Question about Palm Vx Handheld
How do u remove vx commodore front bumper,have all screws out but the sides are tricky,dont want to break the clips on hockey stick.whats the trick to it? cheers wayne
  • Palm Expert
  • 346 Answers
Normal 0 The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
http://kb.palm.com/wps/portal/kb/na/visor/deluxe/unlocked/supportservices/page_en.html
Posted on Nov 19, 2009
Reolace front bumper 2001 ford focus ghia
raise and support front of vehicle, remove radiator grill, remove the headlamps, disconnect the wiring from the indicators and fog lamps.
undo the screws holding wheel arch liner to front wings (1 each side) and the screws (3 each side) securing the bumper to the wings.Release the 6 securing clips from the top of the bumper cover and the 3 from the bottom. with someone helping, pull out the sides of the bumper and slide forward. Fitting is in reverse order
Mar 14, 2015 | 2001 Ford Focus
How to replace front light in mazda 3
to replace the headlight, the bumper should be removed, in order to expose the bottom bolts of the headlight. be carefull, on the side of the fenders where the bumper clips in, it usually breaks if manhandled. this will cause the bumper to clip out in the fender sides.
Aug 26, 2014 | 2004 Mazda 3
Remove front bumper 1999 tarago
Hi
This is how you remove the front bumpers from 1990-2000 model Toyota taragos/Previas
First if your tarago/previa has a bull bar it has to be removed, before you can remove the front bumper.
There are 6 X 18 mm bolts secured to the bull bar brackets, remove the 3 x 18mm on the left and 3 x 18mm on the left and place the bull bar in a secure area to reattach later, don't be surprised if its full of rust it needs to be sand blasted, rust treated and repainted.
The next step is to remove the bull bar brackets to do this you must remove the grille to access the 4 x 18mm bolts on the inside of the grille 2 x 18mm on the left and 2 x 18mm on the right.
Open the bonnet of your tarago/previa there is a screw at the top of the center of the grille that has to be removed and placed in a container to reassemble later.
The next step is a bit tricky but with persistence and practice you will get better, the grille has four plastic clips that hold the grill in place.
Now listen carefully, you cant just pull on the grille firmly and hope that strength alone will pop the grille, these clips are designed to open when the grille is pushed into place so the top and bottom of the clip have to be depressed to slide the insert out to remove the grille, but you can depress one side a time it dosent have to be both at the same time.
It just takes take and patience to do, start from the top left clip, pull the grille towards you and with a flat blade screw driver look down the grill and press the top of the clip still pulling the grille, the clip will depress but now you have to do the bottom of that clip too.
There are gaps in the grille you need a tool like a L shape pick or an interior tool shaped like a L for removing door trims, you can buy these items at $2 dollar shops, you feed the tool through the gap in the grille and place it under the bottom of the clip and when you press down it lifts up depressing the bottom of the clip while you are still pulling the grille towards you.
Once that clip is out stay on the left side and do the left bottom clip repeat the process and then do the right top clip and then the bottom right clip, when the grill is out push all the clips back into the grille so you don't loose them and place grille in a secure place until your ready to reassemble.
When you reassemble the grille you just place the grille over the insert holes and push them back into place they will automatically snap back into position and then screw the center top grill screw back in.
Now the grille is out, you will need an extension on your ratchet to reach and remove these bolts 4 X 18mm bolts, 2 on the left and 2 on the right, there is a dryer bottle on the left or right of your vehicle depending on country, so the extension needs to be reasonable long.
Once the brackets are removed place the bolts into your container, there are 4 x10mm bottom bumper bolts securing the bumper onto the reinforcement bar remove them.
Then there are 2 X 10mm upper corner bumper bolts securing the bumper to the body remove them, and then the last 2 X 10mm to be removed are at the bottom of the corner bumper secured on to a rail.
Once these 10mm bolts are removed the front bumper will slide off, place the bolts in your container and reassemble when ready.
Cheers
Jun 07, 2012 | Toyota Cars & Trucks
How can I replace the left front fog light unit from a toyota prius from 2009. I cann't find a maintenance manual for this model and year.
Its all attached by clips and screws.Nothing much special.But its all about the procedure.Dont forget the mark the position , location of the screws you remove, so while refitting you don't face any problemTo replace fog light bulb or to replace replace complete fog light unit, click this link below:--- http://technoanswers.blogspot.com/2011/07/how-to-replace-left-front-fog-light.html ---------- This will help.Thanks.Helpmech.
Jul 09, 2011 | Toyota Prius Cars & Trucks
My 2005 Avensis sedan front windscreen washer does not work - wipers do still opperate. Where is the fuse for this located and what else could cause this problem?
