Question about Hoover PE235 Front Load Washer
Drums tries to turn but fails.
The machine was working through its cycle then the sockets in the house tripped.
Put the power back on and the washing machine was trying to turn the drum but to no avail. The drum would kick then the machine would stop trying, wait a few seconds, then try again, fail, then wait, then try again, fail.....
The drum turns by hand no problems.
I guessed the motor.
Took the back off an nothing obvious.
Took the motor out of the machine, took the brushes off, and they are still have 14mm left on them. The armature doesn't look excessively worn.
The machine is 6 years old and average use (2 people in the house and no kids).
Any thoughts / tests I could try? I have a multimeter if that helps?
  • 1 more comment
  • websites0562 Nov 12, 2009
    Circuit board is intact.
    The tacho on the end of the armature looks secure.
    The main thing that seems to say problem is the fact the house sockets tripped out.
    There are no visable problems with the cct board or the tacho.
    Why did the house socket trip though? That is what makes me think of something shorting out. If something was stuck, then this would produce a high current and blow the appliance fuse.
    Re-fitted the motor, but didn't put the drive belt on. Switched on the machine and the motor struggled to start to turn. when it did turn, it turned ok.
    The coil resistance is 1.7ohm.
    New motor, armature or brushes? Or all of the above?
  • Hoover Master
  • 909 Answers
Usually there is a board on the side of the wall of the machine. Check carefully for dry or burned tracks on the board. they either use a relay or possibly a triac etc, Current is fairly high and any bad soldering can create a dry joint. Look for any loose connections leading from the motor to the board. Check the tachometer which normally connects at the bottom end of the motor.Sometimes the magnet comes loose and gives an incorrect signal to the controller. let me know.
Posted on Nov 12, 2009
Keeps tripping power at 13minutes remaining, just before the spin cycle
Hello. It sounds like the motor has gone bad--possibly a shorted part of the motor, or a jammed drain pump. It also could be the transmission binding at the point of going into spin mode. You didn't provide a brand/model number so my help is limited. The clue here is the clicking before the power trip.
Aug 19, 2015 | Washing Machines
Our old Hoover washer dryer had been working perfectly and then started tripping out - it would seemingly lose power mid cycle. We tried it in different plug sockets and using an extension lead with a...
ok I assume from what you are say that the circuit breaker in the consumer unit (fuse box) trips it could be that the circuit breaker is beginning to fail (they can go weak after prolonged use) and will tend to be a problem on high load appliances the water heater will take around 12.4 amps as will the dryer heater get the circuit breaker changed
Oct 24, 2013 | Hoover Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Aug 15, 2009 | Washing Machines
Machine tripped all sockets halfway through cycle
Hi.
You are going to have find the problem by elimination.
Start by unplugging the motor. and trying it again,if it still does it then you need to disconnect heater and so on, until it stops tripping
Nov 24, 2008 | Washing Machines
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Machine fuses house RCD if a drying cycle is selected
Suggest you turn the power off, remove the top cover, diconnect the live and neutral connections to the dryer element (likely to be two of each flavour of connection if the machine has high and low dry settings). Pop a bit of insulating tape around the wire ends so you don't short anything out. Now try to put the machine through a drying cycle. If it works (albeit cold) without tripping the house power, you need a new dryer element. If the house power still trips, turn the power off again and without reconnecting the element wires, disconnect and tape the live and neutral wires from the blower motor. Again, try to run a drying cycle. If this stops the house power tripping, then it looks like a motor problem (though this would be quite unusual). If the house power still trips, you need to have a careful look at all the wiring between the main timer, the dryer timer, any hi/lo heat switch, the blower motor and the element with its associated thermostats and thermal cutouts (all located near the element on the air duct). Look in particular for chafes where wires go round corners, and where wiring crosses from the case to the suspended machinery in the middle of the machine. Pop any follow-on queries in the comments section of this question - I'll keep half an eye on it. A.
May 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
Hoover PE235 Front Load Washer Logo
136 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
