Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Lawm mower engine will only run on choke
Lawn mower engine will only run on choke
  • 460 Answers
The carb is gummed up with laquer. take it of the motor and soak it in some solvent for an hour. but first take off the float cover before emersion.
Posted on Nov 12, 2009
Why does my Husqvarna 122c trimmer not start?
try this hold the throttle open all the way then choke it or primer if you have one then pull stat it . it should start up this is a trick that lawm mower tech use to start badly flooded trimmers are new trimmers that have not start it gets them to start right up so they can adjust the carburator so they will run this might help you to start the new trimmer you have
May 19, 2014 | Husqvarna Garden
Where is the choke
Many Briggs engine have a primer rather than a choke, the 675 series has a choke that is worked by an air vain, the choke is always closed when the engine is stopped, once the engine starts air pressure from the flywheel pushes the air vain which in turn opens the choke to allow the engine to run normally, there is also a version with a bi thermal switch on the back of the muffler, as the muffler heats up the switch opens the choke.
Feb 12, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
My lawn mower is surging and spark plug is black is this lack of air briggs& stratton . plus runs ok when running out of petrol /????
Are you running it with the choke on? Also if the air filter is dirty it will do that as well. Black plugs means it's getting too much gas and is not getting the proper air to burn properly. Some engines if you rev them up with the handle right as fast as it will go automatically the choke is on.
Sep 01, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Engine starts sputters then shuts off
probably a dirty carb. or if this problem is occuring when the engine has been run and is hot and its the new style easy start engine with auto choke ( no primer or choke lever) then the auto choke unit coud be faulty
Aug 21, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
My craftsman 6.5 hp lawn mover oil leaaking and smoke coming ou
Smoke white or blue? = oil overfilled possibly.
Apr 16, 2010 | Garden
I have a 15hp tecumseh engine that will only run with the choke on.
You have a partially gummed up carburator. Get a bottle of carburator cleaner to add to your fuel. Follow those directions and you should be fine.
The alternate method may be to get a can of starter fluid. Spray the fluid into the air intake as the engine is running with the choke on. When the engine sounds better take it off of the choke status. Joe
Apr 11, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn mower stays running on jumper cables but once disconnected it shuts down when choke is engaged
if it is already running and you "engage" the choke, you will flood the engine with too much gas and it will sputter and die. the only time you engage the choke is to start the engine when it is cold. if the mower dies when you remove jumper cables, and you leave the choke alone, you need to have someone look at your charging system.
Apr 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Toro lawm mower
the bulb is allowing air in some where. Replace it.
Jul 20, 2009 | Toro Lawn Mower With Toro Power Tools
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,176 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
