Question about Garden
Tried starting my petrol mower, not used it for 3 weeks, and it won't start. it has petrol etc. could it be damp, it has been under cover but outside
    Genius:
  • 1,341 Answers
First check the spark plugs if there is any spark when u try to start the engine...if there is none, then test the wiring without the spark plug and see if there is any spark...now if this does not solve then check the carb and also make sure there is petrol in it and petrol is flowing to the carb freely..If that does not solve then let us know and I will explain further as there is more complicated things that need to be checked and I cannot assist in a simple message.
Posted on Nov 12, 2009
Starts, but halve the power
Has the mower been tipped on its side since you used it last?
are you using fresh petrol ( less than 6 weeks old!?)
does it smoke much when running?
If you could answer these 3 questions I maybe able to help!
Jan 17, 2014 | Electric Lawn Mower
Petrol mower won't start
Could be any number of things, start with fresh fuel and a new spark plug, then check the flywheel key has not sheared, make sure the blade is tight, if not better it may be the valves have burnt and are now not seating.
Apr 15, 2012 | Garden
Why won't it start when it's damp outside?
The first thing I would look at is spark plug wires.
Feb 07, 2012 | 1994 Pontiac Grand Am
The mower was putting out white smoke and then it was choking out. Now it won't turn over/ start.
There may have been too much petrol going into the engine, possibly caused by having the choke on. Ensure the choke is not engaged, and then try to start the mower again
Aug 27, 2011 | Garden
Flymo petrol mower starts but won't tick over.....keeps cutting out
Probably needs the carburetter cleaned out. Smell a lot of petrol? could be flooding out. Starts up but dies. No smell of excess petrol? Fuel line clogged at tank inlet, rust? Other crud? Gas gets to carb, engine starts then runs out of fuel. I dont know the flymo carb, but generally...
Start by removing the bowl under the carb, 2-3 screws. Youll need to remove the air filter box first. You should find a float tank which operates a needle valve. This can be released by popping out a pin pivot. DO NOT LOSE THE NEEDLE VALVE which will come out with it. A pointed stem which closes the fuel as the float rises. If you see a lot or just a little crud around here, that can be the problem. Clean it out with carb cleaner spraying up into the where the needle seats, also spray into every opening you see. Carefully replace the needle and float. The needle generally snaps into or is locked into the float loosely, then pin the float back in place while guiding the stem back into its hole. Replace the bowl and try to start it.
Good luck
Jun 05, 2011 | Garden
2001 r1 not been run for 14 months started it up not responding like it should.emptied tank n put fresh petrol in seems to respond better higher up the revs but wont tick over getting a bit ov back fire.
Try cleaning out your carb, Petrol starts to form into a jelly after 3 to 4 weeks if you dont turn the engine over. Your carb is situated under your petrol tank. Hope this helps
Jun 22, 2010 | 2001 Yamaha YZF-R1
Husqvarna R53SV Petrol Mower wont start. I think too much oil had been put in. I drained some out bu still wont start. Is the engine flooded? how could i start it? Thanks
Use starting fluid when it does finally start continue starting until all the oil is cleared out of the carburator you may need to repeatedly choke out the carb with the engine running to clear out the carb, do this by removing the air cleaner, start the mower on high speed rpm, and cover the air intake with your hand repeating this start/ choke/ stall procedure until it is cleared out it works, I just did this to a mower last week that had too much oil in it, the mower smoked quite a bit but eventually returned to normal
Jul 15, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Why wont my suzuki bandit 250 start? it turns over but doesnt start, i changed the spark plugs last week and it started and then tried this week and doesnt start again, i took 1 plug out and it was very...
If you tried to start the engine for any length of time, the plug would be damp and smell of petrol because fuel was being drawn into the combustion chamber. Without spark to ingnite the mixture, it would cause the plug to become damp. I am assuming you fitted the correct spark plug and that it is gapped correctly.
I don't mean this to sound foolish, but I would suggest you make certain the emergency kill switch has not been accidentally switched off. Also, if you have a sidestand safety interlock that prevents the engine being started while the side stand is down, flip up the sidestand and try again to start it.
Additionally, to make sure the plug wire is securely fitted to the plug. It is possible that the inside of the plug wire cap has gathered moisture and may need to be wiped dry.
If none of the above suggestions solve the problem, remove the plug then reconnect it to the plug wire and hold it near the cylinder - but not near the plug hole in the cylinder head (fuel vapors) - while pressing the starter . You should see an obvious spark. No spark likely means the coil is faulty.
Mar 14, 2009 | 1992 Suzuki GSF 250 Bandit
Can i cover my outside house vents in the winter?
you should never cover any vents, they are there for a reason, to keep you safe from fumes, damp, etc.. (If talking about vents that are outside you home). If you are talking about appliance vents then you run the risk of them breaking if you cover the vents, due to overheating
Vents that are outside the home including boiler vents etc... exhume all of the carbon dioxide that is bad for you. Vents that are there to stop damp, if blocked may cause you to have a problem with damp in the future.
Jan 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
