controls are touchy(if you turn then too high unit will shut off)if the black and white picture was good i would not adjust screen controls.if it was bad turn blue and green screens down all the way.picture is now red turn green up until it turns yellow then turn blue up until it turns white
Sep 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have no picture, only green screen and audio when I turn on
i have no picture the sceen is green but i have sound can u help thanks.
Jun 06, 2009 | Polaroid FLM-2011 Television
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Sony kp-57ws500 green screen then auto shutoff
I have the same tv and it did the same thing only now it has red hues all around the picture as well. The service guy told me it was the green tube and it would be about $500.00 to replace and may not fix the problem. What a p.o.s. I will not be guilty of buying any other Sony products from now on.
Jul 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture failure
Do not have a clue without a model number and make. Are we to be fortune tellers here too?
Oct 04, 2007 | Televison & Video
Fuji FinePix F650 Digital Camera Logo
16 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
