Question about Sharp AR-5316 Advanced Digital Imager Copier
How i can install developer in sharp copier AR-5316
    Problem Solver:
  • 10 Answers
The steps to take are
  1. Open the toner door.
  2. Remove the toner cartridge.
  3. Unscrew and pull out the compartment housing the toner cartridge.
  4. View to see three screws on the compartment undo them.
  5. Next you see an enclosure with spiral, rigth there you pour in your developer. Then couple.
I hope it worked.
Thanks
Engr. Kachi.
Posted on Nov 21, 2009
We are trying to connect the Desk top PC so as to use AR=5316 as a printer.Need help to install the printer software. Can I get it downloaded from Sharp site. Please reply.
you may gey the driver software for AR=5316 printer install sotware inthese websites
http://nodevice.in/driver/AR-5316/get47086.html
http://ptf.com/sharp/sharp+ar+5316+printer+drivers+to+support+windos+7/
Apr 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Installer of sharp AR-5316
Remove the screws marked and all tapes around the copier, open the tray and remove the screw supporting it. Open the front cover and unscrew the green screw holding developer unit and pullout the unit. Open the 3 screws and pour the developer evenly and return it back. Remove the seals on the toner cartridge and insert it. Power on the copier and make a copy.
Nov 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to chande the developer
you take the drum out, then unscrew the developer (it should be a greenish screw), it should slide out, empty the developer out, take bag of new developer shake it up real good... then pour evenly into developer unit, while turning the mag roller... reinstall..
Nov 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Dec 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
142 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
