Question about Canon NP 6050 Copier
Bad image after i made adjustment in the service mode it wont memoriiz it what shall i do
    Problem Solver:
  • 14 Answers
Cleane the currana wires & mirro
Posted on Nov 17, 2009
Is there a way to reset to factory settings Loewe TV Connect 40 ?
you've to enter its service mode to do this. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 10, 2016 | Loewe Televison & Video
How do i fix C-E002?
Hladnc, Go to Service mode, state confirmation, memory/HDD adjust, HDD Version upgraded. Firmware on the control board/image control board not matching data on the Hard drive. per the service manual, if not that bad control/image control board
Jun 03, 2015 | Konica Minolta bizhub Office Equipment &...
Sony KP-57WS510 Red Hue to screen.
Misaligned grey scale adjustment. Do a white balance adjustment, after entering its service mode. Contact the authorized service center of any experienced service technician. http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
Please visit these sites to get some details.
Jun 15, 2017 | Sony KP-57WS510 57" Rear Projection HDTV
JVC HD-52Z575 red screen
The solution is an easy fix. Ignore anyone telling you to take it to a service center or to replace the convergence driver. You need to access the service menu on your television by using your remote control:
DRIVE CONVERGENCE Adjustment (Using remote control)
•Use the inner RGB box pattern.
(1)Set the [SLEEP TIMER] key to 0 min.
(2)Press the [DISPLAY] key and the [VIDEO STATUS]key simultaneously.
(3)Press the [9] key to display the RGB box pattern.
(4)Select the R mode by pressing the [DISPLAY] key.
(5)Adjust the R mode to setting as same as G mode bypressing the [CH ]+ / [CH -] key.
(6)Select the B mode pressing by the [DISPLAY] key.
(7)Adjust the B mode to setting as same as G mode bypressing the [VOL] - / [VOL +] key.
(8)Check to see that the cross pattern is white. If thecross pattern is not white, readjust (5) to (6).
That's it, your color is now corrected. Yes, I know...your welcome.
Feb 20, 2010 | JVC HD-52Z575 52" Rear Projection...
How do I fix my screen from being blurry? I have an AccuSync LCD 72vw with AT&T services.
Hello: Try the following:
Signal cable should be completely attached to the computer.
Use the OSM Image Adjust controls to focus and adjust display by increasing or
decreasing the FINE control. When the display mode is changed, the OSM Image
Adjust settings may need to be readjusted.
Check the monitor and your display card with respect to compatibility
and recommended signal timings.
If your text is garbled, change the video mode to non-interlace and use 60Hz refresh rate.
Nov 19, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
How do I get into service mode on a Konica Minolta Bizhub C250 copier and how do I adjust the color settings once I am in there?
hi,
you can get in service mode by pressing: utility counter -> job details ( on lcd) -> stop -> 0 -> 0 -> stop -> 0 -> 1 .
Select "imaging process adjustment", then "graduation adjustment.
The copier prints a coloured sheet, you have to place it to the glass and the machine will read it.
Repeat sequenze 4/5 times. You have to make it in all three section " graduation mode" "resolution mode" and " i'm not remeber".
You can find clear information about graduation adjustment in a installation manual procedure.
Contact me, i can give you a pdf file.
Sorry for my bad english.
Bye.
May 13, 2009 | Konica Minolta Office Equipment & Supplies
Can't adjust aperature in manual mode.
1. Check the power switch is pointing to the rear dial (not "ON") or you wont be able to set your aperture.
2. Try shooting one image for each position of the mode dial on the top. Then review each image to see what mode the camera indicates the image was taken.(Pressing info during playback will bring up detailed information to show this) If the recorded setting and actual setting dont match, this indicates a fault with the dial.
3. If the camera does not display an aperture, or shows "00" then there is a communication fault with the lens. Check the contacts are clean and sitting correctly. You can confirm this lens is at fault by trying another lens on your camera,I'm sure a photo store could help with this.
Apr 05, 2009 | Canon EOS-20D Digital Camera
I have a Konica Minolta Bizhub c351 and all of a sudden it started printing everything with a pink hue and the colors are very uneven.
There is a long process to solve the problem I might suggest that you have to call for service. It might be the magenta developer unit might be bad or rich the max life that need to be replace. Or just plain adjustment on colors setting. It might need to update the firmware to the newest level.
Mar 27, 2009 | Konica Minolta bizhub C351 All-In-One...
Projection tv
How bad are the color? are they like three separate colors. If the colors are real bad all of a sudden, you may need a Pair if STK ICs.
Best regards
Circuitcity
Nov 03, 2007 | Sony KP-51HW40 51" Rear Projection...
Canon NP 6050 Copier Logo
48 people viewed this question
old marine
old marine