PROBABLE CAUSE Impact to the front bumper pushes the bumper back far enough to break the washer pump hose fitting. CORRECTIVE ACTION Replace the windshield washer reservoir and washer motor with updated parts. REPAIR PROCEDURE 1. Turn the ignition switch to ACC (I) to unlock the steering column. 2. Raise the vehicle on a lift. 3. Remove the right front inner fender. Unhook and pull back the bumper for better access. CLIPS (6 places.) SCREWS (6 places.) RIGHT FRONT INNER FENDER 4. Release the hooks on the upper right side of the front bumper. 5. Remove the clip from the filler neck, then remove the filler neck. FILLER NECK CLIP WINDSHIELD WASHER RESERVOIR CLIP WASHER MOTOR CONNECTOR BOLT BOLTS WASHER TUBES 6. Remove the right front fender trim, and disconnect the washer hose from the 90-degree fitting. CLIP FRONT FENDER TRIM FRONT HOSE 7. Disconnect the 2P connector and the two washer tubes from the washer motor. 8. Remove the washer reservoir clip and the three bolts, then pull out the reservoir. 9. Assemble the new reservoir components, but do not install the filler neck. 10. Trim 85 mm off the end of the 1,260 mm washer tube only. 11. Route the washer tubes on the reservoir. NOTE: The black fitting is for the front windshield nozzles, and the white fitting is for the rear nozzle. 85 mm 12. Install the reservoir. 13. Connect the rear tube to the straight fitting in the wheelwell. 14. Connect the 2P connector to the washer motor. NEW RESERVOIR Connect the rear washer tube. CLIP BOLT 9.8 N•m (7.2 lb•ft) 15. Install the filler neck with the original clip. Connect the front washer tube to the 90-degree fitting. Then reinstall the front fender trim. WASHER FLUID DIPSTICK 2P CONNECTOR FRONT FENDER TRIM FILLER NECK CLIP
May 15, 2011 | Toyota Passenger Cars & Trucks
How do you remove a rear bumper
How To Install Replace Remove Rear Bumper Cover Honda Civic 01-05
Dec 11, 2010 | 2004 Honda Civic
How do you take bumper of vw passat 2003 to replace radiator
Tools Required
T25 Torx Screwdriver
Phillips Head Screwdriver (if equipped with fog lights)
Small Flathead screwdriver
Wide Flathead Screwdriver
Bumper Removal
1. Jack the car up on both sides and remove the front wheels. Use Jackstands and please observe all safety procedures. I'm sure it's possible to do this by turning the wheels to each side as you work in the wheel wells, but this was easiest for me to do.
2. Remove the hood release lever.
Pry out the plastic guide on the front of the grill, and looking directly down on the hood release lever attachment point, you'll see a metal clip. Using your small screwdriver, flip that clip up so it's off of the plastic lever and place your wide screwdriver in the Y of the plastic, turn the large screwdriver to spread the Y off the pins that it is holding on to. This can be VERY frustrating, so take your time. If you need to remove the latch cover in frustration, it's a $6 part from Liberty (experience)
3. Remove the front grill.
Just a T25 torx screw on each side and clips underneath, be careful not to break the clips as you pull it off. If you have an aftermarket grill you might have to pull through or cut off your double-sided tape
4. Remove the 3 lower grills (they just pop out, the middle one is a little tricky, just take your time and make sure all the plastic clips release)
5. Remove fog lights (if equipped) 3 screws each and disconnect
5. Remove the 4 T25 screws from the top of the bumper (under where the grill just sat)
6. Remove 4 T25 Screws from each wheel well, one is pointed straight up, you'll have to feel under the wheel well where the bumper meets the fender to find it.
7. Climb under the car and remove the 3 flat head screws (they just twist out)
8. With your helper, pull the bumper straight towards you from each side, and remove the connections from the side markers. The bumper should now be free.
Installation is basically the reverse of removal HOWEVER, there are tabs on each side of the car that line up with tabs on the bumper, be absolutely sure that these line up, they will center the bumper for you and hold it on while you screw it in.
Removing Bumper strip
1. Looking at the back of the bumper that you just removed, find the 4 tabs and 4 hooks holding the strip on. The hooks are down by the side marker holes, and the tabs are on the front of the bumper.
2. You'll see a black pin holding one of the hooks in place, if you push with a small screwdriver on the bottom of this pin, you'll see another, smaller pin come up, pull this pin out as far as you can and the large pin will pop right out.
3. With your screwdriver, carefully pry back the tabs and pull on the strip from the front of the bumper, releasing it in sections.
4. After all the tabs are removed, pull the strip away from the bumper (as if you were pulling it from off from the front of the car, and it should come right off)
I hope help you woth this. Good luck (remember rated this help).
Oct 01, 2009 | 2003 Volkswagen Passat
Cadi CTS 05 Front Blinker / Running Light Bulb is out
It is fairly simple to replace the turn signals on the CTS. You do not have to remove the whole bumper, just enough to let you inside behind the lights. Turn the steering wheels one way and remove the 4 clips around the bumper with a flathead screw driver. Then do it again to the other side. You can remove the top clips to give you more wiggle room. Look under the car and remove enough of the clips to loosen the sides. At this point you can stick in your hand from the wheel well and replace the lights. Just turn and pull and re-install the new lights. Simple.
Apr 12, 2009 | 2005 Cadillac CTS
Headlight out on 2000 chrysler m3000
remove bumper
then there should be retaining clip or 2 screws holding the lamp in OR
remove the wheel fenders and behind the wheel fenders you will see clips or screws this will be little tricky but you can do it one side you will have to remove battery also to get to lamps
OR jack car up enough to get your hands behind lamp unlock there clips and pull lamp out bulbs should stay put
Nov 26, 2008 | 2000 Chrysler 300M
Palm Vx Handheld Logo
621 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
