Legacy heater won't stay light
Several years back I purchased a legacy natural gas wall heater with a blower. Recently it has developed a problem. The pilot will light and the heater appears to work fine until it tries to cycle. Then it not only shuts off the burner, but it also shuts off the pilot light. it is like all the gas has been shut off. There is no natural gas smell. I do not believe it is the oxygen sensor tripping because I am able to immediately relight it. Since I can still buy a similar unit for around $200, I don't wish to call out anyone to repair it. But I also don't wish to replace it if the fix might be something simple that I could do myself either.
    President:
  • 1,515 Answers
Hi, Lets see if I can help you out. You have a wall furnace with a forced air fan, 120volts I am sure. It could be a couple of things happening. You say the pilot will light and the burners fire, but after the heat exchanger reaches it's fan on temp, all just shuts down? Does the blower ever come on? It sounds to me that this unit is shutting off on a safety such as the high limit switch.On wall units that don't use a blower, the limit is located in the upper section of the furnace when you remove the cover. If your fan motor never comes on at all, the heat will open this switch and shut down everything.Not knowing if the fan motor is any good, i am just giving you some ideas what would happen if it was bad, shorted, open windings ect.If the motor never comes on then check to see if you have power to it.If you do, then the motor is faulty. If the motor runs, then go to you're high limit. It is a small round flat disc, black wire in and out back to gas valve.Take a jumper wire and jump across this limit and see if it works for you. If so, it would be worth the cost of replacing the limit.If the blower is bad, replace the furnace.Make sure your thermostat is ok also. You can also jump out the stat to see if the unit comes on and stays on. Jump the red and white, you should have only two.If you do this and it runs, do it several times. If all works well, then replace the stat. So there are several things you can check yourself. Please let me know about the blower motors condition. Good Luck,
Shastalaker7
Posted on Nov 12, 2009
Spa heater not staying light
remove burn rack and clean out it is plugged
Apr 15, 2014 | Jandy Legacy 175K BTU Natural Gas Pool...
Pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Aug 28, 2011 | American Standard 40 G Natural Gas Water...
I had purchased this unit RMO-80LPT heater several years back, I never installed unitl this week. the sales en at the time told me it was gas/propane. Now seeing the -80LPT on the side is it propane...
The orifices for a propane heater are much smaller so you will not be able to get the natural gas to flow properly with the current orifices.
The both the natural gas and propane valve are 1/2 psi so the valve can be used but the regulator for propane is typically 8-11 inches on the wc table and the natural gas is typically 3 lbs on the wc.
You may be able to drill out the orifices in the burner and in the pilot ods and get the unit to work.
Oct 13, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heater will not stay lit
sounds like the thermocouple is going out this is the part the flame from the pilot burns on and tells the gas valve to stay open by producing a small amount of electrical current in milli-amps these can be purchased @ a good hardware store and you must position as it is when it comes out , and must be the same length , make sure to connect to gas valve clean and tight , also is there a moisture trap in the line if so you might need to turn off gas and make sure it is free of moisture , this is a good place to start with these items
Jan 16, 2009 | Desa International GWP20T GLOWARM Wall...
Legacy heater problem
first make sure there is no obstructions in the burners, rust,dirt dobers nest or any kind of stuff stopping the burners up. the whole burner won't have to be stopped up to throw flames out.
Jan 07, 2009 | Heating & Cooling
Natural Gas wall heater
It sounds like the thermocoupler is either not adjusted into the flame properly, or you may have gotten a bad one. The thermocouple is the main thing that makes the pilot work.
Dec 22, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
you will need someone to look at this not a job you can do your self i
Oct 28, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heating & Cooling Logo
200 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
