Question about Bosch Classixx WFL 2066 Front Load Washer
My bosch dishwasher dosnt get hot the element is ok
  • 909 Answers
Does it have a thermostat that you can set the temperature seperately? If so, i would check the over temp thermostat firstly.(possibly it has a push button reset.) Normally found near the element,If good, check the temperature thermostat.Unfortunately, it requires using a tester to check for continuety.and resistence. Normally, that should solve the problem.(Im taking it that the element is ok as you have stated).
Posted on Nov 12, 2009
Dfdsf
Does my Bosch SHU43C06UC/17 dishwasher have a hot water element in it? Our kitchen tap water does not get very hot, and before I hook up the dishwasher I want to make sure it will have water hot enough to...
Hi.
Your dishwasher should never be connected to a hot water tap.
Every dishwasher has its own Heating element. If you connect it to a hot water tap you may eventually damage the inlet valve which has sensitive plastic components in it and may even void your warranty if your installation manual suggests Cold water connection only.
Regards Sam
Oct 06, 2013 | Bosch 24 in. SHU30 Built-in Dishwasher
I have a bosch diswasher which is quite a few years old no sgs3042gb/03. the water isn't getting hot and it doesn't dry?any help will be grateful
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Bosch Dishwashers
My bosch sgs45 tripped the electrics out, now the machine washes the dishes, but does not get hot and stays washing on 1 indefinatley,i have checked the pipe under the kick board which was blocked,also the...
and have you checked the heater element for continuity? also check to where the wires are connected to the element as well sounds like a short to me Thanks Rick
Apr 10, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
My dishwasher does not do a hot wash. Why is this? If I need to replace the heating element, how do i gain access to heating element on my Bosch classixx dishwasher?
Hi, a common problem with these machines is the solder coming away from the heater relay. A simple repair if your lucky. Run a continuity test on the element with a multimeter before replacing it, as it is a massive job to change it. I just changed mine yesterday, the machine had to be totally stripped down. Although its not an impossible task, it does take some time. A kindly man on this site sent me a manual for Bosch dishwashers, which helped me enormously on stripping the machine down. I don't know if it is any good for your machine, but if you give me your email I will send it on to you. Mike :)
Nov 29, 2010 | Bosch SHU9950 Dishwasher
My Bosch dishwasher is no longer using hot water to wash dishes, only cold. I have checked all the connections and they are ok. What gives?
Check the thermostat, heater element. Finally check whether the power supply reaching the element terminals.
Take care if you are doing it keeping the machine ON.
May 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Our bosch shu9902uc dosnt clean the dishes,ive tryed to clean out the drains,blew compressed air thru the drain line,cleaned out the sprayers,still it dosnt clean food off the dishes. water plenty hot and...
make sure you clean the sprayers out real good,if theres debris on the end nozzles they dont spin around too good,also pull out the little service plug that protects debris from getting in the impeller.
i found a little chunk of wood in there! im still not sure how wood ended up in the dishwasher!
Jan 04, 2010 | Bosch SHU9922UC Built-in Dishwasher
Dishwasher leaves a soapy film on the dish's.
ok i run a appliance repair company DENTON appliance and your problem is simple you have a water temp problem the are two thermo sensor under the bottom of the tub one or both are bad causing the heater not to come on to heat the water. it could be a bad heating element but you would be able to see a burned spot on the element. it takes hot water to remove the soap film this should fix your problem.
Feb 18, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Cold water. Water has never been hot since installed.
indicates that the heating element in the unit is non operational ( not connected or burnt out )
Jul 30, 2017 | Bosch SHU5316UC Dishwasher
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch Classixx WFL 2066 Front Load Washer Logo
162 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
